Author Topic: 120V Sys Power Box  (Read 52239 times)
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
Re: 120V Sys Power Box
« Reply #60 on: February 13, 2018, 01:17 PM »
FWIW...just got a note back from International Configuration and they have the 70020-BLK receptacles in stock at $6.46 each.  [smile]
However, they do have a $50 minimum charge.  [sad]
@Cheese Do a group buy. Still a lot cheaper, half the price, than the ones I bought.
Greg Powers
Offline Greg Powers
  • Metric convert
« Reply #61 on: February 13, 2018, 01:20 PM »
Greg, can you tell if the specifications on that pdf are the same for the blue socket?
@Mario Turcot   You need 38mm center to center, horizontal and vertical for the mounting holes. The Outside dimensions are 50mm square.  Looks like the specks on the pdf match the screw holes not sure of outside dimensions as there are none on the PDF.
« Last Edit: February 13, 2018, 01:30 PM by Greg Powers »
Greg Powers
Offline Mario Turcot
« Reply #62 on: February 13, 2018, 01:56 PM »
Excellent, thank you for replying :D
Mario
Offline JeremyH.
« Reply #63 on: February 13, 2018, 02:21 PM »
So if you don't have a distribution with built in PRCD (which is then mostly as big/bulky as a systainer, maybe even more - and which abides by all rules/regulations) you will most definitely have at least one additional power strip with PRCD built in.
Kind regards,
Oliver
Progressive Retinal Atrophy? You might have to tell us in the US what PRCD means over there...
CXS;RO150;ETS EC 125/3 EQ;CT26e  KSS400;MT55cc;DDF 40
Offline six-point socket II
« Reply #64 on: February 13, 2018, 02:31 PM »
Kind regards,
Oliver
Hi Jeremy,
Sure. :) Switched Protective Earth Portable Residual Current Device = PRCD-S
It's a mobile version (with the additional functionality of detecting a faulty wiring/circuit and as result not staying "on") of this:
https://en.wikipedia.org/wiki/Residual-current_device
Kind regards,
Oliver
Kind regards,
Oliver
Offline JeremyH.
« Reply #65 on: February 13, 2018, 04:04 PM »
Ah, figured but wasn't sure. In the Americas they call them GFCI.
I don't really care much for GFCI except for bathrooms and kitchens. They go bad way more than people think, and it's really confusing as to what is going on.
« Reply #66 on: February 14, 2018, 09:05 AM »
I have GFCI's on all the outside receptacles, I've had to replace 2 of them.  [sad]
I have GFCI's on the dish washer and the garbage disposal, I've had to replace both of them.  [sad]
I have GFCI's on all the runs in the basement, I've had to replace 3 of them also.  [sad]
It does seem like the newer Leviton versions are more reliable than the earlier Leviton versions.  [unsure]
Offline BJM9818
« Reply #67 on: February 14, 2018, 11:11 PM »
Try the new Arc fault breakers. I’m  experiencing about a 10% failure rate right out of the box.
Offline JeremyH.
« Reply #68 on: February 14, 2018, 11:46 PM »
Sensing a conspiracy for breaker "code" or "standards" of use related to investors in breaker companys...
It's not like after decades of problemless functions of good breaker (not all are equal), a bunch of cheap ones are magically going to be better for safety - under the presumption that people now suddenly just cannot resist dunking everything they plug into the wall into water........
When it comes to safety, outlawing back-stab outlets state by state has been a very positive thing. Those are a problem, not people dunking electronics into water.
Offline Sparktrician
« Reply #69 on: February 15, 2018, 08:16 AM »
In all the years I worked as an electrician, I think I replaced less than 10 GFCIs.  My own "WOW Memorial PowerTainer" uses a whole-house surge suppressor from Square D to eliminate surges that often trash GFCIs.
- Willy -
« Reply #70 on: February 15, 2018, 09:06 AM »
I've never had a GFCI fail.
Short version for Germany: they are required by law since May, 1st 1984 for all rooms having a bathtub or shower. And since February 1st 2009 for all circuits supplying receptacles/sockets/outlets up to 20A for use by "everybody" -> non-professionals.
Furthermore they have to be installed in a way that they will not interrupt complete supply -> light circuits should remain live for example.
There is no need to amend existing installations if they were according to code at some point in the past (meanin pre 1984 or 2009. However, major changes to existing circuits/supply require GFCI's to be installed according to current code.
Can't say that I've heard much complaints about faulty GFCI's. Like I said, mine work since the day they were installed.
Kind regards,
Oliver
Kind regards,
Oliver
« Reply #71 on: February 15, 2018, 09:58 AM »
@Sparktrician
Thanks for that post. If I understand the HEPD80 correctly, it needs to be placed/connected as close to the main lugs as possible and then it will protect both legs of the system, is that correct?
Two of the GFCI's were knocked out because of lightning strikes and two others were taken out by an intermittent neutral from tree branches. That allowed each leg to vary any where from 50 to 190 volts and both legs varied constantly as the wind blew.
« Reply #72 on: February 15, 2018, 12:30 PM »
@Sparktrician
Correct.
- Willy -
Offline Greg Powers
  • Metric convert
« Reply #73 on: February 15, 2018, 01:41 PM »
Those push sockets are garbage. You're soo much better off with the replacements that have screws.
The socket in the photo is the Festool 220 volt UK one. The blue 110 volt USA ones, used in the mod, do have a screw on connections.
Greg Powers
Offline JeremyH.
« Reply #74 on: February 15, 2018, 02:18 PM »
Panel mount surge suppression is good. But to be very safe for something of value you want an end device as well. SurgeX is the best thing I've ever seen (and I've seen patents etc).
