Author Topic: Removing old door window putty/silicon  (Read 11501 times)
Offline Untidy Shop
« on: December 18, 2013, 10:28 PM »
I am currently restoring an old cedar door.
In attempting to scrape old putty (and silicon from someone's 1/2 backed restoration), I have just cracked the glass. Fortunately the glass only covers top 1/3 and I am sure it can be replaced.
However for next time, and for removing what's left, does anyone know what will soften hard putty, or is it a matter of scraping,scrapping?!
It has just hit 40C here so will not be back to it today.
With appreciation.
Offline Peter Halle
Re: Removing old door window putty/silicon
« Reply #1 on: December 19, 2013, 12:58 AM »
A heat gun will usually soften old glazing compound and allow it to be scraped out.  To be honest I haven't tried it for silicone.  There are products out know that will soften silicone to allow for better / easier removal.
Offline jools
« Reply #2 on: December 19, 2013, 01:56 AM »
Heat guns and glass don't mix so only really useful on cleaning rebate after glass removal.  Softness achieved with heat depends on oil content/age weathering etc. I usually remove old potty with a hacking knife if glass not antique,and retained. If glass wanted remove with a Fein mm  Silicone responds better to mechanical scraping after it has been heated
Regards
Jools
It started with one little sander
Offline Motown
« Reply #3 on: December 19, 2013, 04:47 AM »
I have just done this for french casement windows (swing open versus up and down) and because their were 137 total windows I used a piece of scrap ply and wrapped it in tin foil to protect the glass from cracking as i worked to remove the putty. Worked well.
Offline Untidy Shop
« Reply #4 on: December 20, 2013, 07:07 AM »
Thankyou all for your ideas/experiences, much appreciated. [smile]
Offline R. Beverly
« Reply #5 on: December 23, 2013, 11:32 AM »
Thirty years ago, I re-glazed an old house full of windows with the tool shown.  No longer manufactured, but it looks like they show up on eBay occasionally, selling for around $50.  It appears parts are still available; Google G&H Electric Putty Softener.
This tool works very well - no damage to glass, no damage to wood.  I would bet, however, that the insulating elements are asbestos.
Dick Beverly
Offline lillianhofstader
« Reply #6 on: February 14, 2014, 12:32 AM »
My husband had used prazi usa's putty remover, it is attached to a power drill to remove stubborn putty. It also consist of a handle that helps the user to guide the drill, and the tool's rotating chisel cuts the putty from the window.
Offline Untidy Shop
« Reply #7 on: February 14, 2014, 02:18 AM »
Thanks for that Lilian.
In the end, I found that Selleys Putty Remover was effective.
And welcome to the FOG.   [smile]
