Author Topic: SORT-SYS1TL DOMINO  (Read 2800 times)
Online RustE
SORT-SYS1TL DOMINO
« on: July 14, 2019, 11:01 AM »
Festool Item No. 203176.
Festool Systainer I T-Loc with three divided bins for storing dominos.
https://www.festool.com/accessory/203176---sort-sys1tl-domino
Does anyone know if this is available for purchase in the United States?
Offline rmhinden
Re: SORT-SYS1TL DOMINO
« Reply #1 on: July 14, 2019, 11:19 AM »
I couldn't find that, but did find a sys2 version:
Festool 498889 Domino Tenon Systainer
https://www.amazon.com/dp/B00766V40Q/ref=cm_sw_em_r_mt_dp_U_5A0kDb043T5Q8
It's available from a lot of places.
Bob
Offline TinyShop
« Reply #2 on: July 14, 2019, 03:29 PM »
FWIW the storage trays are available as a separate item (Part# 700715) - with one divider included per tray (extra dividers can be had via Part# 700716). IOW if you have a spare T-Loc SYS 1 (or SYS 2) you could put together your own version of a "203176". The only thing you'd be missing is the polystyrene lid insert (which keeps the contents in their respective bins in the event of an upset). A regular soft foam lid insert (Tanos 81200004) would perform the same function.
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Online RustE
SORT-SYS1TL DOMINO
« Reply #3 on: July 14, 2019, 04:14 PM »
Interesting. I thought item no. 700715 would be too tall for the SYS 1 because it is usually advertised for the SYS 2.
Online edwarmr
« Reply #4 on: July 14, 2019, 09:55 PM »
It’s the same systainer as the one in this set. The bins are shorter than the ones that come in the normal domino systainer. It’s made for the Domino connector set.
https://www.amazon.com/Festool-203170-500-Domino-Connector/dp/B07BMYSHCD/ref=pd_lpo_sbs_469_t_0?_encoding=UTF8&psc=1&refRID=NES4TG55GBES3ZG175P6
I don’t think it’s available separately in the US.
Offline TinyShop
« Reply #5 on: July 15, 2019, 12:48 AM »
I stand corrected. Sorry for any confusion.
