Author Topic: SYS3 Bins - 3D Files for printing your own  (Read 6890 times)
Offline BK Makes
    • BK Makes YouTube Channel
Re: SYS3 Bins - 3D Files for printing your own
« Reply #60 on: February 22, 2021, 04:00 PM »
@BK Makes
You should sell your bins, for real! They look super nice :) You could even do them in Festool Green PLA. I’m excited to see how the 83.3x175 bins turn out. Personally I think the lip in the Festool bins (or Bott I should say) takes up valuable space so I prefer your streamliner design. As an example, common domino sizes are 8x50mm, 10x50mm, 8x100mm, 10x100mm, etc. The 50x50 stock bins are only 50mm at they very top so at the bottom they will not fit a 50mm domino lengthwise. The 100x100 bins are the same. They are only 100mm at the very top so they won’t fit a 100mm long domino lengthwise. I think they would just fit in your streamliner bins. That’s a big plus for me.
One question: What is the purpose of the bin within a bin design? It seems to me it would just reduce your storage space. It does look really cool though :)
Very kind of you to say so!  :) though I have no intention of selling plans for anything I end up making. Oooh, Festool-green PLA might have to be ordered though [laughing], I love that idea!
Hmmm... the Streamliner as its currently designed has the same slightly smaller base as the Bott bins, so that may not give you what you're after. I could go slightly larger, but the midpoint of the square lines that run along the bottom of the SYS3 ORG are 50mm, the wall thickness of those lines then slightly eats into the potential widths, as will the thickness of the bins themselves...gonna go grab a 50mm Domino and check things out up close..(the 30mm Domino I just measured is only 28mm.. but I also live in a very dry area)
EDIT: My 50mm Domino is 48.3mm, but still won't fit lengthwise in either bin just given the wall thickness of the bins themselves
I was going to use the bin-within-the-bin for flat, not as numerous things.. Like a pair of mini c-clip pliers in the tray and a pile of c-clips in the bin or a bunch of mini-hemostats that I used to use for modelmaking on top and a few reversed clothepins or those flat, elastic-using plastic clamps on the bottom.. I just have so much random odds and ends in my existing bin drawers that I'm sure I'd be able to use them in some fashion.
I agree with you on the dividers.. they're not ideal in their existing form. As Seth and daz9100 said as well, the 25mm sizes are likely the preferred alternative.
« Last Edit: February 22, 2021, 04:08 PM by BK Makes »
Offline BK Makes
« Reply #61 on: February 24, 2021, 11:30 AM »
So the 83.3x175 Bins do work (at least the "Edge's" do, I'm sure the "Middle's" will as well), though I'm having some warping issues with my prints (green circles in the photos). Typically that's due to a draft or temperature differences in the layers, though I moved my printer out of my garage and that didn't solve it. I'll try printing the Middle section with a hotter bed temperature and a slower fan speed, which should solve it.
In the picture are the bottom sections of two prints I stopped after noticing the warping, and one full bin. I'd note that the .STL file is fine, the warping is only due to my print settings.
The 4x4 "drawer bottoms" in the top right of the picture came out great (though also slightly warped on the corner...same issue). The "wiggle test" proved identical to the SYS3 ORG, though I think some higher, and thicker walls around the edges might be in order if they aren't going to be flush against your drawer sides (I'll whip up a 4x1 square with a taller/thicker edge)
SYS3-like 200x200 Drawer Bottoms
Offline squall_line
« Reply #62 on: February 24, 2021, 11:19 PM »
snip
One note on selling these, etc.  That would not be acceptable on FOG for anything other than custom sizes. And depending on Festools thoughts maybe not the custom sizes either.  This would come under the competing product research and marketing portion of the FOG rules and ultimately Festools discretion.
There's also that pesky little part about how it takes 3-4 hours to print a 25x50 bin. 6-8 bins/day, even selling them at 2 dollars each to turn a margin (which gets eaten up checking on the system every so often), nets...
carry the one, divide my toes...
7 dollars per day, give or take.
You'd be better off setting up an MFT and selling Festool-green lemonade to passers-by on a hot day. :)
Definitely makes more sense to just provide the files and people can print at home.
Offline BK Makes
« Reply #63 on: February 25, 2021, 10:31 AM »
The new and improved 100x150 Nesting Tray (and the tweaking of my printer settings) came out beautifully.
