Author Topic: Systainer internal cardboard guides  (Read 591 times)
Offline sanjay
« on: May 12, 2021, 11:55 AM »
Does anyone know if the cardboard guides on the inside of the lids can be bought separately and where from?  Or if the images can be got from somewhere to print out?
Offline Alanbach
Re: Systainer internal cardboard guides
« Reply #1 on: May 12, 2021, 12:54 PM »
Yes, call Festool USA in Indiana. If the particular item is still produced / stocked they should have it. You will probably also need the little white plastic rivets that hold the placard in place and they will have those as well. If their printer is working at the time they can even supply you with the appropriate stickers for the two spots on the outside of the Systainer, to identify the contents.
