Author Topic: Classic Systainer Foot Template  (Read 6302 times)
Offline Scorpion
« on: March 12, 2018, 08:17 AM »
I made a template for cutting reliefs into shelving for t-loc feet using patterns from a previous thread on FOG.  I haven’t been able to find patterns for the classic systainers.  Does anyone know where to find them?
TIA
Sent from my iPhone using Tapatalk Pro
Offline Don T
  • Phoenix, Az
Re: Classic Systainer Foot Template
« Reply #1 on: March 12, 2018, 10:37 AM »
Here is what I saved a while back.
Online neilc
« Reply #2 on: March 12, 2018, 09:14 PM »
Can you share your T-lock Systainer foot template, Matt?  SVG or PDF with dimensions would be great!
thanks -
neil
Offline Mario Turcot
« Reply #3 on: March 13, 2018, 02:10 PM »
thanks -
neil
@neilc I am going to create one soon, using Easel from Inventables and let you know how it fit in a T-Loc systainer
Mario
Mario
Offline Scorpion
« Reply #4 on: March 13, 2018, 10:00 PM »
thanks -
neil
Here’s one I’ve had for a while.  I have another I’m still looking for.  I’ll post it as soon as I find it.
Offline Scorpion
« Reply #5 on: March 18, 2018, 10:49 AM »
I’ll post dimensions at some point but here’s what I came up with.
The feet require square corners so they’re not as fast to cut with a router and teleplay as the t-locs.  After cutting I had to square the edges with a chisel.  Will work just fine though, they retain the systainer the same way as the others.
Offline Scorpion
« Reply #6 on: March 24, 2018, 09:27 AM »
I ended up finding the one I used to make my T-Loc template from.  Turns out it was pinned in Pinterest.
« Reply #7 on: June 22, 2019, 09:08 PM »
@neilc oops I forgot about that one. Here the link for the inventables project T-Loc Systainer Insert. If you don't want to worry about inventables I can send you the toolpath file (.nc).
Mario
Offline SRSemenza
« Reply #8 on: June 22, 2019, 11:03 PM »
   It was a long time ago that I did those drawings.   [wink]  Not a foot template though.  Here are the rest ----------------------------
Systainer - I  Details
Systainer II - V  Details
« Last Edit: June 22, 2019, 11:10 PM by SRSemenza »
