Author Topic: Sawing 1/4" thick UHWM  (Read 1734 times)
Offline krudawg
« on: February 15, 2023, 12:13 PM »
Can I cut UHWM on my table saw with a wood saw blade?
Ted
MFT/3, DF 500, Hammer K3 Winner, TS55,  Sjoberg Elite 1500 Workbench, Fuji MiniMite4 Platinum, OF1400, CT MIdi, CT26, RO90, ETC-150, OF1010 EQ-F
Former Marine, Vietnam Vet
Offline Svar
Re: Sawing 1/4" thick UHWM
« Reply #1 on: February 15, 2023, 12:20 PM »
Yes, cuts like butter.
Online rvieceli
« Reply #2 on: February 15, 2023, 12:45 PM »
Machines pretty much like wood. Cut, drill, router with regular wood tools. Edges will probably be sharp may want to know then down with a sanding block.
Ron
Offline MikeGE
« Reply #3 on: February 15, 2023, 03:23 PM »
I cut the sacrificial strips for my MFT-style workbench from a sheet of 5mm thick UHWM using my slider saw.  It took me over an hour to clean up the mess because the static cling caused the UHWM chips to stick to the inside of the saw rather than be sucked up by the dust extractor.
It did cut like butter, but very messy butter.
Offline krudawg
« Reply #4 on: March 01, 2023, 10:22 PM »
I had a 10" Forrest Duraline AT blade but I gave Forrest a call and he said it would tear it up.  So on his recommendation, I bought another Blade and it cut the UHMW very cleanly - some byproduct had to be cleaned up but other than that, It worked great
Ted
Offline Crazyraceguy
« Reply #5 on: March 02, 2023, 05:42 PM »
A zero-rake triple-chip (TCG) blade will give you the best finish/feel on the edges, but pretty much anything will cut it. It all depends on what you are expecting from it and ultimately how much of this you need to do.
A dedicated blade is a good way to go, if the volume makes it worth the cost.
U-H-M-W
Ultra
High
Molecular
Weight
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Offline morts10n
« Reply #6 on: March 02, 2023, 11:44 PM »
Buy it at requirwd thickness from a plastics supplier
Offline krudawg
« Reply #7 on: March 04, 2023, 11:22 PM »
That UHMW is expensive!  I live in the Phoenix area and called two plastic places and one of them said my order was too small (I wanted a 13"X48"  1/4".  The other place I called in Phoenix directed to their plant in PA or someplace as that is the only plant that sells small orders so I ordered one.  I wanted to save on shipping and said I could pick it up locally and was told my order was too small for me to pick up at the plant in Phoenix.  It shows up finally and it was 24"X48"  1/4" thick - I had to rip it to size.  The Cost, with shipping $285.
Ted
« Reply #8 on: March 05, 2023, 07:58 AM »
What flavor of UHMW PE? Did you check out McMaster.Com? They stock a dozen varieties ranging in price from $90 to $240+ for the same size.
Offline krudawg
« Reply #9 on: March 05, 2023, 09:00 AM »
I'll check it out. thanks
Ted
Offline squall_line
« Reply #10 on: March 05, 2023, 11:16 PM »
McMaster is likely the way to go, but you won't be getting a custom size; it'll be stock sizes like you found.
1/4" white UHMW 24x48 is about half as much as your number, ground-shipped to my door from Chicago.  25% of the total bill is shipping.
Shipping is the killer when you start talking about objects with a 4-foot dimension in any direction, honestly.
Online rvieceli
« Reply #11 on: March 06, 2023, 06:54 AM »
@squall_line McMaster does do (sort of) custom cuts on 1/4 and 1/2 white UHMW sheets.
The sort of is that only offer two ranges in sizes. If your piece fits within a 29x29 square or a 48x60 rectangle. Unfortunately on the bigger sizes the widths don't cross over they start at 30 inches. So if you need a piece 29 or under wide and longer than 29, you are out of luck.
https://www.mcmaster.com/products/plastics/slippery-uhmw-polyethylene-sheets-bars-and-strips/
Scroll down to where it says
Additional White Sheet Sizes
Ron
« Last Edit: March 07, 2023, 02:21 AM by rvieceli »
Offline Quasinerdo
« Reply #12 on: March 22, 2023, 02:03 AM »
For small dimension pieces is the material quality of chopping boards the same as what is being provided by larger suppliers?
I'm thinking of use cases like sliders for T-Slots, small bushings and such. Unsure what else people use it for in the workshop... but interested to learn :D
« Reply #13 on: March 22, 2023, 09:50 AM »
Nowadays most plastic cutting boards are made of polypropylene not polyethylene. If the board is PE it should be as good for other purposes as raw stock but if it is PP don’t buy it. I bought a few plastic cutting boards to make vacuum clamps and there was a molded in texture I had to remove and in the process discovered that the stuff is uneven in thickness. Also, it’s milling characteristic is somewhere in between PE and styrene. PE is much better to work with.
A brief comparison of the different types of polyethylene.
Offline rst
« Reply #14 on: March 22, 2023, 05:39 PM »
I used some to make a dovetail cutting slot in my MFT, I can slide it in to replace.
Online rvieceli
« Reply #15 on: March 22, 2023, 06:40 PM »
I believe that the majority of the poly cutting boards available through a commercial kitchen supply house will be high density PE in varying thicknesses.
I'm also a big fan the IKEA Legitim cutting boards. Seems to be HDPE, has a slight texture and is reasonably flat and consistent in thickness. They are 13.5x9.5x.25 inches. Used to be able to pick them up for 1.99 but are now 3.99.
Use them as backers on the drill press, sliders, shims, washers, etc.
https://www.ikea.com/us/en/p/legitim-cutting-board-white-90202268/
Ron
