Author Topic: Show your systainer  (Read 39769 times)
Offline Mortiser
Re: Show your systainer
« Reply #30 on: January 10, 2019, 10:05 AM »
I upgraded from a 5 gal bucket to a SYS-ToolBox SYS-TB-2, the great thing about it is that it stacks with the rest of my tools and is easy to move around the job site on the top of my Sys-Roll.
(Attachment Link)
Jeff, who makes the leather tool pouch pictured there?
Offline PeterJJames13
« Reply #31 on: January 10, 2019, 10:10 AM »
Just by the stitching, I'm guessing Occidental Leather. I'm curious too.
Offline fyme
« Reply #32 on: January 10, 2019, 11:44 AM »
@fyme the saw blade storage is genius. How did you mount the knobs? Is it just inserts on a backing plate?
Under the insert is a plywood to which I attached m8 nuts  [smile]
« Last Edit: January 10, 2019, 11:47 AM by fyme »
Offline gunnyr
    • Compass Custom Creations
« Reply #33 on: January 10, 2019, 12:35 PM »
@Mortiser, @PeterJJames13 is correct!  It is an Occidental 5057 Pocket Caddy.  I got it from Amazon.  The neat thing about it is that it has a snap so you can put it on your belt without removing your belt OR you can slide the back flap of the pouch in your back pocket for the quick jobs.
« Last Edit: January 10, 2019, 08:46 PM by gunnyr »
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline Tooms
« Reply #34 on: January 10, 2019, 12:56 PM »
Not my video but just got the link, that is another way to use systainer
"A little bit of rhythm makes Systainers go round"
https://www.instagram.com/p/BsTUu98FoKd/
« Last Edit: January 10, 2019, 01:00 PM by Tooms »
« Reply #35 on: January 10, 2019, 01:50 PM »
@Mortiser, @PeterJJames13 is correct!  It is an Occidental 5057 Pocket Caddy.  I got it from Amazon.  The neat thing about it is that it has a snap so you can put it on your belt without removing you belt OR you can slide the back flap of the pouch in your back pocket for the quick jobs.
Lucky guess, lol. Though they always have their own distinct look. Great quality on them too.
Offline Tooms
« Reply #36 on: January 12, 2019, 08:38 AM »
Starmix meets systainer
Offline Tooms
« Reply #37 on: January 12, 2019, 08:39 AM »
Starmix meets CA-VA
Offline Curt Boyer
« Reply #38 on: January 12, 2019, 08:39 PM »
Here is my drill Systainer which also has some often used miscellaneous items.
Cheers
Curt
Offline The.Handyman
« Reply #39 on: January 13, 2019, 12:04 AM »
Festool ti 15 foam insert modified
Sent from my SM-G960U using Tapatalk
Offline zapdafish
« Reply #40 on: January 14, 2019, 01:11 AM »
jessem dowwel jig
Offline Ordewin
« Reply #41 on: January 14, 2019, 03:13 AM »
What I did with the maxi for my CMS set up and standard sys for the dogs etc
Offline Ordewin
« Reply #42 on: January 14, 2019, 03:24 AM »
Modified sys 3 with drawer holding both of my centrotec sets and the drawer has the aftermarket snappy and Fisch bits etc
Offline BrianSometimes
« Reply #43 on: January 14, 2019, 03:13 PM »
Wanted to organize my little apartment toolbox and glued an elastic band around the edge to allow for storage other than "chuck it into one of the two compartments". It's more flexible than custom plywood inserts if not nearly as attractive, does the job, though. This approach would work better in the black Tanos version of the toolbox.
290789-0290791-1
« Reply #44 on: January 14, 2019, 03:26 PM »
I like the elastic band approach.  [smile]
Did you use hot melt?
Offline Coen
« Reply #45 on: January 14, 2019, 03:26 PM »
That looks super nice. Did you do the cutouts in the yourself or did you order it custom made?
I wondered if the CMS OF stuff could fit in a Systainer Midi, but I guess not. How space do you have left over on the sides of the biggest part? I transported my CMS OF stuff in a banana box recently... and I didn't like that.
Did you use the Tanos foam?
« Reply #46 on: January 14, 2019, 03:41 PM »
Quote
Universal super glue gel.
Offline Ordewin
« Reply #47 on: January 14, 2019, 05:54 PM »
I used Kaizen foam in all three Systainers. All of the SYS OF will fit in a Maxi only, you need to separate the fence which is dead easy to do and you need to break down the guard as well, that take a minute or so to put together but it has reall saved damaging the kit or losing parts when you are on a job
Offline c_dwyer
« Reply #48 on: January 14, 2019, 06:05 PM »
Offline Tooms
« Reply #49 on: January 15, 2019, 03:19 PM »
Two old bosch sander
Offline lerabotperche
    • What I do and how I do it :)
« Reply #50 on: January 15, 2019, 04:07 PM »
(Attachment Link)
Mine is still in progress but thank you for sharing yours, it helped !
Offline Tooms
« Reply #51 on: January 15, 2019, 04:33 PM »
Heat gun and Heat-shrink tubing
Offline Tooms
« Reply #52 on: January 16, 2019, 02:27 PM »
Well packed systainer 5 with 3M versaflo helmet and speedglas 9100xxi
Offline ryanjg117
« Reply #53 on: January 17, 2019, 11:57 PM »
Sharpening station in a SYS4:
Offline ryanjg117
« Reply #54 on: January 17, 2019, 11:59 PM »
Router bit organizer in a SYS3 (my failed attempt at commercialization):
Online Bob D.
« Reply #55 on: January 18, 2019, 05:12 AM »
There is nothing wrong with your router bit organizer as far as I am concerned. I wanted one. Only problem was there weren't enough people interested to make it economical to produce by CNC as I remember.
There was no fail on your part is my point, and I don't think of it in that way. It is a well thought out design that makes excellent use of space available and is expandable to whatever Systainer you wish to use.
Maybe in place using CNC the pieces could be cast in plastic. Think about selling the idea to Rockler or FastCap or someone else. Take the money and spin it into your next great idea. I have no doubt you have a few more you are wanting to try.
Offline Mat Provost
  • Festool Dealer
  • Festool Dealer
    • Burns Power Tools
« Reply #56 on: January 18, 2019, 09:29 AM »
Hello,
Here is my new blue Systainer which holds paper for my RS2 sander.
Need some proper dividers.
It may be my imagination but I seem to get a better finish with paper from the blue systainer.
Hey Brian,
It's not your imagination, it's Science. Hope you're staying warm up there.
Burns Power Tools
Authorized Festool Dealer since 2003
Home of the SuperSharp Premium Blade Sharpening Service
www.burnstools.com
Offline Jimdude
« Reply #57 on: January 18, 2019, 11:02 AM »
Yesyes wrong shade of green, I know:
150mm paper to the left, 125mm paper to the right (*). Which doesn't match the label, I see know (I'll have to burn it down and start again).
(*) this row has a bumped up bottom, otherwise the paper fell down too far
« Reply #58 on: January 18, 2019, 01:59 PM »
I'll echo Bob's thoughts, it was & still is a great idea.  [smile]  I was actually  [sad]  when you returned my down payment.
Offline ghjaxman
« Reply #59 on: January 18, 2019, 02:42 PM »
I liked the router insert as well.  If we could get in SketchUp or Fusion 360, which I would pay for.  Then I could make my own with my Shaper Origin.  [smile]
