Author Topic: 120V Sys Power Box  (Read 54914 times)
Offline Dick Mahany
120V Sys Power Box
« on: January 01, 2018, 01:46 PM »
Thanks to some inspiration found here on the FOG, I decided to build a US 120V power distribution box in a Systainer.  I just need to finish the inside rear cover panel and install a strain relief for the cord.  I used 12 gauge wire throughout and it was a little difficult to work in close quarters without distorting the systainer.  I was going to use a GFI, however all of the outlets that I typically use are already GFI protected.
I'm only using this at home for my own personal use, so I'm not worried about OSHA or UL regulations. Just wish we could get a US version of the European power hub.  Any body listening at Festool?   [wink]
« Last Edit: January 03, 2018, 09:49 AM by Dick Mahany »
Offline TinyShop
Re: 120V Sys Power Box
« Reply #1 on: January 08, 2018, 05:53 PM »
I agree. Anyone listening?
Nice work BTW! :)
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline SRSemenza
« Reply #2 on: January 08, 2018, 07:46 PM »
Yeah, and pretty good combination in the CT-Sys stack. Makes sense.
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
« Reply #3 on: January 20, 2018, 10:31 PM »
We have been waiting for the NA version for a long time.... [sad]
Greg Powers
Offline Don T
  • Phoenix, Az
« Reply #4 on: January 21, 2018, 12:18 AM »
NIce setup. What size systainer?
Offline TinyShop
« Reply #5 on: January 21, 2018, 03:03 AM »
So, since I don't see this happening anytime soon, I thought I'd share the results of my research into sourcing the components I'll be using to convert a new to me (but lightly used) Sys III into a DIY 120V/60Hz SYS-PH.
For outlets, I plan to use either the following, which are designed for installation in panels:
NEMA 5/15 Panel Outlet w/Spring-Loaded Cover, Black
...or these (which are also intended for panel installs):
NEMA 5-15 Panel Outlet w/ Spring Loaded Cover, Blue
Since the former are half the price of the latter, I'll likely opt for a selection of the less expensive ones, in which case I'll need to also procure some female terminal ends:
...to facilitate wire-up. I figure that after I've sunk the appropriate number and diameter of holes into the front of the systainer, I'll use pop rivets to fasten the outlets to the systainer wall.
As for protection on the inside of the systainer, I may or may not fasten a junction box behind each respective outlet (this will depend on how hermetically-sealed I make the plywood shroud that will cover the new work).
I also plan to install a single red LED indicator light like this one:
Indicator Light
...into the front face of the systainer to indicate whether or not the outlets are live.
I'm considering installing a standard 15A GFCI outlet upstream of the various outlets (ideally, mounted inside the systainer in the aforementioned plywood shroud) for ground fault protection but am hesitant to do so out of concern over high draw hand tools possibly causing false readings. Not sure if this concern is valid or not but it would be a nice place to tie in the short length of heavy duty power cord that I plan to use to supply power to the outlets (most often via a plug plugged into my Starmix vac).
I'm calculating that the entire project, including the US$50 I spent on the used systainer, will cost approximately US$100. My plan is to use the remaining space inside in the systainer for storage of a power cord (or two?) and a couple of battery chargers and some batteries, etc. We'll see.
Oh, and another even less expensive outlet option might be these snap-in (but non-dust cover protected) versions:
120V 15A US Socket, Panel Mount, NEMA 5-15R
Compatibility will depend on the thickness of the panel they are intended for (no idea if the intended panel thickness is thinner or thicker than the wall of a systainer).
So, just some ideas in case anyone else can benefit....
« Last Edit: January 21, 2018, 03:51 AM by TinyShop »
Offline Svar
« Reply #6 on: January 21, 2018, 03:14 AM »
I'm curious what is the purpose of it? It's equivalent to a simple power strip, but 20 times bigger. Not to mention the cost. Why?
Offline TinyShop
« Reply #7 on: January 21, 2018, 03:22 AM »
Efficiency mostly. I hate stumbling around cords in tight spaces and I can always use more sys storage (even if some of the interior volume will be eaten up by the associated wiring). Plus, it just adds to the professional look I'm aiming for. Also, I figure that the associated wiring and shroud won't take up any more room than a beefy power strip. So, nothing really lost (other than the ~US$50) while some improvements gained.
Offline TinyShop
« Reply #8 on: January 21, 2018, 03:27 AM »
Judging from the three horizontal lines on the front face of his systainer (under each label slot), it's a Sys III.
« Last Edit: January 21, 2018, 03:33 AM by TinyShop »
Offline Womble
« Reply #9 on: January 21, 2018, 06:22 AM »
There is many UK people who been wanting a 110v UK version of the Power Hub myself included.
But Festool have been neglecting the 110v UK construction workers for a while now by only releasing many of their tools in 240v only versions, even when they claim in their lovely marketing literature they been designed for rugged site use.
I will point out that Festool are not the only company doing this Metabo (among others) are also not releasing 110v version of loads of their tools, not sure if they trying to pressure the UK into adopting 240v only across the board ( i know 110v isn't the law but it is the standard for site use whether we like it or not & its not going to change any time soon)
Offline Naildrivingman
« Reply #10 on: January 21, 2018, 04:55 PM »
Indicator Light
@TinyShop I have a really pesky suggestion for you if you choose to use the black outlet version. If possible, remove the door, turn it upside down and reinstall. I suggest because for me I kept having to bend over my vac to see the outlet when I plugged into it.  Flipping the door may introduce more option for dust to enter the outlet, but I am willing to accept this over wrenching my back.  If you can’t remove/reinstall the door, simply flip the outlet.  Just a suggestion.