Cheers!
EDIT: as of Feb.27, 2021: The rim of the tray was lowered from being flush with the top to allow the SYS3 ORG lid to close. If you printed this prior to Feb.27th 2021, my sincere apologies. The updated file and pictures are now below. It fits like a glove!
New SYS3 ORG 100x150 Nested Tray .STL file
(getting that 83.3x175 Middle bin on the printer now ed!)
« Last Edit: February 28, 2021, 12:07 PM by BK Makes »
Offline simnick
« Reply #64 on: February 25, 2021, 04:38 PM »
This thread inspired me to finally pick up a 3d printer. My Artillery X1 arrives tomorrow. Your bins will be some of the first things I try. Any advise or resources to point me to for getting started with my 3d printer? What slicer are you using?
Offline festoolnewbie
« Reply #65 on: February 25, 2021, 04:51 PM »
Any chance of creating a 25x150 Streamliner bin
Offline BK Makes
« Reply #66 on: February 26, 2021, 10:39 AM »
FYI: I printed the 83.3x175 Middle bin last night and made a miscalculation in the placement of its feet (it doesn't fit)...
..but it does now! I fixed the file, ran it through Netfabb and modified the original links.
So both the 83.3 MIDDLEs for the 175 and the 350 are now accurate. Enjoy!
Offline BK Makes
« Reply #67 on: February 26, 2021, 10:41 AM »
You bet! I'll whip it up in a few minutes :)
Offline BK Makes
« Reply #68 on: February 26, 2021, 11:34 AM »
Oh man, that's awesome! I've seen prints from the X1 in person and they are fantastic!
My advice to anyone getting started in 3D printing:
1. Free files to print and search are available on Thingiverse There are a lot of other sites like this too these days; Cults, Yeggi, and paid sites like CGTrader, Do3D....
2. Learn Fusion360 early, its free! and you now need a login from its parent company Autodesk to check your files to ensure they are manifold (watertight) using the free Netfabb service. There are a lot of paid Fusion360 courses available, some tailored to woodworking, etc., but Kevin Kennedy on YouTube has a Learn Fusion 360 in 30 Days for Beginners YouTube playlist that is completely free and where I learned it. Google Lars Christensen for additional free resources; he works for Autodesk
3. Slicer. I use the PRUSA Slicer that came with my printer, but it works with all printers (as far as I know, you can configure it to show the Artillery build plate, etc). Its very easy to use (and free!), though it is not the only good one around these days.
4. Check out Angus Deveson at Makers Muse for advice, reviews, tests, neat stuff, etc. He is an OG 3D printer and still going strong with great content.
5. Run any file you pull off a free site (and even the ones you've created) through the free Netfabb service referenced above. This repairs any file found to be non-manifold. There's nothing worse than coming back to a 24-hour print and finding a giant spaghetti mess of hardened plastic caked all over your printhead and print bed because your model wasn't manifold and the printer was trying to print in mid-air.
6. Have supports enabled via your slicer for anything that overhangs at greater than a 45-degree angle (most slicers have an automatic support option). You can change all sorts of parameters here, using stronger honeycomb supports, rectilinear, etc.. over time you will know when you need and don't need supports.. and you can "paint" them in manually as well
7. You don't need to use high infill percentages. 15% is very common and saves you filament. More infill = stronger prints though, and I use the gyroid infill pattern, as it saves plastic and is still strong.. you can find videos of strength tests from CNC Kitchen
8. There are a pile of filaments out there; PLA being the most common. Its also corn-based and actually smells alright, ha ha. ABS, Nylon, Carbon-fibre reinforced stuff, flexible stuff (NinjaFlex).. and all kinds of variants. Your slicer will likely automatically adjust your settings when you input what brand/type you're using but the roll of filament or the box will also have suggested settings. The highest quality prints I've ever achieved were from a roll of PRUSAment filament that came with my printer, but I usually use generic 2kg rolls of PLA because its cheap and still has great print quality. If you're in Canada you can use the code 52021FDC to get 5% off at Filaments.ca. I told them earlier this week I was making a 3D printing video on YouTube and asked if they would share a discount code, and they did! 5% not huge, but its a start :) (I'm sure Seth will let me know if this is allowed on the forum... I get no money from them and have no affiliation.. I just asked and and they gave it [laughing])
9. Setting up a print for the first time, calibrating your bed, your first layer height, etc. is a trial and error process, but once dialed in you should be good. Try not to get too frustrated during this process.
