Author Topic: Polyurethane Glue and Domino Joinery  (Read 3776 times)
Offline jeffinsgf
  • Woodpeckers Marketing Department
« on: January 06, 2023, 01:27 PM »
Opinions? I use polyurethane (Gorilla) glue pretty frequently. I recently used it on a project with a lot of Domino joints and started over-thinking the whole situation. The first advantage I see is poly's expansion. Even die-hard Domino fans have to admit, they aren't exactly the tidiest glue joint fit. They're not even close to the fit most serious hand-tool woodworkers expect on a mortise and tenon. PVA glues rely heavily on wood to wood contact...poly...not so much.
Next advantage is application. I used an acid brush to spread the glue in the mortise and wrapped the Dominos in a wet paper towel a few minutes before assembly. When I use PVA, I apply to both the mortise and the Domino, which takes longer and increases the chance of getting too much in the joint.
Finally, clean up. I am firmly in the camp of "leave it alone until it's dried and then clean it off with a chisel" (regardless which kind of glue). I find dried poly comes off easier and cleaner than dried PVA. There's less final residue and it requires less sanding to ensure no ghosts in the finish.
So, I'm leaning toward using polyurethane on all Domino joinery in the future. I'd love to hear from anyone with an opinion on the matter, one way or the other.
Offline Frank-Jan
Re: Polyurethane Glue and Domino Joinery
« Reply #1 on: January 06, 2023, 01:52 PM »
I think this is the first thread I have read complaining the domino mortices are not tight enough.
« Reply #2 on: January 06, 2023, 02:02 PM »
I usually only glue Dominoes when one of the parts presents end grain.
I use PU glue even less often. The wet glue is a mess to get off my hands.
And it seems to be much weaker than aliphatic resin glues.
Isn’t it difficult to put a swollen Domino (“wrapped in a wet paper towel”) into the mortise?
I agree that dry PU glue is easier to remove.
To deal with glue squeeze out I try to turn clamped assemblies so that the glue line is vertical. Any wet glue runs along the joint instead of across the face of the board. There are several ways to deal with the  excess glue after that.
« Reply #3 on: January 06, 2023, 02:10 PM »
I’ve put Dominoes in the microwave to shrink them but I’ve never needed to make them swell, even when not using glue.
If Jeff’s mortises are noticeably bigger than the Dominoes maybe his bit or machine are bad?
I think he just means the edges of the Dominoes which not match the round profile made by the bit. Maybe deliberately in order to avoid hydraulic blow out. If a custom Domino perfectly matched the mortise you’d have to be sure the glue applied was just enough.
Offline MikeGE
« Reply #4 on: January 06, 2023, 02:38 PM »
Here are two YouTube videos from Bradshaw Joinery showing his use of PU glue on projects.
Offline Packard
« Reply #5 on: January 06, 2023, 03:20 PM »
I was an early adopter of the PU hot glue gun system.  It was expensive to get into it because the glue gun cost a couple of hundred dollars, and there was minimum purchase quantity to buy the glue sticks.  But the reviews (in industrial magazines) were terrific, with very high strength and a super nifty glue gun that was not wired to the charging holder.
I invested in this because I thought it would speed up production in my picture frame shop.  It read like it would.  I could glue and join a frame and then start fitting the art/mat/glass and mounting boards immediately.
We were using pre-finished moldings,  The PU glue left a black line at the joint and so was unusable.  I think I’ve used it twice after that.  I’m not sure where it is, but in my basement somewhere.
My point is, when entering a new tech, the information available is what applies to the type of work the reviewer is performing.  It might not mention some crucial aspect of the system that could mean thumbs down on the product for your application.
What is the open time for this adhesive?  I tried making a furniture repair (damaged by the moving company) using Gorilla glue (polyurethane).  The glue expands as it cures and pushed the joint open.  A strong joint, so it is impossible to take apart and re-glue.  An 1/8” gap where there should not be any gap.
If I knew about the expanding, I would have used a beefy clamp.  It was a dowel joint that appeared to be solid.  I don’t think I used a clamp—I think I used a bungee cord wrapped around the piece.
