Author Topic: Modify a VAC090AH ro carry systainers?  (Read 3643 times)
Offline ColossusX
« on: May 06, 2018, 05:57 PM »
Has anyone done this? I know it has a mount for the L-Boxx, but I'm finding I like the Systainers more. Wondering if the Nilfisk Systainer Mounting Kit would work.
Offline TinyShop
Re: Modify a VAC090AH ro carry systainers?
« Reply #1 on: May 06, 2018, 06:04 PM »
Who makes the latest Bosch vacs again? I can't recall. If it's Nilfisk then I would be worth looking into their sys-port since you just plug-and-play. Otherwise, you'll be into the realm of DIY'ing a solution (like those of us with pre-latest generation Starmix iPulse vacs have had to do).
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline tallgrass
« Reply #2 on: May 06, 2018, 11:31 PM »
interesting that you like the sytainers more the Sortimo. I have quite a bit of both and find that they have their respective strengths.
Offline ColossusX
« Reply #3 on: May 07, 2018, 12:47 PM »
I do have and like both. I like the smaller foot print of the Systainers. I have more systainers  and sys compatible boxes like the Makita MakPac. It looks like the Nilfisk mounting kit supports both, I would just have to find a rebadged one in the US. I think the milwaukee is??
Offline demographic
« Reply #4 on: May 07, 2018, 02:40 PM »
I had a few Sortimo boxes but gave them away, they didn't fit into my van toolsafe as well as Systainers and you needed to have a hand on either side to unlock them which is impossible in a packed topolsafe. Really didn't like that at all.
Plus they aren't flat on top cos they have the stupid catches sticking up.
Offline tallgrass
« Reply #5 on: May 07, 2018, 03:04 PM »
very valid points. I love the sortimo boxes and the systainers. I do use the T boxes for organizing small items and screws and fasteners. On that one I think sortimo has it nailed. The smaller footprint of the systainers is a plus. I had not thought about the side access issue on the sortimos. Choice is a good thing.
Offline ColossusX
« Reply #6 on: May 08, 2018, 07:17 AM »
Thanks for the input. I haven't decided yet on which dust extractor to get, but was leaning towards the Bosch because I can buy it local and get a discount on it.
Offline tallgrass
« Reply #7 on: May 08, 2018, 08:41 PM »
If it has a sortimo mounting plate, would it not be simple to make an adapter plate? Considering the systainers are smaller and the bits are available to make such a plate. Best of both worlds.
Offline ColossusX
« Reply #8 on: May 08, 2018, 09:41 PM »
That's what I was going to try and do.  These seem to make it easy
Offline tallgrass
« Reply #9 on: May 09, 2018, 09:11 PM »
that is pretty neat. I was thinking of the available bits and mounting to a plate. this is much cleaner.
