Seems we’re on par here, although I didn’t get Cheese’s reasonings at first. The different thickness is the obvious culprit here. I have never seen countertops with double layer as here with different thickness. The thicker wood will swell more, so it seems reasonable that it expands a bit more.
Right; it’s made up by short pieces, both layers. This is common here, just like parquet, but hat has plywood under.. Usually these are very stable: using one layer that is.
I’ll try drying it inside, it’s now been a couple of days under roof outside, not very moist weather, but slightly moist in the morning. Table legs is an option that I thought of too.
Mini Me - I thought about the same, I’ve done it with slight success before. However, treating one side (the thin layer) with some sort of clear finish oil to soak in applying wet in wet with slow drying oil is also something I’ll try. I’ll check in with the paint store..
A thicknesser is on my bucket list too
![Big Grin [big grin]](https://www.festoolownersgroup.com/Smileys/default/biggrin.gif)
. If I go ripping it down, I might as well resaw some on my band saw. Then I could use it on plywood too. I don’t know how it will react to this though.
It’s high rated firewood too!
![Tongue Out [tongue]](https://www.festoolownersgroup.com/Smileys/default/tongue_smilie.gif)
- But, nonetheless I think it’ll be useful to anything else than that.
