Author Topic: New T-Loc Systainer Labels  (Read 6924 times)
Offline Trucks192
« on: September 18, 2016, 05:40 PM »
I finally came up with a different form of label for the systainer t-locs. My stickers go on the actual catch instead of the standard label area. These were a long time in the making and I have been through several versions. My latest version is printed on a vinyl sticker and then covered with doming resin to make a 3D sticker that is also durable. I have finally created labels for all of my Systainers both festool and tanos with several brands of tools in them.
What do you guys think? I wanted something quick and easy to identify but also different then what others were doing.
Offline blaszcsj
Re: New T-Loc Systainer Labels
« Reply #1 on: September 18, 2016, 05:58 PM »
Those are really great! Nice and visible!
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline neilc
« Reply #2 on: September 19, 2016, 12:06 AM »
Nice labels.  But for readability, blue on green requires too much thinking!  Even the pictures require your brain to work.  They look great, but I went down the path of image-based labels and gave up...
Personally, I use clear tape in a P-touch label maker and make 1" black letter size to stick on the Green latches.  TS-55 in 1" letters across the room is really clear!   Carvex is readable from 20 feet away!
It's the BEST and most visible solution I have come up with for identifying a tool quickly.  The image labels are nice, but I have found that I have to get so close to them that they don't help me to easily find the tool.
YMMV!  Particularly if you have better eyes than me!
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #3 on: September 19, 2016, 03:40 AM »
Very Clever!
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
« Reply #4 on: September 19, 2016, 01:57 PM »
Same here, I found myself squinting and trying to make out the image on the label. I switched to different colored T-lok latches. Easy to recognize from 30 ft away. Any Systainer with a black latch is associated with the DF 500. White latches denote routers, yellow latches are 125 mm sanders/paper...
Offline RockstarRemodel
    • Rockstar Remodel
« Reply #5 on: September 19, 2016, 05:44 PM »
I love this idea. I've been thinking of replacing all my latches with anthricate just to look cooler, but having them color coded per tool type is great... oh money, how you never stay in my wallet...
Keep Rocking
Brendan with RockstarRemodel.com
« Reply #6 on: September 19, 2016, 06:08 PM »
Here's a shot of some, as I said you can identify them from across the room.
« Last Edit: January 27, 2018, 03:11 PM by Cheese »
Offline Sinbad1958
« Reply #7 on: January 27, 2018, 02:43 PM »
how do you do these
Offline Trucks192
« Reply #8 on: January 28, 2018, 07:25 PM »
how do you do these
I have a template of the latch shape in a vector art program on my computer. Once I design the latch I can print them and cut them out with my die cut machine.  They are then covered in a resin to make them 3d