10. Be safe. Your hot end is typically melting the plastic at 215C or higher, there have been fires from controllers and hotends.. a smoke detector would be great. You can also connect a webcam to almost any printer these days (free plans online) and watch your prints from your phone with Octoprint... you can do timelapses, etc, too.. I've printed PLA indoors, but typically do it in my garage on a steel benchtop (and have NEVER had any problems with the smell or fires). I've seen an Artillery (printer brand) operating on a dining room table for hours on end with no issues and no bad smells; but to each their own.
11. Failed prints happen, for a variety of reasons. Software and printers these days are much better at detecting and correcting these, but be prepared for occasional frustration. Such is life.
Good luck! ;D
12. Oh, forgot this one. You can use a conventional mouse for everything in Fusion360 and your slicer program, BUT a Space Mouse from 3DConnexion is AMAZING for improving your workflow and "flying around" your model and the screen. I have the SpaceMouse Wireless so I can use it on my desktop or laptop. It gets used by my left hand, while my right uses the conventional mouse. It comes with its own "training" app to get you fluent quickly, which was a nice touch too.
EDIT: 13. If you come back to your printer and find a failed print and a huge blob of hardened plastic encasing your hotend, don't just try and pry/cut it off. Heat up the hotend first ("Load filament" setting on your printer) and then just pull it off slowly. The first time this happened to me I accidently ripped off the wires connecting to my hotend. Oh, and depending on your printer, almost every tiny little part is available for purchase separately and very inexpensively. You can also print your own parts in many instances, or have a friend print them if yours is out of commission.
EDIT: 14: 3D Printer recommendations: ALL3DP Best Printers (as of Feb.2021)
I've owned or been in close contact with three of their top choices (across different price categories) so in my opinion, its a credible source. ;)
« Last Edit: February 26, 2021, 12:44 PM by BK Makes »
Offline BK Makes
« Reply #69 on: February 26, 2021, 12:13 PM »
The 25x150 Streamliner bin
SYS3 25x150 Streamliner Bin .STL file
I'd note that the 25mm bins are meant to be paired together as one side wall is vertical and the other sloped. They would still work alone, but better together. I've added some extra "feet" to give this one some more stability and have a set going on my printer as we speak.
P.S. I have been 3D printing for a while, but am NOT a Fusion360 expert. After creating the original (with a lot of measurements from a $40 pair of digital calipers) all the other modified versions have been very easily modified. Anyone can do this!
Offline simnick
« Reply #70 on: February 27, 2021, 01:21 AM »
Thanks for the tips. My first prints of basic stuff went great, but once I got to your bins I had issues with supports. What do you recommend for these bins to adhere and support, given that so little actually touches the base? The supports that I first did were way too hard to remove.
Offline BK Makes
« Reply #71 on: February 27, 2021, 10:47 AM »
I've printed most of the bins with the standard rectilinear supports everywhere and they came off like a dream; I recently switched to honeycomb supports (Print Settings>Support Material> "Pattern: Honeycomb"). They provide a much more stable base, and while they are "stuck" to the model a bit better, they still came off as one unit quite easily. I've yet to use a pair of pliers.
I'm using generic PLA too.
If you're using PRUSA slicer there is a new "experimental" feature that they automatically leave on that you have to turn off.
If you go to Print Settings>Support Material>and uncheck the "Don't Support Bridges" box you will get supports under all of the base. You can also confirm this by putting your file on the print bed in the slicer application, Pressing the "Slice Now" button and then rotating the object on screen to see underneath and ensure that the supports are going across the whole bottom, not just the rim.
Offline BK Makes
« Reply #72 on: February 27, 2021, 10:55 AM »
The 25x150 Bins came out great.
In the top right I'd note that the nesting tray, with its newly "improved" rim that goes straight to the top, no longer allows the lid of the SYS3 ORG to close! I've edited the original post on this tray.
« Last Edit: February 27, 2021, 11:42 AM by BK Makes »
Offline Bob D.
