Author Topic: Attic Storage -- show us what your set-up looks like  (Read 44318 times)
Offline Chris Wong
  • Festool Dealer
  • I make things that challenge me.
    • Flair Woodworks
Re: Attic Storage -- show us what your set-up looks like
« Reply #30 on: January 12, 2017, 11:26 PM »
A small improvement in my opinion would be that the bit holders would move the opposite direction. That way the heavy bits won't come loose when opening the systainer if the compartment isn't closed. Happened to me a few times  [unsure]
You can pop out the tilting racks and put them back in the other way if you want...
Chris Wong, http://FlairWoodworks.com
First Festool was a free pencil.
Shipping live-edge cribbage boards around the world since 2010.
Offline ScotF
« Reply #31 on: January 13, 2017, 12:18 AM »
Hi. So my attic looks like they do in real life. A huge mess...;)
Contents in the smaller segments might switch around a bit, but I really like to have the "ultimate" needs in order in the center and then be able to just throw anything I might need right in.
Looks like you can pack quite a bit in there...good stuff!
Offline vogel61
« Reply #32 on: January 13, 2017, 01:30 AM »
Here is my Attic setup. I haven't finished the proper printing for the drills, 5mm is actually 6mm and 6mm is actually 7mm.
Gesendet von meinem SM-G935F mit Tapatalk
Offline GarryMartin
« Reply #33 on: January 13, 2017, 06:43 AM »
Errr... you can't Chris; at least I can't. My trays are shaped for orientation, and the racks themselves have different sized holes on one side than the other, so I can't put mine in the other way around. Do you have something different? Have you tried?
Offline Chris Wong
  • Festool Dealer
    • Flair Woodworks
« Reply #34 on: January 13, 2017, 10:27 AM »
Don't turn around the trays - just the tilting bit holders that fit inside the tray.
Offline Cochese
    • The 144 Workshop
« Reply #35 on: January 13, 2017, 10:54 AM »
Tee, Lee Valley sells Tanos systainers, including a SysII with attic lid and also the Bit Storage Tray for Systainer┬« Case with Lid Storage.  .  You can either do a search for Tanos which wil show the entire line, or the fore mentioned discription.  I've bought quite a few Tanos and other items such as their Veritas┬« Mk.II Honing Guide System.  Great vendor three thumbs up!!  [big grin]
I didn't realize these existed. A conversation in 2013/4 found nothing like this.
I'd buy the 769094, but it's another one of Festool's infuriating NAINA decisions, and I'm not paying upwards of $100 for a grey market import either.
Offline GarryMartin
« Reply #36 on: January 13, 2017, 11:40 AM »
I think we must have different trays - the holes in each side of mine are different sizes so you can't turn them around.  [crying]
« Last Edit: January 13, 2017, 11:42 AM by GarryMartin »
Offline Ocram
« Reply #37 on: January 13, 2017, 02:23 PM »
I tried it already and there is no way to switch the tray or bit holder without a modification.  And if you do a modification the little handle on the front side of the tray disappears under the cover so it is not easily removed without removing the cover. So I'll just have to remember to close the cover [big grin]
Greeting Ocram
(I hope my writing is okay)
Offline jobsworth
  • Festool Baby.....
« Reply #38 on: January 14, 2017, 04:08 AM »
You guys got me again, I got one coming. It should be here Monday, along with some festool bling to take to the states with me
Offline Ocram
« Reply #39 on: January 14, 2017, 05:56 AM »
@vogel61 I'm curious, you say that you didn't finished the proper printing. Do you mean that you found a way to print the labels on the bit holders yourself?
Ocram
Offline vogel61
« Reply #40 on: January 14, 2017, 06:18 AM »
Ocram
I did remove the original printing on the bit holder to the right (apologies for the picture being rotated 180┬░, it looks proper on my mobile display) with fine grid sandpaper, then fiddled around alot with my DYMO label printer printing icons for the philips and slotted bits on transparent stripes. If you look closely, it is not perfect, but it works for me. I did not do rhis work with the wooden drills, because I  have 4/5/6/7/8/10mm in the holder with original printing for 4/5/5/6/8/10mm. I  will fix this later. Just wanted to share that it can be done  quite easily (if you can spare some time).
Richard
Offline Ocram
« Reply #41 on: January 14, 2017, 09:06 AM »
@vogel61, I surely could live with it. It is close to perfect.
Thanks for sharing!
