@Cheese I'll be interested in your results with those disks. The 3M selection I was able to find on Amazon was underwhelming and I never put in the energy to search further. Mostly I'm using disks from the local-ish industrial supply, the carry SAIT and similar options. Hughes looks like a good source for 3M.
RE: working with AL, I've needed some pre-sized blanks for making misc. parts with Origin and found the best approach was old school, cut them with the saw and grind to final size. Made sense to make a jig.
A few years ago I filed the front edge of the grinder table to make it parallel with the disk. The first (rightmost) guide gets set with the jig a few thou off of the disk. The screws holding the guide in the slot are loose, so the jig can move in and out until it hits the hard stop.
With the hard stop set, you use a gage block to set the fence.
I use a 10 thou shim when setting the fence, to leave the final part oversized, then file/lap it to final dimension. Should'a made this years ago.
Looking forward to your report on the 3M disks.
RMW