« Reply #73 on: February 27, 2021, 04:08 PM »
BK Makes, have you tried using string trimmer line as filament?
Also, any thoughts on the Snapmaker 2.0 A350 ?
I'm looking at the Snapmaker because I would like to have a laser in addition to 3d printing.
« Last Edit: February 27, 2021, 04:12 PM by Bob D. »
Offline BK Makes
« Reply #74 on: February 28, 2021, 12:32 PM »
I have never heard of using string trimmer line as filament! Ha, I'll have to do some googling.
Funny you should mention something capable of laser engraving as I've been looking at laser cutters, I want a higher wattage unit capable of cutting through 1/4" MDF and was considering a Chinese K40, and upgrading it (lots of info on this on the internet, though not without risk) as I don't think a GlowForge would have enough "oomph"/and is pricey for what you get.
That Snapmaker looks pretty clever, though I'd be curious how each function compares to dedicated machines. The price certainly looks good for what you get. A dedicated 3D printer is very inexpensive these days.. a laser engraver, not so much.. so I see where you're coming from..
Just had a read of this, as well: Snapmaker 2.0 Review
Offline Bob D.
« Reply #75 on: February 28, 2021, 01:39 PM »
Thanks for that link to the Snapmaker 2.0 review. Makes me want to hold off for a bit and see if they make any improvements.
Since this would be my first with any of these three I thought the Snapmaker might be a good entry level machine. I had been thinking of a dedicated 3d printer and also a X-Carve Pro 2x4 that I add a 6 watt laser to until I saw the Snapmaker A350.
More money (x3) but better all around and much larger user area for the CNC and laser operations.
Here is a YT video by CNC Kitchen on using trimmer line for 3d printing.
« Last Edit: February 28, 2021, 01:46 PM by Bob D. »
Offline mino
« Reply #76 on: February 28, 2021, 07:55 PM »
Knowing a thing or two about FDM 3D printers, I would expect the Snapmaker to do OK as a CNC and a laser device. Not so as an FDM printer.
The reason the absolute bulk of the FDM market is still at the 20x20x20 cm or so size is mechanics, practicality and costs.
Look on the Prusa Mini - the machine is only marginally (20%) smaller than MK3, yet they were able to get away with a single-arm design. That is the physics part. The mechanical accuracy needed for a (reliable) FDM printer is way above what you need for a good CNC or Laser cutter/engraver and this makes it hard to scale in size while maintaining reliability.
Second is practicality.
On a 20x20 cm printer a job can take days. Try a 40x40 cm print time for big items ...
There is a place for big FDM printers, but it is really a small niche for both reasons.
A (soft materials) CNC or engraver, on the other hand, does not have these limitations as it is mostly a 2D+ tool not a fully-fledged 3D tool. So making it bigger as well as sharing the mechanicals makes a lot of sense.
AGC 18(@AGC 125 flange), BHC 18, C 12, CTM 36, DRC 18/4, PSC 420, RS 200, TSC 55
Narex: EDH 82, EFH 36(fixed@LR32), EVP 13 H-2CA
My Precious FS/2: 376, 376, 376 holy, 632, 1016 holy, 2520
Offline BK Makes
« Reply #77 on: March 01, 2021, 03:01 PM »
Thanks for the link Bob!  :)
Offline Bob D.
« Reply #78 on: March 01, 2021, 08:26 PM »
Thanks Mino. I've been looking further into the SnapMaker and there is a lot to not like. Biggest worry is lack of support and promises that keep coming but over a year later nothing has materialized. Problems with the bed warping, poor cable connections, and other issues have taken it off my list.
So still looking. I'm focusing on the Avid CNC or X-Carve Pro, both in a 2x4 size I think. Big difference in the price of these two. Just getting started at the details of these two. But that is the topic for another thread, and stop taking this one off course. Sorry.
Offline simnick
« Reply #79 on: March 02, 2021, 07:24 PM »
Having fun printing these and other things on my new printer, and just started learning Fusion based on your recommendation.
Any reason why you streamlined the sides, but did not make the bottom simpler? Given that you need to print supports anyways, why not build them into the design? The 25*100 bins would be a lot more stable if more of the wall went all the way to the bottom.
The Boat/Tanos/Festool design is optimized for least plastic when injection molding, but for FDM printing, I think it might want to look a bit different.
