@Cheese did you get those hook and loop 3M scotchbrite disks? Had a chance to use them yet? Curious about how they perform. Thanks Ron
Hey Ron
@rvieceli I finally received the backing pad. Before I received the 3M backing Pad for the AGC, I tried using the Scotch-Brite™ Precision Surface Conditioning Discs on the RAS 115. Initially they held fine until the RAS was removed from the surface, at that point the RPM's increased and the discs would usually jettison themselves from the sander.
I really like the Surface Conditioning Discs as they impart a nice uniform finish to the metal. They aren't nearly as aggressive as the Scotch-Brite™ Clean & Strip discs.
The Scotch-Brite™ Clean & Strip discs work well for striping paint, coatings, adhesive or mill scale and rust. They don't load-up but they do leave a very slight surface texture. It would be best to then paint the surface (powder coating would probably be ideal) or if you want a more decorative finish, further refine the surface using the Scotch-Brite™Precision Surface Conditioning Discs.
Here's a RAS Scotch-Brite™ pad with an aluminum round placed on top and a Scotch-Brite™ Precision Surface Conditioning Disc with the same aluminum round. Quite a difference in stiffness.
A sample of the 5 grits available, extra course, course, medium, fine & very fine.
Here's the 3M backing pad. It comes with 3 different sized nuts for 10 mm, 14 mm or 5/8-11 threads. The plastic piece fills in the middle of the pad if the discs have 5/8" diameter center holes.
Here's a comparison of the hook & loop between the 3M pad and the RAS pad...quite significant.
The Precision Conditioning Disc and a comparison to the Clean & Strip Disc.