Ocram
Offline jobsworth
  • Festool Baby.....
« Reply #42 on: January 16, 2017, 12:27 PM »
Ok guys, Got my attic sys today. So tomorrow Im goig to put the C 18 drill in it along with some things that I dont have space for in my installers set.I might get another one for the C12 and the PS jig saw. Great way to store jig saw bits
Offline Chris Wong
  • Festool Dealer
    • Flair Woodworks
« Reply #43 on: January 17, 2017, 09:45 PM »
So I talked to my customer who turned one bit holder around. He said he needed to reduce the diameter of one of the pivots to get it to work.
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
« Reply #44 on: February 13, 2018, 07:13 PM »
You can flip the tray inserts 180 degrees and snap them in upside down. It works for the two outside trays with out and modification. But the center tray need a little of the top edge clipped off to make it fit under some plastic tabs on the top.
Greg Powers
Offline KongKirill
« Reply #45 on: February 14, 2018, 04:59 AM »
THIS IS MY FAVOURITE TOPIC ON FOG SO FAR! I LOVE TO SEE PEOPLE ORGANIZING STUFF!!! [thumbs up] [thanks] [thanks] [thanks]
Offline gunnyr
    • Compass Custom Creations
« Reply #46 on: February 14, 2018, 04:04 PM »
I swapped out the normal lid with an attic lid on my Installer Set and keep various bits and nut drivers in it.
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline Dick Mahany
« Reply #47 on: February 14, 2018, 04:46 PM »
I'm liking these attic lid systainers more all the time.  The only problem I have is forgetting to lock the lid before opening the Tloc.  I'll figure it out eventually. :-
Offline ScotF
« Reply #48 on: February 14, 2018, 11:03 PM »
Greg...any pics you can share?
Offline Greg Powers
  • Metric convert
« Reply #49 on: February 14, 2018, 11:32 PM »
@ScotF This mod took all of 10 Minutes
Photo 1 Shows the two out side trays upside down
Photo 2 the tab that will not allow middle tray to be flipped
Photo 3 area of tray that needs to be removed
Photo 4 has the plastic ground away
Photo 5 all three trays flipped and installed upside down
Photo 6 this is the area of plastic removed to make it fit under the tab
Note: the middle tray must be installed under the tabs first and the opposite end forced down hard to get it in.
« Last Edit: February 14, 2018, 11:42 PM by Greg Powers »
Greg Powers
Offline SRSemenza
« Reply #50 on: February 15, 2018, 09:39 AM »
I did this to provide a visual reminder. Red Sharpie.....................
Offline Dick Mahany
« Reply #51 on: February 15, 2018, 09:48 AM »
    (Attachment Link)
    (Attachment Link)
Going out this AM to get a red sharpie, thanks !
« Reply #52 on: February 15, 2018, 10:05 AM »
Great idea, I also keep forgetting to lock when I open up the Systainer.  [tongue]
Offline mschmidt10k
« Reply #53 on: March 16, 2018, 11:43 AM »
Is there a retailer that actually sells replacement attic lids for Festool systainers? I know that Lee Valley has the Tanos systainer with the attic lid, but I just want the actual lid ...
Offline Dick Mahany
« Reply #54 on: March 16, 2018, 11:49 AM »
I have seen them on Bob Marino's Festool store  website.
« Reply #55 on: March 16, 2018, 11:54 AM »
Festool sells them as an accessory as well as Tool Nut I believe.
Offline mschmidt10k
« Reply #56 on: March 16, 2018, 12:00 PM »
I don't think Tool Nut has them anymore - at least I couldn't find them on the site.
Is the lid available as a complete package or do you need to buy separate parts (lid, cover, plastic dividers, etc)?
Offline justaguy
« Reply #57 on: March 16, 2018, 12:05 PM »
I checked on these about a week ago and could not find them on the Tool Nut site. I sent a PM to Shane and he replied that Festool changed the scope of delivery requiring some of the parts to be ordered separately. They did not think the resulting pricing made sense and they are no longer offering the attic lids.
I'm paraphrasing, Shane can probably clarify the details.
« Reply #58 on: March 16, 2018, 12:36 PM »
Bummer...I purchased my last one from Tool Nut for $31.37, part number 702082.
Offline Greg Powers
  • Metric convert
« Reply #59 on: March 16, 2018, 12:51 PM »
They got a lot more expensive. $80! Festool products are getting ridiculous.
Greg Powers
