Author Topic: Sloted C-Chanel for making table tops  (Read 1620 times)
Offline bholmsten
« on: February 14, 2023, 05:36 PM »
I am planning on building a kitchen table from old lumber that has sentimental value for my friend.
I've seen on YouTube where people router a slotted C-Chanel under the table top for support and expansion contraction issues.
If I use Domino-XL and wood glue for joining the boards lengthwise edge grain is the C-Chanel needed?
« Last Edit: February 14, 2023, 05:51 PM by bholmsten »
Offline nvalinski
Re: Sloted C-Chanel for making table tops
« Reply #1 on: February 15, 2023, 09:21 AM »
I'd still recommend it. The dominoes would act similar to a spline joint/biscuits, which keeps the boards aligned with each other vertically so that the surfaces remain flush. But, with a wide table, the table as a whole is still able to cup/twist, even with the seams staying flush. The C channels act as a low profile reinforcement to keep the table flat, very similar to what the skirt of a more traditional table or piece of furniture will do.
Offline bholmsten
« Reply #2 on: February 21, 2023, 03:15 PM »
Thanks for your response
« Reply #3 on: February 21, 2023, 05:08 PM »
I’m confused by the photo. I suppose you’re asking about the (apparently) embedded strips but I can’t get past the table legs in this picture which are likely to cause the table to split if/when it dries. If the construction is done in winter when humidity is very low maybe it’ll be okay as the wood expands in the warmer months.
Offline Sparktrician
« Reply #4 on: February 21, 2023, 05:54 PM »
Blacktail Studio has a video you might want to watch regarding the use of embedded C-channel in tabletops.
« Last Edit: February 22, 2023, 08:53 AM by Sparktrician »
- Willy -
Offline Crazyraceguy
« Reply #5 on: February 21, 2023, 06:53 PM »
Yes, ^^^ slotting the C channels w/o doing the same on the legs is working against yourself.
That is a theme you have to carry through the whole job, including breadboard ends, if equipped.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Offline Peter Halle
  • Ain't so Small no More
« Reply #6 on: February 21, 2023, 08:00 PM »
When the word "slotting" is being used here, I hope that includes making the mounting holes for both the legs and the c-channel larger then the mounting screws or slotting those to allow for movement across the board.
« Reply #7 on: February 22, 2023, 08:55 AM »
Peter, take a look at the way Cam Anderson does it in the video I referenced.  I really like the way he seems to have thought it out to allow for expansion and contraction while routing for the C-channel.
- Willy -
Online Cheese
« Reply #8 on: February 22, 2023, 12:12 PM »
Thanks for that Sparky...that was well worth watching.  [big grin]
Love the screw inserts with the cup point set screws, great idea.
The Murakoshi style bolts was certainly interesting along with the Concept 13 c-channels.
Would like to know more about the N3 Nano coat, there's really no information on the web site.
« Reply #9 on: February 23, 2023, 01:52 PM »
Yes, that video was very good! I’m going to check other videos of his.
I’m also going to borrow the adding a router template to the work with double stick tape technique.
Offline luvmytoolz
« Reply #10 on: February 23, 2023, 03:28 PM »
I love his videos and actually signed up for his epoxy course which is brilliant, but that's the one thing I really don't understand with Cam, he uses c channels from one supplier in standard sizes, but doesn't have a one piece template for the sizes he uses, makes no sense to me. I do loads of template routing and find it's far easier and simple to make a single template in MDF big enough to just clamp down.
No tape needed, no possible movement or error.
« Reply #11 on: February 23, 2023, 04:59 PM »
I agree. He could  easily make a pair of L shaped templates he could slide together to make slots of different lengths for the same channels. If I have to do the same operation more than three times I’ll make a real template or jig. If it’s more complicated than drilling holes.
But I do think that technique looks good for quickly one off templates.
« Reply #12 on: February 23, 2023, 06:41 PM »
This is a perfect application for the now-gone MFS.  Just sayin'...   [crying]
- Willy -
Offline rst
« Reply #13 on: February 23, 2023, 06:42 PM »
Sparktrician...Word!
