Good point about tapering the fence post tops and leaving a "fall" around the crete. Having worked quite a bit in Australia I am familiar with the standards and techniques. Setting the posts in crete here is similar to leaving it upright in a bucket of stagnent water as you effectively create a well for the post to sit in which has no weep holes for the water to escape
As I mentioned for my own private client work I would never set timber into the ground and would always use some type of galvanised shoe that would be levelled and set in crete the day before timber install. In the UK the ground can be water logged for weeks or months on end so the norm is to set the posts in a quick set concrete which hardens enough to level posts literally in minutes.
I dont like this system but have used it several times when sub contracting, due to main contractor constraints
. Especially on new build housing the method is to erect quick decks and fences to define the boundries of new developments. The notion of longevity on hedge carpentry here does not really exist unless it is a really high end job .The nasty stuff like arsenic has been removed from the wood preservatives and green tanlith is widely used. Internally tanilised timbers have a long life span but set in wet ground it does not!! Hence this product has come about.
I have no experience with posts that have been pile driven so cannot comment except I would imagine if you were to shrink a post protector around one, then pile drive into stifff ground surely it would tear the post protector off??
Its seems it is acceptable to install a fence or deck in this way as it is widely accepted that it would have a short life span, but would be cheap to replace, very similar to the notion that outbuildings like sheds with bitumen felt roofs and the sheds themselves are disposable. (5-10yrs)
It rains here A LOT........infact for every day the sun shines in Australia we would get Rain.
