Author Topic: Systainer-compressor out of makita AC001  (Read 18086 times)
Offline Billy stray
Re: Systainer-compressor out of makita AC001
« Reply #30 on: May 27, 2018, 10:15 PM »
Yet another really good point
Billy
Offline Kevin D.
« Reply #31 on: May 30, 2018, 12:40 AM »
The Rolair AIRSTAK produces 2.0 SCFM compared to well less than 1 SCFM for the little compressors people are DIYing.
Therefore it can run a framing or roofing nailer where the DIY units can only run trim nailers.
Consider that before you compare the two options.
I haven't yet found a compressor that makes as much SCFM but will fit in the footprint on a Systainer.
If anyone does, post it up!
Just get the Cadex SYS4 like I did.  3.8 CFM @90 psi.
I did read in my research somewhere it is able to accomodate two users using larger guns.
IMO, it is far superior to the AirStak, specs and quality build-wise.  And that's from a loyal Rolair owner and Fan....me!
« Last Edit: May 30, 2018, 12:45 AM by Kevin D. »
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline Kevin D.
« Reply #32 on: May 30, 2018, 12:52 AM »
Here's the specs on my JC10 and the AirStak also.
Offline MGB
« Reply #33 on: May 30, 2018, 10:07 AM »
As someone who recently made a sys compressor. It was very cheap compared to the cadex or rolair
Sys 4 -$90 cad
Senco pc1010 clone - $150 cad
$250 ish and a few hours of spare time, no additional parts were necessary. Granted its a pretty weak compressor, but I knew that and it's more than fine for what I do.
I just grab my mac700 if I'm using a nail gun all day
