Author Topic: Question about metric size plywood.....  (Read 6407 times)
Offline BigCountry73
« on: March 01, 2015, 10:57 AM »
This might be a stupid question, but I will ask anyway.......
When purchasing metric size plywood are the dimensions true? For example does 19mm thick plywood actually measure 19mm? Or does it vary like the imperial measurements?
Thanks,
Keith
Offline Peter Halle
Re: Question about metric size plywood.....
« Reply #1 on: March 01, 2015, 11:50 AM »
Keith, I believe that the measurements are true.  If you have been buying imperial plywood like most of us in the US you have actually been buying metric thickness plywood with imperial panel sizes.  Take a metric tape measure off the wall at one of the big box stores and check it out.
« Reply #2 on: March 01, 2015, 03:31 PM »
Thanks for the reply Peter! That is what actually primed my interest. I want to start building cabinets for my garage and use the metric system because of its simplicity. When I measured my 3/4" plywood with a digital caliper it measured just shy of 19mm.
I guess I am good to proceed.
Thanks,
Keith
« Reply #3 on: May 20, 2015, 04:18 PM »
Yes, in my experience most of the properly stored metric sized plywood sheets are true in size.
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Offline Mr Heavy
  • Clamps? Who needs clamps?
« Reply #4 on: May 20, 2015, 06:59 PM »
... except in the U.K.
running a caliper on 9mm gives me 8.5
 ?? = 9.5
12 = 10.5
15 = 15
18 = 18
 6  = <5.5
Sys4 with cheese sandwich, a small pork pie with Tabasco sauce, a nice bottle of dry, vintage Prosecco and three reusable ice packs. Olives with pimento and a capon, roast in Dijon mustard. Several slices of fresh pineapple, a scale model of the Eiffel tower made from noodles, black forest gateau and a gingham table cloth for the MFT-3. A block of Parmesan and a Stanley 2" chisel for grating.
Sys3 with a half bottle of La Fée Absinthe, a spoon and vodka-soaked mint with Rothenberger blow-torch.
125 year old balsamic vinegar in spray bottle.
Ibuprofen and a pair of handcuffs. 2 loaves, 5 (very) small fishes, some bread, broken. A goblet of blood-red wine, a hammer... nails
Offline mike_aa
« Reply #5 on: May 20, 2015, 08:38 PM »
That is if you can find a metric one!  YMMV, but I asked for one in the local orange box store and the clerk who thought they had one tape in metric, searched for a while and discovered they no longer carry them.
Mike A.
Offline carlb40
  • Site carpenter
« Reply #6 on: May 21, 2015, 08:22 AM »
 ?? = 9.5
12 = 10.5
15 = 15
18 = 18
 6  = <5.5
Yeah there doesnt seem to be a decent set standard for ply in the uk from what i have seen over the last few years.
Far too many variances in thickness lately. Even when we have had full pallets of 18mm ply, sheets vary by up to 1mm or more in thickness.
Carl
Never never go, never never know [smile]
Flickr
Offline Trickie
« Reply #7 on: May 21, 2015, 05:35 PM »
I built Tim's MFTC from 12mm ply from Wickes which actually was 11mm. Didn't realise until the push release drawers weren't catching right. Only then did I think to check. Nothing a wee packer didn't sort but slightly irritating. The 18mm also comes in at 17mm. Always worth checking.
« Last Edit: May 21, 2015, 05:44 PM by Trickie »
