Author Topic: Show your systainer  (Read 39764 times)
Offline zapdafish
Re: Show your systainer
« Reply #60 on: January 18, 2019, 04:54 PM »
ditto, would be interested in it for a sys 1 or maybe a sys 2
I liked the router insert as well.  If we could get in SketchUp or Fusion 360, which I would pay for.  Then I could make my own with my Shaper Origin.  [smile]
Offline Systainer.Store
    • systainer.store
« Reply #61 on: January 19, 2019, 08:40 AM »
What an awesome thread of possibilities with systainers!  OK - I need to get into the workshop and seriously work on my organization.
Offline Trucks192
« Reply #62 on: January 19, 2019, 04:30 PM »
I use systainers for almost all of my tools. Here are a few of the ones that I have setup with kaizen foam
Offline Trucks192
« Reply #63 on: January 19, 2019, 04:34 PM »
Offline Trucks192
« Reply #64 on: January 19, 2019, 04:38 PM »
My Dewalt 20volt drill & impact in a Systainer 2 with drawer and lid sort. I set this one up a few years ago and it is used every day so it shows.
Offline Trucks192
« Reply #65 on: January 19, 2019, 04:45 PM »
All of my small hand tools are kept in three sortainer SYS 4s. This one is my everyday tools and has ALOT crammed into it. I have tried to organize it better but can never fit as much in it so I just pile everything in. I know where each tool is, it is just a matter on moving stuff that is on top of it.
I keep this box and my drill kit in the last photos where I can get to them from the sliding door of my van without getting in the van. They are actually on a cart/mobile workbench that I will take inside with me on some jobs.
The other 2 sortainer SYS 4s have my less used tools and are kept up on the shelves inside the van.
Offline Trucks192
« Reply #66 on: January 19, 2019, 04:52 PM »
This last one I'm looking for suggestions on. I have my Dewalt 20volt 16 gauge and 18 gauge nailers in a systainer (I think it is a sys4 but might be a sys5?). I wanted to build a plywood caddy/insert for them but the lid just barely closes now with the slim batteries in the guns.
Does anyone have a good dewalt nailer setup with both guns, charger, spare batteries, and nails in one systainer? I have tied a few ways of putting them in and his was the only way I got both to fit and it is tight height wise.
Offline tjskinny
« Reply #67 on: January 19, 2019, 04:54 PM »
New year orginizing - Borrowing insert designs from Peter Parffit and using some leftover material:
291190-0
291192-1
Using a Lee Valley pliers orginizer and cutting it:
http://www.leevalley.com/us/Wood/page.aspx?p=75474&cat=1,43326
291194-2
Offline Trucks192
« Reply #68 on: January 19, 2019, 04:57 PM »
Quick shot of the inside on my van with most of my systainers. It is still a work in progress but I'm almost done. I did start a thread on this built awhile back, I need to get some time to get good photos of the almost finished build and update that thread.
Offline Coen
« Reply #69 on: January 20, 2019, 12:21 PM »
How do you prevent them from sliding out if you take a fast corner??
Offline Trucks192
« Reply #70 on: January 20, 2019, 12:30 PM »
There is a stop block so the shelves don't slide out and there are recesses in the shelves for the feet of the systainers. So far none have fallen out.
Offline George Oliver
« Reply #71 on: January 23, 2019, 01:31 AM »
Nice van build Trucks. I also have my drill/impact in a combi sys 2, without the storage lid though. I had my doubts about its durability but it's held up surprisingly well, knock on wood, and I think it's a big improvement on the old Husky cantilever box I was using.
Offline Tooms
« Reply #72 on: January 25, 2019, 03:53 PM »
Fluke CNX 3000 kit
Offline Kevin C.
« Reply #73 on: January 25, 2019, 11:22 PM »
[attachim[attach=4]291680-1291682-2291672-3291674-4291676-5291684-6g=1]
Offline Tooms
« Reply #74 on: January 26, 2019, 10:19 AM »
2 old Fluke scopemeter 199C and 196B
« Reply #75 on: January 26, 2019, 11:46 AM »
Fluke CNX 3000 kit
I like the yellow handle and yellow T-LOC...easy to pick out the Fluke packages from a distance.
I also use different color T-LOC's to differentiate between gear from across the room. Easier than squinting at labels.  [smile]
Offline Tooms
« Reply #76 on: January 27, 2019, 03:21 AM »
Fluke CNX 3000 kit
at first i was thinking of yellow case with dark handle and tloc, but i think it is alot better with the dark case and then just have the color on the handle and tloc
for the label i try to make the big and clear in design, so the are easyer to read
Online fyme
« Reply #77 on: January 29, 2019, 02:47 PM »
Next project completed.
 Makita router accessories
Offline coho10
« Reply #78 on: February 04, 2019, 09:39 AM »
a few more of mine
Not sure why images are coming up sideways....sorry.
Offline Coen
« Reply #79 on: February 06, 2019, 11:38 PM »
a few more of mine
Because of different standards. Some software ignores that one bit that says "rotate". If you then manually rotate it and then feed it to some other software that does recognize that rotate-bit... it will show wrong again.
Offline Bartel
« Reply #80 on: February 07, 2019, 12:14 PM »
My Bosch 10.8/12v ‘sawcollection’ in a Sys 3 Classic
« Last Edit: February 09, 2019, 03:22 AM by Bartel »
Offline Mario Turcot
« Reply #81 on: February 12, 2019, 08:42 AM »
@coho10 the last photo where you have the ridgid trimmer is using a Sys 1?
I also had that orientation problem. I'm using an iPhone and disable the flip rotation on it. Since, all my pictures comes in the right orientation.
Mario
Offline coho10
« Reply #82 on: February 12, 2019, 10:58 AM »
Mario, It's a sys 2. I wanted to leave a larger base attached, otherwise it would fit in a sys 1.
« Reply #83 on: February 12, 2019, 11:03 AM »
Thank you! I have the same trimmer and you gave me the idea of have it in a systainer with all the accessories. I actually use the bag that was coming with the router and it became hard to fit everything in it.  [eek]
Mario
« Reply #84 on: February 12, 2019, 12:34 PM »
@Bartel   Your Bosch kit looks great! The jigsaw seems to be much smaller than I thought, so now it’s tempting. Does it work well? Are the 10.8 and 12 batteries interchangeable?
Offline Mortiser
« Reply #85 on: February 12, 2019, 12:50 PM »
Does someone know if the lids for the Sys-Storage Box will fit the Sys-Toolbox 2 ?
http://www.leevalley.com/us/Festool/page.aspx?p=70732&cat=5,105,71886
Offline SRSemenza
« Reply #86 on: February 12, 2019, 01:50 PM »
The clear lids? Not sure of the physical size would fit , it might,  I have both and can check when I go to the shop. But you would need to come up with some type of hinge / attachment even if they would fit. But that could be worth exploring for added versatility. Though if you really needed larger closed space , a regular Systainer can do that job.
Offline Christopher Fitch
« Reply #87 on: February 12, 2019, 03:19 PM »
Here's mine...just one - mini-systainer
Offline SRSemenza
« Reply #88 on: February 12, 2019, 03:28 PM »
Cool, good thing it is a flex head ratchet.
« Reply #89 on: February 12, 2019, 03:52 PM »
Yes... it was a small struggle but I really like my flex head. I find myself using it a bunch.
