I was tired of always having to search all over the place for the right bit and didn't want something fixed to a wall. So I made 3 systainers for my router bits. Just a few bits of ply shaped so that they would fit, a few strips of plastic for easy affixing labels, and a number of plastic bushings in different sizes CMT make for their router bit organizer (https://www.cmtorangetools.com/eu-en/systems-and-accessories/organizer). Those bushings fit perfectly in holes made with a 22 mm Forstner drill bit. I am quite happy with this solution. It is uncluttered, flexible, and easily accessible. Maybe not the most efficient with space, but I purposely made the gaps between the bits a bit larger so that I can grab a bit without cutting my fingers.
(Attachment Link)
(Attachment Link)
(Attachment Link)
I like this too.
I've been pondering something like this for a while. I have most of my 1/2 stuff in 2 Harbor Freight cases with a foam bit organizer in one of them (other has a bunch of rectangular open top "boxes") because it's easy to see what is what.
I can't do that with my 1/4 bits because way more are dimensional and I can't necessarily tell what is what with a quick look so my Makita router case is literally overflowing with little cases/bags.
I wanted a way to label each bit in the case.
I was thinking about the Festool "kit" but it's way too short (I can't believe they don't offer a larger one). I did order a Powermatic foam systainer insert for router bits so we'll see how that fits when I get it.
I found a medium sized systainer on clearance for $22! Currently debating whether to store my Milwaukee routers in it or use it for the router bits. I'll have to test fit when I get the foam in.
I'm also having a little trouble justifying the regular cost of the systainers (I know.....), but I have a bunch of the original Dewalt Tough Boxes that are larger and sturdier than the systainers that I paid a lot less for that I can't help comparing them to...
I've also got a bunch of the Woodpeckers square inserts (they come with the bits they sell; nice touch), was trying to think of a way to make them work with the foam. Or maybe an insert in the foam.
I have the original Festool router bit Systainer with the foam inserts and after some time the bits are very difficult to remove because the foam grabs them so tightly.
Another good reason to not get the Festool one.
That looks sexy! Very soothing to my ocd.
![Laughing [laughing]](https://www.festoolownersgroup.com/Smileys/default/laugh.gif)
The actual size of holes drilled with a drill press depend on how much total runout there is.
If it matters, it’s better to reposition the bit in the chuck a few times to find the minimum.
Also matters how you tighten the drill chuck. Best to gradually tighten with all 3 holes vs just tightening one.