Once I make some more progress with F360 I'll give my idea a try, but I'd think it should look more like the negative of the floor puzzle.
Also, you could make the bases wider for a tiny bit more capacity.
Offline SRSemenza
« Reply #80 on: March 04, 2021, 04:00 PM »
Since there is lots of bin measuring in this topic I figured I'd ask here .....................
      Festool gives the height of the bins as 68mm. Is that inside the bin, outside the bin, including feet excluding feet? I want to know the actual usable height of the inside of the M/L89 Organizer Sys.  Trying to figure if it will work for something else.
Offline squall_line
« Reply #81 on: March 04, 2021, 04:12 PM »
Are you looking for the usable height of the interior in the case that you were to load something large and flat inside of it that was resting on and/or impinged by the bottom and top grids?
Offline SRSemenza
« Reply #82 on: March 04, 2021, 04:40 PM »
     Yes.
Offline mino
« Reply #83 on: March 04, 2021, 05:09 PM »
I am pretty sure Tanos engineers did not look at "minimum material" even for a minute. Not at the prices they sell these things.
They most likely looked at an optimal combination maximum usability/practicality and maximum space efficiency. In that order. Once they had the shape to provide those, the thickness of the walls was a question of good durability at acceptable weight.
If Tanos is known for anything, it is they do not choose shapes that are easy to mold. They specialize in "crazily" complicated molds to provide otherwise unavailable capabilities at premium prices.
To the topic.
Pure vertical boxes are a PITA to insert as you must fit them exactly into the hole and cannot take advantage of the self-guiding property of a tapered shape.
If you want to increase usable volume, you may try to create a vertical "colar" up to 1/2 the height or so and taper only the bottom. But one thing you do not want for practical use is a pure vertical shape bottom-to-top.
Offline simnick
« Reply #84 on: March 04, 2021, 05:11 PM »
     Yes.
The bin's exterior is 68mm high.
But the squares on the bottom of the organizer stick up 5mm, and the retaining squares on the lid stick down 2.5mm
Doing the math, you should be able to stick a large item 60.5mm tall inside the organizer.
I can only tell from inference, because it is really hard to measure the container when it is closed!
Offline simnick
« Reply #85 on: March 04, 2021, 05:19 PM »
To the topic.
I'm pretty sure Bott designed them, but I wasn't implying they were cheap. They were likely looking for the best strength to weight to functionality balance, within the constraints of injection molding, which is very different than FDM/3d printing. They didn't find that adding more to the base helped for their design criteria.
BK Makes has added new sizes, including half sizes, to the Bott design. The foot design originally was designed for minimum of 50mm. I'm suggesting that the foot design might be different when there are 25mm sized containers, and when you need to print supports anyways.
Offline mino
« Reply #86 on: March 04, 2021, 05:29 PM »
To each his own.
I do not want to see (pure) vertical boxes anywhere near my small parts storage. Had them and happy got rid of them. What a waste of PET filament it was.
Ref. Bott, I think you are overestimating their influence on the detailed design. They sure did a collaborative design with Tanos that was supposed to combine their markets. But it was Bott who subcontracted the making of the box system to Tanos, not the other way around.
The system uses a module of 25x25 instead of 50x50 which is great. Maybe it will end up a future-proofed item that will be just a boon for tuners like us here but who knows.
 [cool]
« Reply #87 on: March 04, 2021, 07:39 PM »
Maybe this will help Seth...
Outside dimensions:
From the top wall to the flat bottom of the container is 64 mm.
From the top wall to the bottom of the feet on the container is 68 mm.
Inside dimensions:
The inside of the container has a blended radius that connects the side to the bottom. Thus there are 2 inside height dimensions.
From the top wall to the beginning of the radius is 59 mm.
From the top wall to the bottom of the radius is 61.5 mm. Forgot to take a photo [doh]
Offline Bob D.
« Reply #88 on: March 04, 2021, 09:24 PM »
"....Pure vertical boxes are a PITA to insert...."
Vertical sides on a molded piece are more difficult and costly to manufacture.
The slope of the sides of the bins makes releasing them from the mold much easier.
Offline SRSemenza
« Reply #89 on: March 04, 2021, 11:42 PM »
Thanks for the bin measuring.  [thumbs up]
