Author Topic: New Mafell Sys Workbench  (Read 11305 times)
Offline tazprime38
« on: October 16, 2018, 04:45 PM »
Saw this at the DM Tool Show. It is a sys top workbench cutting centre that attaches to any systainer and is also stored inside a sys1 t loc.
Expensive at around £309.00
Offline Bert Vanderveen
Re: New Mafell Sys Workbench
« Reply #1 on: October 16, 2018, 05:37 PM »
That's a rebranded product. Made by Ruwi (Germany):
https://ruwi.de/en/produkte/festool-mft3-surface/
Manor Wood over on YT is a user and fan of their MFT/3 add ons
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950
Offline wheely
« Reply #2 on: October 16, 2018, 06:47 PM »
The Mafell is a slight tweak from the standard RUWI product though as the arms are hinged so they go inside the Systainer.
https://shop.ruwi.de/produkt/systainer-flaechenadapter-set/
The Mafell systainer is the MA-730, and comes with two arms, four clamps and the systainer
https://www.its.co.uk/pd/MA-730-MaxxTloc-Workstation-with-Foldaway-Arms-_MAFMA730.htm
https://www.machinery4wood.co.uk/product.php/sn/MAF%2F91B%20201
Offline Svar
« Reply #3 on: October 16, 2018, 07:43 PM »
Miniature saw horses for $350. No, thanks.
All standard framing components made by 80/20 and Bosch Rexroth: aluminum profile, hinge, end caps, brackets, T-nuts. BTW that plastic hinge has aluminum version.
« Last Edit: October 16, 2018, 07:53 PM by Svar »
Offline Farming_Sawyer
  • Sawyer, builder, winemaker, farmer, chef
    • Foley's Custom Sawmill
« Reply #4 on: October 17, 2018, 06:41 AM »
I really like the sys-mft systainer. Works great as a temporary jobsite work surface, perfect height as an off feed table when combined with my other systainers. Temporary step. Store my clamps and dogs in it. Inexpensive. I'd get four before buying something like the above.....
CT 26E, RO125, sys-mft, sys-toolbox, a bunch of 30 year old tools I'm looking to replace.
« Reply #5 on: October 18, 2018, 11:05 AM »
That's a pretty slick idea. If you subtract the price of a Sys 1 from the package the rest of the included items seem to be a little more reasonably priced.
What I don't get is why didn't they just attach the ply top directly to the Systainer like the Festool SYS-MFT? Even though the rest of the gear stows away nicely in a Sys 1, you still have the ply/steel top thing to lug around separately.  [eek]
I just may make my own version using some 80/20 items and a SYS-MFT. [smile]
« Last Edit: October 18, 2018, 11:28 AM by Cheese »
Offline jobsworth
  • Festool Baby.....
« Reply #6 on: October 18, 2018, 11:36 AM »
 If we use the Lee Valley standoffs we can do basically the same thing.
Offline bror
    • diafer.nl
« Reply #7 on: October 18, 2018, 04:33 PM »
I really don’t get this. What’s the point.? what’s it for?
Cutting up really big sheets of material with a track saw on an unstable pile of systainers.?
That seems a life threatenig stunt excercise to me..
It looks to be adjustable in many ways,  none of which I can really see the use of.
What is the advantage over a pair of simple saw horses with your systainers containing your tools ready and accessable
Certainly not the price
The only good thing I can see that it can be stacked inside a systainer, than it’s not in the way.
I think the metal mounting plate is completely over the top. And a one trick pony.
I think it is over designed, overrated and overpriced.
But tazprime38: great foto report and thanks for the scoop.
Offline ben_r_
« Reply #8 on: November 09, 2018, 08:18 AM »
100% agree!
Offline tallgrass
« Reply #9 on: November 11, 2018, 01:46 AM »
I use and love the RUWI products with my festool stuff.  think this is just another way of maximizing the systainer. May be a bridge to far. Maybe for a niche application. There does seem to be a need out there for maximizing the minimum foot print. Not my cup of tea, but it is a choice.
« Last Edit: November 11, 2018, 07:37 PM by tallgrass »
« Reply #10 on: November 11, 2018, 10:00 AM »
I still think this item has a niche to fill. It was never designed to hold a 4 x 8 sheet of plywood. It's just another way to get the item you're working on closer to waist level, albeit a fairly expensive way. For small items it's certainly easier to work with this than kneeling on a stone patio. I also think it works well for use with a jig saw. Just another option available, you can purchase it or not.
Offline jonathan-m
« Reply #11 on: November 11, 2018, 12:13 PM »
Hmmm, the metal plate is obviously to raise the wood plate up, so you can still put your hand inside the handle cutout to carry the systainer.
It's obviously not designed for sheet goods, but rather aimed more towards smaller workpieces.
I think it looks like a very useful piece of kit for certain applications for people who need to be mobile. That's why it is also designed to fit inside the systainer format.
Just because you don't see a use case doesn't mean there isn't one.
I don't get the hostility. Maybe the systainer has the wrong color latch and label for you? If you don't like the product just don't buy it...
Festool: 2x MFT/3 // OF-1400 // MFS-400 & 700 // RO-90 // SYS-ROLL // VAC-SYS SET SE1 // CT-ASA CT 26/36/SB // KS 120 EB & UG-L & R //  VECTURO OS 400 EQ-Set  // DSG-AG 125 // DSC-AG 125 // DSC-AG 125 FH // HK 85 EB // HK 55 EB
Protool: 2x VCP 260 LE AC // PDP 20-2 // WCP-32
Mafell: MT55cc // P1cc // DD40P // Erika 85 Ec
Offline Vondawg
« Reply #12 on: November 12, 2018, 06:14 PM »
Isn’t the FOG  for disciussing these kind of things ? So unless you like this or that just shut up ?? No need to get your “ you know whats “ in a bind, it’s just a healthy conversation. I like everybody’s different opinions on the stuff that’s being done, the tools we do them with, and how different members accomplish and work thru an idea. Not to mention how someone works in another country. So thanks for all the different observations !
