Author Topic: Proper Design Idea for Maxi & Mini Sysport?  (Read 3898 times)
Offline Festoller
« on: August 25, 2011, 08:15 AM »
I have a few Mini and Maxi Systainers and was thinking about a Sysport design for both to finally get them organized.
There was only one Maxi Sysport post on the board with simple drawers that I could find, but notjhing for the Minis except the Mini in SYS 3 solution.
Has someone built or designed a Sysport for Maxis or Minis? I would have drafted my first thought with Sketchup, but unfortunatley there was no Maxi or Mini Systainer in the library.
Any thoughts?
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
Offline VictorL
Re: Proper Design Idea for Maxi & Mini Sysport?
« Reply #1 on: August 25, 2011, 10:40 AM »
You can implement combined Maxi/Regular systainers and mini/regular systainers. Just rotate smaller systainers 90 degree.
For example one shelf for Maxi has footprint equivalent of two regular systainers. The same rule is true for regular /mini systainers. So in other words Few shelves for regular systainers, few for mini.
Good Luck!
VictorL
