Author Topic: What do you put in your Systainers.  (Read 19175 times)
Offline T. Ernsberger
« on: March 16, 2017, 08:50 PM »
Let see your tools or accessories in your systainers.  I now have all my tools in systainers.  I thought it would be cool to start a thread see how everyone else uses systainers to store their tools.  I know a lot of guys are using Kaizen Foam.  Might be cool to get ideas and see what others are doing.
Re: What do you put in your Systainers.
« Reply #1 on: March 16, 2017, 08:53 PM »
I'll start it off.  Here is my new Bosch JS572 in a Tanos Sapphire Blue Sys2 with red t-loc and black handle.  Used foam that was precut from Woodcraft.
Offline Kevin C.
« Reply #2 on: March 16, 2017, 11:07 PM »
I will throw a couple in on this thread! Dewalt hammerdrill and tapcons both in sys 1s. Dewalt planer and all its accessories in a sys2. The Bosch lasers(points, level and measuring laser) along with extra batteries and a Dewalt 20v charger and battery. Senco 1010 in a sys5 with room for a 25ft coil hose and a cord reel under it, and a MFT lid.
« Reply #3 on: March 17, 2017, 08:23 AM »
Looks good.  I really like the Mft top.
« Reply #4 on: March 17, 2017, 08:26 AM »
I have my Paslode Angled 16ga in a Combi2.  The drawes work great for nail, gas and charger storage.
Offline ben_r_
« Reply #5 on: March 17, 2017, 03:18 PM »
Nothing but the tools that come with them and associated accessories that fit. I dont need my tools to be mobile so I have found no need to use  systainers for organization around the shop.
Offline DiscoStu
« Reply #6 on: March 17, 2017, 06:40 PM »
I have a Sys 2 with a number of hand tools.  I also have a Sys 1 with my DeWalt Drill and Impact in. A mate of mine gave me grief for trying to make out I had more Festool than I do but for me it's keeping them all in a system. I have made a Dewalt label for it.
« Reply #7 on: March 18, 2017, 11:17 AM »
Do you have any pictures?
Offline Gwerner
  • They call me George...
« Reply #8 on: March 18, 2017, 03:30 PM »
Quick side question for you, what do you think about the dust collection on that saw? I'm seriously considering ditching my Carvex and going with the D-Handle version of the JS572.
It's really good to see it fits well in a SYS1 as well!
Offline DiscoStu
« Reply #9 on: March 18, 2017, 08:31 PM »
Well having just gone out to take a photo I realise it's a Sys2 but here are some photos
I think I bought a Sys1 for them but with all the foam they didn't quite fit so I had to do a swap about.
Offline Holzhacker
    • www.aic-chicago.com
« Reply #10 on: March 18, 2017, 08:40 PM »
No pics but to name a few
- Lunch box, contains plastic silver ware, knife for cheese and sausage, napkins, paper plates, corkscrew, etc.
- Sys 1 full of hole saws and arbors
- Sys for Ridgid see snake, moisture meters
- TS 75 sys turned into storage for smaller clamps
- Sys 3 for safety stuff, i.e. tyvek suits, masks, gloves, safety glasses, etc.
« Reply #11 on: March 18, 2017, 09:28 PM »
The dust collection is awesome.  The dust tube is actually on a hinge and will move side to side when cutting and helps the saw move more smoothly when making curve cuts.  I was going to get the Carvex but decided the Bosch JS572 was a better saw.  It has a built in led light and tool less bevel.
« Reply #12 on: March 19, 2017, 08:22 AM »
That looks great.  I need to get some time and make some custom labels.
Offline Master Carpenter
« Reply #13 on: March 19, 2017, 05:14 PM »
Just finished up a organizer for my finish nails. I use 15, 18, 23 gauge nailers plus a narrow crown stapler on my jobs. Nice to finally get this cleaned up, but I'm probably going to get a few shallow boxes to organize the loose brads.
[ Specified attachment is not available ]
Offline Vondawg
« Reply #14 on: March 21, 2017, 10:21 AM »
With blades in the attic lid
« Reply #15 on: March 24, 2017, 05:46 PM »
Just got done with my cabinet systainer.  Its a sys1 with compartments.  I took out some of the compartents and replaced with kiazen foam for my true position hardware jig.
Offline PaverMan
« Reply #16 on: March 26, 2017, 10:32 AM »
I have done A LOT of decks over the years.  I always end up with extra pieces of Azek cladding.  Considering it's impervious to rot AND how expensive the stuff is, I've always hesitated to throw it away.
So now I use it to create custom tool holders.  It's light, it's free (well, already paid for), easy to mill, pretty tough.
Here's a simple one for a Systainer 3 - and my DeWalt impact driver and associated items.  I've actually added to this since this picture.  I'll add more pictures later.
« Last Edit: March 26, 2017, 05:54 PM by PaverMan »
Offline SRSemenza
« Reply #17 on: March 26, 2017, 04:50 PM »
That's a good idea for tool holders in systainers. I tend to think foam but a solid material works well too.
