Author Topic: Systainer-compressor out of makita AC001  (Read 18167 times)
Offline ka3ax
« on: October 24, 2017, 03:31 PM »
Made recently Sys-compressor out of makita AC 001
Baking form and systainer 4
Offline dupe
Re: Systainer-compressor out of makita AC001
« Reply #1 on: October 24, 2017, 04:05 PM »
Proper job!! But we need more proof it all fits... [cool]
MFT.1080    CT.Midi    DF.500    DTS.400    ETS.EC150/3    RO.150    RO.90    CXS 10.8    RAS.115
Offline Billy stray
« Reply #2 on: October 25, 2017, 08:49 PM »
Yup i agree, half the job is inside
Billy
Offline ka3ax
« Reply #3 on: November 11, 2017, 01:18 PM »
Here are the photos of the project being built
Offline ka3ax
« Reply #4 on: November 11, 2017, 01:19 PM »
One more
Offline ka3ax
« Reply #5 on: November 11, 2017, 01:29 PM »
The compressor fits right but the motor had to be moved closer to the tank approx 1/5 of inch most of the Cage had to be cut off, air lines from the tank and from regulator had to be replaced due to the their length. I wanted to replace the on/off switch with padded one. But after research found out you cannot modify switch if the pressure switch and on /off built in together. Also the drain valve is not access I left anymore so you have to drain through the pressure releive at the top. All of that is to make sure the compressor is more compact, you can put something on top of it now and also "stick it" to the Schneider and Cadex with their $700USD price tag VS $350 CAD it costed me to build it.
Offline antss
« Reply #6 on: November 11, 2017, 07:30 PM »
Nice job.
You'll have to wait a bit to stick it to Cadex though as their compressor in a systainer version is still a pipe dream.
Did you consider drilling a hole in the bottom to access the drain valve ?
Offline Peter Halle
« Reply #7 on: November 11, 2017, 07:34 PM »
Cool project.  How much time do you have invested in it?
Offline Dick Mahany
« Reply #8 on: November 11, 2017, 07:40 PM »
Great job.  It must be a little hair raising to cut up such a nice compressor to fit.  Glad it worked out so well.  You can expect a few copies of this idea.. [cool]
Offline ka3ax
« Reply #9 on: November 11, 2017, 10:03 PM »
Thank you guys. In terms of the time its a bit tricky I dont remember cause at first I cut off the handle and had to find the material to mount the motor to the rest of the frame. It took about 3 hours. The fact that we live in the condo and the only place where I could work is the balcony. Did not help much. And the second time to finish was about 3-4 hours. But that was about 2 weeks later. Cause I had to gather the rest of the parts.
Offline ka3ax
« Reply #10 on: November 11, 2017, 10:06 PM »
Yes Dick it was a bit scary. Cause I knew if something goes wrong I wouldn't be able to make any warranty claims.
Offline ka3ax
« Reply #11 on: November 11, 2017, 10:12 PM »
In terms of the drilling the hole to drain the air, I did not want to cause the hole will have to be fair Big to accomodate at least two fingers in order to drain it.
Secondly it would be just collecting the dust and other debries from the sites. I am thinking of extending the drain valve with drain kit and fishing and rerkuting it to the side where it will be reach able.
Offline Billy stray
« Reply #12 on: November 12, 2017, 11:38 AM »
Billy
Offline Sandor188
« Reply #13 on: April 07, 2018, 11:47 AM »
Made my own senco 1010 in a Sys 4
Offline Billy stray
« Reply #14 on: April 07, 2018, 03:50 PM »
Looking good I thought I'd have mine done over the winter , i cracked the lid of the systainer and lost my mojo...
Billy
Offline Billy stray
« Reply #15 on: April 07, 2018, 03:54 PM »
lost my mojo...
I assume everyone has seen the cadex..
Billy
Offline Vondawg
« Reply #16 on: April 08, 2018, 10:35 AM »
And the Rolair due out soon
Offline Billy stray
« Reply #17 on: April 08, 2018, 10:30 PM »
I had no knowledge of the roll air 👌sweet
Billy
Offline Billy stray
« Reply #18 on: May 01, 2018, 08:41 PM »
Ok so I'm collecting parts to move on to phase 2 of my 1010 in a sys 4 project
I'm wondering if someone can help me out with the "plugit" set up , ive seen others use this but where do i get the male end that comes out of the systainer ?
« Last Edit: May 01, 2018, 08:46 PM by Billy stray »
Billy
Offline Vondawg
Offline StanB
« Reply #20 on: May 02, 2018, 06:23 PM »
Does anyone know where to get the gage cutout from the rolair or Cade’s?
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18
Offline Billy stray
« Reply #21 on: May 02, 2018, 08:02 PM »
I dont imagine that will be to hard once the Rolair hits the shelves, the must sell "replacement" parts ??
Billy
Offline dupe
« Reply #23 on: May 02, 2018, 10:13 PM »
I’ve messed around and uploaded models to Shapeways and found their pricing very reasonable, though never placed an order. I have used a product for smoothing 3D prints called XTC-3D with good results. Single coat, 2 part epoxy levels the ridges. Sands easy.
Offline Peter_C
« Reply #24 on: May 02, 2018, 10:51 PM »
Make one out of ABS.
Online Gj12
« Reply #25 on: May 03, 2018, 04:43 AM »
Has anyone regretted putting their compressor in a systainer? I picked up an Omega PN1004 and was thinking about doing this.
Offline ggc
« Reply #26 on: May 03, 2018, 05:12 PM »
Looks like Rolair has used the Schneider gauge cutout.
http://ekat.schneider-airsystems.de/catalog/app?__bk_&__rid=LSK1525381567731#2V10C9D9248E4C6405
Part DGKG700007, https://www.schneider-druckluft-fachhandel.de/blende-sys-master-g700007
Offline Billy stray
« Reply #27 on: May 03, 2018, 09:47 PM »
Rolair and every other company that ever sold a compressor in a systainer....except Cadex
Billy
Offline Billy stray
« Reply #28 on: May 03, 2018, 10:03 PM »
I personally like being able to click it right into the stack, im still in the middle of upgrades but I cant imagine id ever not like the convenience
I will say this though
Senco pc 1010--$120
Systainer 4.        $90
Parts.                  $75 ?  Probably more
Gathering parts  time ?
Ready made Rolair $475
Hmmm
But with all that said, its kind of a fun project
« Last Edit: May 03, 2018, 10:14 PM by Billy stray »
Billy
Offline tzed250
« Reply #29 on: May 27, 2018, 04:16 PM »
The Rolair AIRSTAK produces 2.0 SCFM compared to well less than 1 SCFM for the little compressors people are DIYing.
Therefore it can run a framing or roofing nailer where the DIY units can only run trim nailers.
Consider that before you compare the two options.
I haven't yet found a compressor that makes as much SCFM but will fit in the footprint on a Systainer.
If anyone does, post it up!