Make some tests before committing to the new glue.
What advantages does it hold for you?  I use Woodworkers’ III for general glue-ups.  I like the long open time.  I use hide glue for cane work, and Corner Weld (a picture framers’ glue) which has a extremely short open time and tacks up in a minute or less.  Handy when gluing up picture frames where assembly is almost instantaneous.
Offline jeffinsgf
« Reply #6 on: January 06, 2023, 04:07 PM »
My Domino is fine. My fit on the thickness is spot on. Like everyone else, I have to use pliers to extract dry fit Dominos. The issue is the ends. I understand the air gaps for hydraulic expansion, but that detracts from mechanical strength of the joint. And if you switch to a wider setting, you're getting no mechanical strength in that direction at all. I have found the expansion of polyurethane to fill those gaps and create what I think are better bonds.
I don't "need" to make the Dominos swell. The directions for Gorilla (and other polyurethanes) say to dampen one surface and apply glue to the other. Wrapping the required Dominos in a wet paper towel was my quick and dirty way to dampen the surface while I was applying the glue to the mortises.
Offline jeffinsgf
« Reply #7 on: January 06, 2023, 04:22 PM »
Not complaining at all. Domino mortises are perfectly fine in thickness, but by design they do not fit very well on the ends. All I'm saying is polyurethane glue can help create a better joint by filling the designed gaps as it cures.
Offline Packard
« Reply #8 on: January 06, 2023, 04:37 PM »
You are suggesting that filling the slot at the ends of the domino will add strength?
I don’t see how it would.  And of that gap were filled with glue, the PU would try to force the domino out of the slot making new demands on clamping.
Has anyone ever done testing on dominoes, dowels or tenons suggesting that PU offers greater strength than other glues?
If that gap causes weakness, then I should drill shallower holes for my dowels.  I always leave about 1/8th of an inch gap at both ends of the dowels.
Offline squall_line
« Reply #9 on: January 06, 2023, 04:56 PM »
A wide mortise could potentially weaken shear strength by providing an air gap for the tenon to move laterally, but I would think that it would depend on the grain orientation of the joint as well as the loads encountered.
I thought that at least one method of mounting breadboard ends to account for expansion/contraction was to mill wider mortises on the table side and leave out the glue on most of the wide mortises while leaving the breadboard end tight and glued, but I've never actually built a table, I've only read about it.
Offline ChuckS
« Reply #10 on: January 06, 2023, 05:06 PM »
This fellow uses polyurethane glue for furniture making though I'm not aware of people I know who use it:
https://www.finewoodworking.com/2016/11/02/polyurethane-is-my-go-to-glue
I once was given a bottle of such glue at a trade show, probably 15 years ago. I never got to using it before I threw it away, so I couldn't say how good it was.
I have had no concerns using yellow glue in any Domino joinery. As part of my routine, all joinery done regardless of its type is tight, cut whether by hand or by machine, so I guess I don't come to wondering if I need gap-filling glue or not in my work. For joinery work, I only use two types of glue: PVA or Old Brown Glue.
Norm Abram did use polyurethane glue in a couple of outdoor projects.
« Last Edit: January 06, 2023, 05:09 PM by ChuckS »
Offline jeffinsgf
« Reply #11 on: January 06, 2023, 05:25 PM »
I suppose I should have said edges rather than ends. I am talking about the rounded edges of the mortise and the rounded edges of the Dominos not fitting tightly to each other. I think, with no empirical evidence, that polyurethane glue makes a better joint than PVA, and even if it is only as good... it is faster to spread, clamp and clean up.
I will agree that cleaning it off your hands is impossible. That's why I use gloves.
Offline mrFinpgh
« Reply #12 on: January 06, 2023, 05:34 PM »
I have used it to good effect for veneering (it's good for repairing bubbles) but generally I prefer not to use it.  It's messy, and the chemicals from the curing process are a bit nasty to spend time around.
