Author Topic: CNC template for foam inserts  (Read 4122 times)
Offline Dusty.Tools
    • Dusty.Tools
« on: May 28, 2019, 12:42 AM »
Hi All,
Does anyone have, or have a pointer, to a CNC template to cut out Kaizen foam inserts for Systainers?
Cheers
Ben
@dusty.tools
Offline Systainer.Store
    • systainer.store
Re: CNC template for foam inserts
« Reply #1 on: May 28, 2019, 06:27 AM »
Hi Ben - you may want to check the files linked on this thread:  http://festoolownersgroup.com/festool-and-tanos-systainers/systainer-files/. It reads like it is a good start to getting you cutting templates on a CNC.
Offline MikeGE
« Reply #2 on: May 28, 2019, 07:34 AM »
For those who don't have the capability or want to cut their own Kaizen inserts, I can recommend KaizenInserts.com as a source for ready to fit inserts for the Systainer boxes.  I'm not affiliated with KaizenInserts, just a happy repeat customer.  I bought inserts for my Sortimo L-Boxx cases, and they fit perfectly.
    • systainer.store
« Reply #3 on: May 28, 2019, 08:24 AM »
I too have bought some items from KaizenInserts and though the item was good.
On InstagramI follow Loxaco and he has a shop with a couple systainer inserts.  I've got the router bit version to try and recommend it.  https://loxaco.com
-Sys Tim
Offline Dusty.Tools
    • Dusty.Tools
« Reply #4 on: May 30, 2019, 01:16 AM »
Thanks all,
Yes I am considering KaizenInserts, three of them cost about the same as a sheet that will make four. I think that's actually a pretty reasonable markup so I might go down that route.
However if I do decide to use my CNC to cut out the tool holes then I might as well cut the hole piece... we'll see :)
@dusty.tools
Offline fritter63
« Reply #5 on: June 23, 2019, 11:38 PM »
Hi All,
Cheers
Ben
I have one in Fusion 360 and IIRC I cut and tested it to. If I haven't remembered to find and post it for you in a couple days ping me so I'll remember. Tired on a Sunday already!
Offline Dusty.Tools
    • Dusty.Tools
« Reply #6 on: June 24, 2019, 12:49 AM »
Hi All,
Cheers
Ben
Fusion3D would be great. I've been meaning to switch to it :)
@dusty.tools
