Author Topic: How to remove systainer insert without damage  (Read 296 times)
Offline dawatson833
« on: October 17, 2020, 01:02 PM »
This has probably been covered, but searching the site doesn't return anything.
I have a systainer that originally contained the cordless drill and impact driver.  TI 18 and TID 18.
A battery charger would fit also.
Anyway, I want to remove the insert without damaging it in case I want to use it again.
The insert must be glued in.  Is there a method to remove without damage?
Offline neilc
Re: How to remove systainer insert without damage
« Reply #1 on: October 17, 2020, 09:58 PM »
I don’t have that Systainer, but I have similar ones with the foam insert and I believe they are just held in place with double-stick tape on the bottom.  Festool USA has had some of the inserts as replacement parts, FYI.  Not sure if they have every one in stock or not.
