Author Topic: Show your systainer  (Read 49141 times)
Offline Coen
Re: Show your systainer
« Reply #120 on: February 11, 2021, 10:44 AM »
Finished my T-Loc Sys II DF for the PS-300 with the accessories. In the top lid are some blades and the splinter guards, as seen here;
https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/diy-jigsaw-blade-storage/msg631774/#msg631774
On the inside of the main lid is the circle jig and the guiderail adapter. In all the years I owned the Trion I never missed the parallel guide for it, so that's the only thing that isn't there.
Most things fixed in place with adhesive hook and loop. When closed it's front-heavy though, but if I didn't place the boxes of  blades in the front it would easily tip over when opened.
Offline Imemiter
« Reply #121 on: February 11, 2021, 12:28 PM »
Fun thread!
This is the box that often keeps my Festool drills from coming along to work.
CSX T18+3 TID18 HKC55 OSC18 OS400 OF1010 LR32 DF700 RAS115 DTS400 ETC125 CTSys CTMidi CT-VA
Offline ghhsolutions
« Reply #122 on: February 11, 2021, 01:16 PM »
A bit of a dormant thread but a good place to make my first post. After buying my first Festool power tool last year (DF500) I was dismayed to find it came in an addictive covering, otherwise known as a Systainer. Most of my power tools are DeWalt stored in TSTAK cases but I am gradually changing to Systainers as I prefer the greater range of sizes and options. I just thought I would share some of my favourite transfers so far, nothing groundbreaking but might be of interest to someone.
This is my DF500 transferred to a SYS-COMBI 3. As this is the only tool that doesn't have a DeWalt AirLock connector it has its own extractor  hose:
327494-0
JIgsaw and multitool in a SysCombi 2. This is TSTAK foam that just needed a bit of trimming to fit in a Systainer:
327496-1
Planer in a T-Loc 3:
327498-2
SYS-MFT top transferred to a T-Loc 2 base with the bins that are used in the domino kit. I will probably add some foam to hold the dogs upright. :
327500-3
Trend Pocket Hole Jig Pro in a Sys-Mini 3:
327502-4
Offline Jeff Zanin
« Reply #123 on: February 11, 2021, 02:03 PM »
This is a great thread, as usual I am late.  I don't have a name for this but I think of it as my "mini-stack" which rolls around as I attend to various projects.  It is a mix of M12, hand tools, a small assortment of screws, some basic measuring & marking, testing, & layout.  The top section has a laser level and tripod.
Offline SRSemenza
« Reply #124 on: February 11, 2021, 02:39 PM »
Nice set ups. Love to see this stuff  [thumbs up]
Offline Imemiter
« Reply #125 on: February 11, 2021, 04:13 PM »
Here's another Systainer with a trim router.
Offline Agent 73
« Reply #126 on: February 11, 2021, 07:56 PM »
My Systainer tool box 2.
« Last Edit: February 11, 2021, 08:03 PM by Agent 73 »
Offline gunnyr
    • Compass Custom Creations
« Reply #127 on: February 11, 2021, 09:04 PM »
I moved my Domino into a Combi-3 so I can keep all accessories together.  The advantage of the Kaisen Foam is that it is easy to see if anything is missing.  I keep all required tools with the accessories so I don't have to go looking for them (3 and 5mm hex keys in this case).
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
« Reply #128 on: February 12, 2021, 04:32 AM »
Nice dividers. A step up from the usual bits of old pipe!
Offline Rumblefish
« Reply #129 on: March 07, 2021, 12:02 PM »
Nice. After using a T Loc Systainer 3 Setup with office supply boxes I found accessibility to be a thing to improve. The Sys Sorts with drawers were a pricy but perfect option. Additionaly I customized my Systainer T Loc 3 into a 12V powertool box. So I have a complete Toolbox Solution. Pretty handy and I am happy with that.
Offline Coen
« Reply #130 on: March 07, 2021, 01:06 PM »
Wago's!  [big grin]
Offline Rumblefish
« Reply #131 on: March 07, 2021, 01:27 PM »
Wago's!  [big grin]
Shure. What else? ;-)
Offline Coen
« Reply #132 on: March 07, 2021, 04:29 PM »
Wago's!  [big grin]
Yeah no idea. They are superior to everything else. I tend to cut away a lot of screw terminals in favor of Wago 221 and Wago 224. Also when adding earthing to existing home circuits the new Wago 2273's are very nice. Even with the additional conductor you use less space in the junction boxes.
Offline Bob D.