Offline SRSemenza
« Reply #13 on: November 12, 2018, 06:41 PM »
Observations , discussion, and opinions are welcome.
Offline Scorpion
« Reply #14 on: November 13, 2018, 12:59 AM »
No reason why you couldn’t use a coupe of them and spread them out to handle larger sheets.  I like the idea as long as the systainers can be stable enough.  Last thing I’d want is to have a sheet too over a stack while cutting with the trac saw.
Offline Svar
« Reply #15 on: November 13, 2018, 05:32 PM »
So now we are up to $700 for something that is better handled by $20 saw horses?
The question here is of practicality and value.
What are the chances you'll have bunch of Systainers handy on site to build two stacks of equal height?
Then you need to un-stack your "bench" every time you reach for a tool. And I'm sure the one you need will be in the bottom sys.  [big grin]
This is also a case of extreme over-engineering. Extrusions are cool, but do you need superior rigidity, straightness, and wear resistant coating for what is essentially a disposable spacer for cutting? SYS-MFT is good enough for a quick cut, keep it simple.
For stability they should offer titanium extension feet for your systainer stack.
« Last Edit: November 13, 2018, 05:44 PM by Svar »
« Reply #16 on: November 13, 2018, 11:46 PM »
Oh boy...so now we’re castigating the clever use of expensive saw horses while at the same time still extolling the virtues of a $600 track saw that could be easily replaced with a straight 2x4, a clamp and a $40 side winder.
Offline Svar
« Reply #17 on: November 14, 2018, 12:16 AM »
Because one is a game changer and the other is a gimmick.
« Last Edit: November 14, 2018, 12:45 AM by Svar »
Offline siltsunrise
« Reply #18 on: December 05, 2018, 04:54 AM »
Nifty, but hope you've got some sandbags in your bottom container. Looks tippy. Cool for a guy who wants to pack it all up small, but crazy overpriced.
« Last Edit: December 05, 2018, 04:57 AM by siltsunrise »
Offline Jaybolishes
« Reply #19 on: December 05, 2018, 07:35 AM »
Kinda fits into the golden toilet scenario.  Not everyone will get it but the guys that do really must enjoy doing business on it apparently. 😁
Offline Deane62
« Reply #20 on: December 05, 2018, 09:45 AM »
To me price is irrelevant.  It's either a good tool or not.  Every tool I use could be replaced with a cheaper alternative.  Mostly I wish we could have threads about tools where someone didn't feel obligated to complain about the price.
I would be curious if it could be aligned with the top of an MFT.  It might give much better support while cuttting sheet goods.
« Reply #21 on: December 05, 2018, 09:58 AM »
+1
Offline tallgrass
« Reply #22 on: December 06, 2018, 12:27 AM »
But why can't it be free?
Offline Svar
« Reply #23 on: December 06, 2018, 12:47 AM »
When running a business this approach is a disaster. Cost of means of production is relevant. You need good return on investment to stay afloat.
False dichotomy.
« Last Edit: December 06, 2018, 01:14 AM by Svar »
« Reply #24 on: December 06, 2018, 01:28 AM »
Not all of us are running businesses...
I really don’t understand why this topic is such a hot button. Who really gives a rat’s asp to how expensive this option is for the average Joe? Average Joe either purchases one of these or he doesn’t. I don’t give a rip...write it up and let me know how it performs, that’s what I’m interested in. If it works I purchase one, if not I pass.
As an aside, every evening I walk up to the local grocery store and notice the 8-10 year old Mercedes in the parking lot that cost $60-$80k and are now rusted out. I then look at my Chevy that cost $30k and is also rusted out. I make no value judgement as to the rationale on the Mercedes owners purchasing wisdom. They purchased what they wanted...that’s what matters.
So 8-10 years later, the Mercedes costing $80k are toast while the Chevrolet’s costing $30k are also toast. Who really cares, both parties will probably repurchase those very same vehicles again, so does it really matter?
« Last Edit: December 06, 2018, 01:38 AM by Cheese »
Offline Jaybolishes
« Reply #25 on: December 06, 2018, 07:25 AM »
I wish I had that idea which is cheap to make and can sell for very high prices people will pay.  A bow of awe to Mafel.
« Last Edit: December 06, 2018, 07:38 AM by Jaybolishes »
Offline Svar
« Reply #26 on: December 06, 2018, 11:15 AM »
It's not. People are different. Some tend to rationalize their purchases even for a hobby and some don't. Nothing wrong with either.
Offline Deane62
« Reply #27 on: December 06, 2018, 11:23 AM »
Quote
Obviously, the cost of production influences decisions on what to purchase when you're running a business.  But I find it difficult to believe that people posting that they won't purchase because it costs too much, provides you with much information of value.  Opinions about quality of construction, ease of use, potential uses, along with firsthand experience help make buying decisions.
Offline TinyShop
« Reply #28 on: January 25, 2020, 10:07 PM »
Reviving this thread to highlight a youtuber's brilliant DIY take on the Ruwi/Mafell sys work bench (his are hinged in the middle so that they, and the work surface, can be tucked away inside a systainer):
« Last Edit: January 25, 2020, 10:13 PM by TinyShop »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
