Author Topic: Foam Insert Questions  (Read 3717 times)
Offline RustE
« on: July 29, 2018, 12:52 PM »
Does anyone know the difference in the foam kits that Festool sells?  I am trying to figure out what items I need to customize a Systainer I.
Festool 497877, Foam Inserts for SYS-Vari, $30
- Appears to have the dimpled lid insert, XX thick diced foam middle, and XX thick solid foam base.
Festool 497878, Diced Foam Insert for SYS-Vari, $17.75
- Appears to have XX thick diced foam middle and XX thick diced foam base.
Festool 498044, Dimpled Lid Foam, $8.50
NOTE: XX represents measurements that I have not found.
Offline RustE
Re: Foam Insert Questions
« Reply #1 on: July 30, 2018, 12:45 PM »
@Shane Holland or @TylerC - Do you know the thickness for each piece of foam in the 497877 and 497878 sets?
Offline Shane Holland
  • Festool Dealer
« Reply #2 on: July 30, 2018, 04:01 PM »
@RustE, we only have the 497877 in stock right now and each of the pieces is roughly an inch thick. Hope that helps.
The Tool Nut
877-866-5688
Offline RKA
« Reply #3 on: July 30, 2018, 08:30 PM »
@RustE
The base insert and all the filler pieces are 25mm, the dimpled lid is 30mm.  The Tanos versions are linked below.
The 497877 set has one base, one perforated filler piece and the dimpled lid foam.  That will fill out a sys1 leaving a 20mm gap above the top perforated foam and the top edge of the systainer base.
The 497878 has two perforated filler pieces only.  So you would add those to the 497877 to fill out larger systainers.
http://www.leevalley.com/us/Wood/page.aspx?p=68754&cat=1,43326,68749
-Raj
Offline Franck Tetreau
  • Festool Employee
    • Tanos Systainer
« Reply #4 on: July 30, 2018, 08:56 PM »
The pick and pluck foam is 1" (25mm) also the base foam is also 1" (25mm)
Franck Tetreau
Tanos USA
North America Sales Manager
Cell: 805-679-3327
Phone: 877-498-2667
email: fte@tanosus.com
Offline RustE
« Reply #5 on: July 31, 2018, 09:02 AM »
Thanks for the info @Shane Holland and @RKA .
From the pictures of 497878, I thought one piece was the perforated base foam.  Maybe they just spun the pieces 180° in the photo?