Dance with who brung ya...
Offline TinyShop
« Reply #11 on: January 21, 2018, 05:32 PM »
@Naildrivingman - I didn't say so, but you are right. The ability to rotate the lid portion of the outlet to any cardinal heading (in the case of the black lidded outlet) is potentially very desirable. My Starmix (branded "CS Unitec") vac features a strikingly similar type of spring loaded lid over the tool outlet and it can be a little annoying to actuate in the vertical orientation. I'll keep your suggestion in mind. :)
« Reply #12 on: January 21, 2018, 05:45 PM »
Even just rotating it 90 degrees makes life easier.
Offline Peter Halle
« Reply #13 on: January 21, 2018, 06:34 PM »
Even the receptacle covers on the CT vans can be pulled off and rotated.  Can help support the cord and keep in plugged in in certain instances.  #festoolsedge did a recent instagram post on this to follow up with the training classes over the years.
Offline Dick Mahany
« Reply #14 on: January 21, 2018, 06:48 PM »
I saw that great tip from Sedge only last week and immediately went out and rotated the one on my CT36 180.  I really don't care for the two handed requirement when plugging in tools and that is why I used standard outlets. Sedge has some great stuff out there.
Offline Greg Powers
  • Metric convert
« Reply #15 on: January 24, 2018, 01:45 PM »
What about buying the UK 220v version and then converting it to USA 110v plugs and re-wire it to 110 Volts. That way you get the recessed front and the interior plastic wiring divider.  True it would be a little expensive but you would have the Power hub and it would be a 110V USA version.  [big grin]
Greg Powers
« Reply #16 on: January 25, 2018, 08:57 PM »
And here I thought I had a million dollar idea....sheesh that festoolsedge guy!
Offline Greg Powers
  • Metric convert
« Reply #17 on: February 10, 2018, 09:16 PM »
« Last Edit: February 10, 2018, 09:23 PM by Greg Powers »
Greg Powers
Offline TinyShop
« Reply #18 on: February 10, 2018, 09:36 PM »
Greg - Mic drop! ;)
Offline Kevin C.
« Reply #19 on: February 10, 2018, 10:38 PM »
darn Greg, that looks fantastic!
Offline neilc
« Reply #20 on: February 10, 2018, 10:41 PM »
Very cool!  Congrats!  Where did you order from and where did you find the replacement receptacles?  Tell us more!
Nice project!
Offline BJM9818
« Reply #21 on: February 12, 2018, 01:03 AM »
Greg great idea.
Love to know where you got the Power systainer. What I would also like to make is a 30amp twist lock I can use with my Honda 3000is to feed two separate 120v  circuits or even two independent feeds to a sys power box.
Offline Greg Powers
  • Metric convert
« Reply #22 on: February 12, 2018, 02:23 PM »
Greg great idea.
Bought the Power Hub Systainer on Amazon UK. It was pricey but I wanted the recessed front  and the plastic divider on the inside. It was also a nice surprise, as the inside wiring was on a three bar bus, with plugs for each socket. Did not need to be rewired. Just change the socketts and the cord plug.
« Last Edit: February 12, 2018, 02:39 PM by Greg Powers »
Greg Powers
Offline Greg Powers
  • Metric convert
« Reply #23 on: February 12, 2018, 02:31 PM »
The blue 110 volt sockets matched the mounting holes exactly. There is a small relief that the sockets fix in too and these blue socket also fit in that recessed space. Too bad the blue sockets were not black. The black sockets I ordered had a wider mounting hole pattern. The blue sockets were also twice the cost of the black ones.
You can find the blue sockets on Ebay and Amazon.
Once I had the sockets the conversion took only about 30 mintues to do. Very easy too do.
Greg Powers
Offline six-point socket II
« Reply #24 on: February 12, 2018, 02:35 PM »
Thats a great conversion!
Kind regards,
Oliver
Kind regards,
Oliver
Offline Greg Powers
  • Metric convert
« Reply #25 on: February 12, 2018, 02:40 PM »
Kind regards,
Oliver
The only option for us here in the USA.
Greg Powers
Offline Trevin
« Reply #26 on: February 12, 2018, 04:52 PM »
I LIKE it Greg!,
Do you have a link to the outlets?  Cannot find them on ebay or amazon....
Thanks,
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline Greg Powers
  • Metric convert
« Reply #27 on: February 12, 2018, 04:55 PM »
I LIKE it Greg!,
Thanks,
Trevin
On Amazon:
Description: Waterproof Panel Mount,Generator NEMA 5-15R Socket & Receptacle,15A 125V,Grdg (ETA:7-12 WORK DAYS)
Link: http://a.co/fHbuvky
The sockets ship from China so it takes awhile to get. Mine took 10 days. User @Naildrivingman sourced them in his post above.
Festool 220V Power Hub
Link: http://amzn.eu/09lmH3o
The Power Hub ships from the UK
« Last Edit: February 12, 2018, 05:00 PM by Greg Powers »
Greg Powers
Offline TinyShop
« Reply #28 on: February 12, 2018, 04:58 PM »
Greg - for posterity's sake, and if you have an additional minute, how about a photo showing the bus bar/guts of the system? Thanks! :)
Offline Greg Powers
  • Metric convert
« Reply #29 on: February 12, 2018, 05:05 PM »
@TinyShop I was hesitant to post that Photo. As I fear Festool/FOG board moderators will take down the post for modifying the guts of one of their products. The inside plastic divider is secured with security screws, so Festool does not want customers messing with the wiring. If it is OK with the FOG board moderators I can post. Other wise you can message me.
Greg Powers