« Reply #133 on: March 07, 2021, 09:14 PM »
Yeah I like Wagos too. Great for those light fixtures with stranded wire. Makes it easy to join the smaller gauge stranded wire to a #12 solid. I keep a bunch in my electrical pouch and a good stock on the shelf. If you buy off Amazon make sure you get the real deal and not the knockoff ones as they are not UL listed.
Offline Imemiter
« Reply #134 on: May 09, 2021, 11:12 AM »
Another Makita in a Systainer. I'll review in another week or so.
Offline Bob D.
« Reply #135 on: May 09, 2021, 12:16 PM »
Is that a Sys II or III ? I want to do the same for my DeWalt cordless router.
If only there was a Festool cordless router.  :(
Offline Bob D.
« Reply #136 on: May 09, 2021, 12:36 PM »
Here are a couple Systainers I have made up for some of my other tools.
Sys4 for the DeWalt track saw
Sys3 for the RIDGID JobMax
Sys2 for the RIDGID 1/4" Impact Driver and 1/2" Hammer Drill/Driver
I'm working on Systainers for the DeWalt cordless Cable Stapler and DeWalt cordless Router with plunge base.
« Last Edit: May 09, 2021, 04:11 PM by Bob D. »
Offline Eric J
« Reply #137 on: May 09, 2021, 01:54 PM »
This is my portable "measuring stuff" Systainer:
331321-0
Offline Imemiter
« Reply #138 on: May 09, 2021, 03:10 PM »
It's an Anthracite Sys lll from Woodcrafters. I tried a Sys ll but it stacked too high.
Offline Vondawg
« Reply #139 on: May 10, 2021, 06:14 PM »
Ok I’ll play…this goes in on every job…toolbox drawer is very handy when in the stack
Offline Vondawg
« Reply #140 on: May 10, 2021, 06:19 PM »
Drill and drive box with stolen ideas…my favorite from Seths bit holders….and you gotta have a bottle opener…lol
Offline SRSemenza
« Reply #141 on: May 10, 2021, 11:14 PM »
How about some details on the end drawer. And what is the black lever looking thing sticking out of the next one down?
Offline Vondawg
« Reply #142 on: May 11, 2021, 11:33 AM »
Sure…end of the toolbox is cut out and the drawer is made to fit snug between sides w/runners on top to hold the drawer…it can be 90% out/open position without tipping or falling out. When closed (and held in, with a scratch awl, from a combination square) the toolbox can be used normally….the other is just a bracket to hold my pin   nailer. And thanks for all your tips Seth, thru the years.
Offline Vondawg
« Reply #143 on: May 11, 2021, 11:34 AM »
Oops…and the drawer front is thin cutting board material…matches the gray pretty good
« Last Edit: May 11, 2021, 11:37 AM by Vondawg »
Offline aurels
« Reply #144 on: May 26, 2021, 02:29 AM »
Here is a custom insert I made out of scraps to secure two sanders into a single systainer ;-)
331854-0
Offline dupe
« Reply #145 on: September 10, 2021, 11:40 AM »
I’m a hobbyist and over the years dropped quite a bit into storage systems from Bosch, Makita, and a few Dewalts. I kept coming back to Systainers and wish I would’ve taken this route from beginning. This is my next attempt to organize multiple tools by type. Organization wise it makes sense, but in terms of deployment or field work I’m still not quite sold. I still need to find that balance of shop stored tools and working mobile. Not pictured is what I consider my EDC –  a SYS-Sort with marking tools, utility/putty knives, scrapers, and PPE. A SYS-TB2 for pullsaw, hammer/mallets, and prying tools. I recently got back into 3D printing and just beginning to scratch the surface implementing what others have designed while remixing items for personal use.
Sanding
Printed RO150 Hanger - Remixed from Thingiverse Kerndrup
Drills/drivers with electricians pouch on printed ToughBuilt Clip - Remixed from Ben Johnson
MFT.1080    CT.Midi    DF.500    DTS.400    ETS.EC150/3    RO.150    RO.90    CXS 10.8    RAS.115
Offline dupe
« Reply #146 on: September 10, 2021, 11:43 AM »
Nailers - SYS-Combi with Attic lid
Finish sanding
150 Abrasives
Cutting - printed clips for recip blade case
Mess of clamps - Clamp rack by Amantea
Lasers
This has been a very useful thread in formulating ideas to become better organized. Thanks to the contributors. Happy to share .stl files for printing or Illustrator files for labels.
Offline squall_line
« Reply #147 on: September 10, 2021, 12:17 PM »
@dupe , I love your use of drawers for the CSX and nailers!