Germany... one issue for any audiophile like my self is that we run individual lines for the stereo, and we use specialized sockets that are better. I guess that isn't an "everyone" use? Stereo only.
« Reply #75 on: February 15, 2018, 03:45 PM »
Hi!
Well, even an audiophile is still "everyone" ;)
BUT, we have a say in Germany: No plaintiff, no judge. ;) ;) ;)
So my best guess would be ;) ;) ;) that if you either do it yourself or find an electrician who will do it for you, your line(s) for the high-end stereo will have no GFCI. ;) ;) ;)
Kind regards,
Oliver
Kind regards,
Oliver
« Reply #76 on: February 15, 2018, 06:10 PM »
Another item few people consider, especially when using a fiber-supplied internet connection (FiOS) is surge protection for the Ethernet connection from the ONT.  I have to give myself a dope-slap in that regard.  Last May we had a thunder/lightning storm here, and one bolt of lightning hit the streetlight in front of my house.  The streetlight exploded and blew glass all over the street and my front yard.  No electrical-only appliances were damaged as I have surge protection on my power feed to the house, but strangely, all my routers and switches were destroyed, as well as my TV.  What they had in common was the Ethernet connection.  Many years ago I took a graduate-level course on grounding, bonding and shielding.  As I evaluated the scenario in light of that training, it occurred to me that although the data connection is via glass fiber, there is a parallel ground line as part of the fiber feed line.  The light pole that got hit is 10 feet from the FiOS distribution box.  I suspect that radiated surge energy traveled down the ground line in the FiOS line that feeds my house.  Lightning energy does some REALLY strange things.  As I dug into it further, I found that the FiOS ground line was not commoned with the house cold water ground.  That has since been rectified with a good run of solid copper directly from the ONT to cold water ground.  Additionally, I have installed an Ethernet surge suppressor in the feed from the ONT to my edge router for better protection.
« Last Edit: February 15, 2018, 06:25 PM by Sparktrician »
- Willy -
Offline JeremyH.
« Reply #77 on: February 15, 2018, 06:48 PM »
Willy, thanks for that description. It's actually something pertinent to a project I am working on [eek]
Offline Trevin
« Reply #78 on: February 27, 2018, 11:01 PM »
Just finished with my Sys Power Box!
Thanks for the ideas guys.
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline Greg Powers
  • Metric convert
« Reply #79 on: February 28, 2018, 12:37 AM »
Nice too have a 3D printer
« Last Edit: February 28, 2018, 10:27 AM by Greg Powers »
Greg Powers
Online rst
« Reply #80 on: February 28, 2018, 07:26 AM »
Just received mine from Amazon.de, conversion awaits the receptacles arriving.
Offline Scorpion
120V Sys Power Box
« Reply #81 on: February 28, 2018, 09:20 AM »
I ordered one as well.  Won’t see it for a week or so.  Not feeling patient
Edit:  excited for the project
Sent from my iPhone using Tapatalk Pro
« Last Edit: February 28, 2018, 09:28 AM by Scorpion »
« Reply #82 on: February 28, 2018, 09:54 AM »
Well I'll be the 3rd doofus to admit to purchasing a Sys PowerHub from Amazon.de.  [embarassed] [embarassed]
Received the box within 4-5 days of ordering it from Germany.  [big grin]
Ordered the black outlets yesterday from International Configurations, $5.41 each. They're also IP54 instead of IP44, a nice bonus.  [cool]
Offline Scorpion
« Reply #83 on: February 28, 2018, 08:00 PM »
PowerHub is cool, it just is.
What was the part number of the IP54 outlets?  Did you have to buy 10 to get to the minimum order amount?
« Reply #84 on: February 28, 2018, 08:32 PM »
70020-BLK-NS...I decided to purchase 10 of them as I may also use them in an outdoor application. So bottom line, $54.10 + $15.97 for shipping. The receptacles are in stock, I ordered them on Monday and they shipped on Tuesday.  [smile]
I'm going to move the charger for the CXS to the inside of the SYS PowerHub along with a charger for my iPhone. Sweet...can't wait.
Offline Scorpion
« Reply #85 on: February 28, 2018, 08:42 PM »
That’s a neat idea.  I too was thinking about incorporating some kind of USB hub but need to see it in person before knowing if it’s a good idea or not.
« Reply #86 on: February 28, 2018, 08:50 PM »
In the summer I work outside all day long. The black iPhone is always an issue because if left in the sunshine it gets so hot that it will shut itself down. Now I'll be able to keep it in the SYS PowerHub out of harms way from tools and sunshine while at the same time maintaining its charge level.
Offline Greg Powers
  • Metric convert
« Reply #87 on: February 28, 2018, 09:17 PM »
10 of the black cost almost the same as 5 of the blue ones.
« Last Edit: February 28, 2018, 11:20 PM by Greg Powers »
Greg Powers
Offline Scorpion
« Reply #88 on: February 28, 2018, 10:38 PM »
10 the black cost almost the same 5 of the blue ones.
That’s what I was thinking as well.  Difference is you have either (1) spares or (2) enough to order another PowerHub.
« Reply #89 on: February 28, 2018, 10:39 PM »
Yeah, I decided to purchase 10 of them because I may look at incorporating some of them into an aluminum fence system. It'd be a lot cleaner than installing separate electrical boxes, box covers, GFCI's, mounting posts, driving the posts into the ground...yada, yada, yada.
Thanks for the original inspiration...🙏...I think I'm going to like it.  [smile]
