Author Topic: Systainer³ for the “Festool 4-step sanding” system  (Read 506 times)
« on: April 08, 2021, 11:02 AM »
Festool promotes this product/method for their Automotive Systems Group.
Don't ask me why they call it 4-steps when they're actually using 5 different grits of paper.  [blink]  It is interesting though. The instructions are printed on the cardboard cover Systainer insert.
https://www.festool.co.uk/products/systainer-and-transport-systems/mobility-and-organisation/576843---sys-stf-d-150-4s#Overview
https://youtu.be/uAyob6jaobk?t=20
« Last Edit: April 08, 2021, 11:07 AM by Cheese »
Online Alex
Re: Systainer³ for the “Festool 4-step sanding” system
« Reply #1 on: April 08, 2021, 11:40 AM »
I do not understand the need to start at 80 grit on a car, those scratches are totally not wanted. Starting at 120 is coarse enough.
Offline Sparktrician
« Reply #2 on: April 08, 2021, 11:42 AM »
So - how's that distinctly different from the approach I used with my approach for my 125mm sanding supplies?  Maybe Festool is finally catching up???   [big grin]
- Willy -
Offline FestitaMakool
« Reply #3 on: April 08, 2021, 11:52 AM »
Clearly, the Systainer has a hidden step..
If no rasp, file or 80 grit, what would the painter and the guy from the body shop have to argue about then..  [big grin]
