I have had good results with FastEdge. Havn't had any call backs on it. I know some people love it and some hate it. From what I understand the the adhesive is basically CA (superglue). It is really sticky so handle with care when peeling and applying. I have found that I get the best bond by rolling between each step. I use the Virutex end trimmer, FastCap roller (works really well) , FastCap edge break sander , FastCap carbide edge trimmer.
Stick it on... roll
Trim ends ..... roll
Trim edge .... roll
Sand edge .... roll
Sounds tedious but if the tools are all at hand it goes fast and gives a good bond.
I especially like using the prefinished when I am using prefinished plywood. Just makes the whole deal a big time saver.