Offline CADru
« Reply #18 on: April 12, 2017, 08:51 PM »
I am in the process of switching over to Systainers for my tools. The Bosch boxes will be for sale soon. For inserts I purchased a foam insert from kaizeninserts.com and use this as a template to cut my own inserts from FastCap's Kaizen foam sheets. I like the fact that I can layout tools/accessories and section cut the Kaizen foam removing layers to accommodate tool shape. I anchor my lid inserts with double sided tape. Once I remove the required layers of foam I use a hot knife with a flat quarter sized tip for flatting and shaping. When scraping away layers I'll use the claw end of a small remodeling pry bar. Using fingers to claw back the foam works for large areas but the remodel bar works great for final leveling.
I make my custom labels for both Festool and non-Festool tools/accessories. This way I can personalize and use manufacturers logos tool images. Saving imaged from internet searching and using TechSmith's Snagit app for screen grabs and editing. I make my labels using Microsoft's Publisher app.
Offline jwaite550
« Reply #19 on: April 21, 2017, 03:09 PM »
Nice!
Offline six-point socket II
« Reply #20 on: April 21, 2017, 04:28 PM »
Hi!
I started out with L-Boxxes and a lot of Bosch Professional tools. By now I have sold off almost everything I once owned made by Bosch, just kept a small rotary hammer and a 12V GSR for kinda personal reasons. Those are also still in 2 L-Boxxes. Without elaborating any further, the L-Boxx is simply not for me.
I now only use Systainers. My top priority is to fit as much accessories as possible together with the tool in a Systainer.
For example, my Snap-On impact wrench Systainer.
What the Systainer holds is two 3/8" metric socket sets shallow/deep. Additional battery, adapters (3/8"-1/2", 3/8"-1/4" hex, 1/2"-3/8" ...), charger, 1/2" sockets for tire changing, a 1/2" ratchet (not in the picture), 1/4" impact bits and of course the tool itself.
Then there is my Festool drill/driver kit. It consists of 3 Systainers. A SYS-1 with CXS and accessories, a SYS-2 with attic-lid for my PDC and accessories (+ one ration of consumables) and another SYS-1 with the Centrotec installers kit.
Spread.
Attic-lid of PDC's Systainer
Installers kit.
CXS
Then comes the DTS sander kit. It consists of one SYS-1 for sanding paper and a SYS-2 for the tool and accessories. Pictures were taken when I got the stuff - looks a little different today and there was more stuff added.
Then my SYS-5 for PPE. Currently there's even two pairs of boots in it, along with the rest...
Then a SYS-2 for my DWC. It's pretty basic. Tool, charger, batteries and some extra bits.
Then my SYS-PH. It has an additional extension cord with built in RCD / GFI (hope that is the right translation).
TSC and Carvex Systainers are kept pretty basic, too. So no pictures...
Currently I'm working on a concept for putting my Fein AFMM 18 QSL, and my Hilti TE 30-A36 in Systainer(s), too. I'll post pictures when I found a solution that works for me.
I also use the Festool-PDF to create my own labels. I might need to take a picture of all of them together *lol*.
Kind regards,
Oliver
« Last Edit: April 21, 2017, 04:30 PM by six-point socket II »
Kind regards,
Oliver
« Reply #21 on: April 21, 2017, 07:12 PM »
Looks good Oliver!
@six-point socket II
Offline live4ever
« Reply #22 on: May 08, 2017, 01:08 PM »
Can anyone verify whether the mini fits inside the new sortainer drawers (4/sort3 and combis)?  Per specs it seems it should be a perfect fit.
Offline SRSemenza
« Reply #23 on: May 08, 2017, 04:02 PM »
They will not.  Too tall.
Offline ggc
« Reply #24 on: May 08, 2017, 04:17 PM »
If you're willing to butcher a drawer, they can fit, but it's less than optimal
2 Minis in a Sys-Combi drawer
Offline live4ever
« Reply #25 on: May 08, 2017, 05:27 PM »
Bummer, what a missed opportunity [doh] [doh]
Offline #Tee
« Reply #26 on: May 08, 2017, 08:05 PM »
uggg oliver!!! that installer set with your attic lid is to die for  [eek]
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
Offline dwillis
« Reply #27 on: May 16, 2017, 04:20 PM »
Maybe mine is an atypical use, but besides being an avid user of Festools and Systainers I also am a long range target shooter and reloader. Because I'm on an extended assignment in northern Nevada I found myself assembling a collection of tools to reload my ammunition while I'm away from home (hand loaded ammunition is typically more accurate than factory loaded). Yes, I could have dumped everything into a plastic bin, but the Sys-Combi3 turns out to be the perfect solution. Besides powder and primers there's room from a small press in the top compartment along with a digital scale and loading block. In the drawer I store dies, funnel, digital calipers, and assorted parts. Now I can simply pull out my Systainer and sit at the kitchen table with all the equipment needed to reload and when I'm done put it all away in a neat and organized fashion.
Remember that the only scientist to walk on the moon was a geologist.  Dr. Harrison Schmitt - Apollo 17 - Valley of Taurus-Littrow - 11 to 17 December 1972.
« Reply #28 on: May 27, 2017, 02:17 PM »
Thanks @#Tee
That's definitely a great idea @dwillis !
To keep this thread alive, fresh picture from today of my Snap-On impact wrench SYS 2 - I re-adjusted some of the roofing panels on my patio.
Kind regards,
Oliver
Kind regards,
Oliver