I don't think it adds anything structurally to the M+T joint if you are counting on the expanding foam to provide support/strength.  Generally a little room on either side of the joint is fine as the long grain to long grain connection is where all the holding power is coming from.  I guess if all other systems failed, the tenon to mortise connection might be providing something, but if I need that kind of stability, I'm probably not using Domino joinery in the first place and I'm probably drawboring that joint.
I much prefer to clean excess glue off ASAP.  Usually scooping off the bulk and hitting the rest with a toothbrush and some water, wiping it dry once I'm done. This doesn't hurt the joint, and I've never had any issues with finishing as long as I really get it all cleaned up.
Offline luvmytoolz
« Reply #13 on: January 06, 2023, 06:18 PM »
I've used the Gorilla PU on some projects, and apart from the nuisance that it dries in the bottle if not used up quick enough over time, found it gave no filling strength at all which was a surprise. Once you break the touch outer skin, it's very soft inside and takes hardly any force to compress.
For wood to wood gluing it's great, apart from the glue line on some timbers, but doesn't add anything apart from being good for moist/wet areas.
Offline Crazyraceguy
« Reply #14 on: January 06, 2023, 06:19 PM »
I have never really seen the need for Poly glue, like Gorilla, for what I do. The only time I ever did was when gluing steel threaded rods into some wooden spindles. They were a turning project that held an oval mirror between them.
I don't do outdoor projects and Tite-bond has always had a product that suited my needs. Usually 2 or 3  or the thick stuff for trim.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Offline luvmytoolz
« Reply #15 on: January 06, 2023, 06:24 PM »
Yeah TB's my go to glue, I get invisible seams, and the joint is wickedly strong. It'd be nice if they released a TB1 with a long open time though as I do a lot of bundles of laminated strips, and it gets very messy and tricky very quickly.
A mate was asking what glues to use for some projects so I gave him cutoffs from some glue ups and told him to break them. All of them broke in the wood, none at the joint. He was impressed to say the least!
Offline TinyShop
« Reply #16 on: January 06, 2023, 06:49 PM »
For future reference, cooling Tite Bond glues down in the fridge/cold ambient temps is what the manufacturer recommends to vastly increase the working/open time. Learned this trick from AskWoodMan of VSC Tools.
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline ChuckS
« Reply #17 on: January 06, 2023, 07:35 PM »
I don't know about cooling the glue to increase the open time (I couldn't find anything on the Titebond site about that), but I put unopened glue in the fridge to extend the shelf life:
http://blog.titebond.com/page/how-to-store-your-wood-glue-for-longer-life
P.S. Same for OBG.
Offline luvmytoolz
« Reply #18 on: January 06, 2023, 09:11 PM »
I did try the fridge once but it doesn't help me in my case as glue sessions can go for the bulk of the day, and I found putting it in and out constantly too time consuming. Plus my shed's really well insulated so doesn't get too warm at all despite the summers in OZ.
In lieu of a much longer work time, what I do need is a method to rapidly and fairly evenly spread a thin layer of glue on thin but long faces so I can get them in the clamps quicker.
To speed things up a little i'm working on a pneumatic ram at the moment for the initial and inbetween holding, and have been looking into the various hand held glue spreader tools around (like the Virutex ones), but they all seem a bit crappy really. I may end up needing to make one myself but really don't want to if I can avoid it.
Offline Packard
« Reply #19 on: January 07, 2023, 10:47 AM »
Re-freeze-able can cooler might work.  You would be limited to the round containers wood workers 1, 2 & 3 offer.
Note:  I have not tried this.  However, if chilling works, then this should work also.
« Reply #20 on: January 07, 2023, 12:52 PM »
Never tried chilling the glue but wouldn’t the increase in viscosity be a drag?
Online TSO_Products
    • TSO Products LLC
« Reply #21 on: January 07, 2023, 01:14 PM »
@jeffinsgf  - interesting topic - I wonder what actual problem led you to consider gap filling adhesive. Did you have some failures or did you see test results pointing to a weak and deficient joint? - any unusual requirements associated with your project?
Hans
Offline jeffinsgf
« Reply #22 on: January 07, 2023, 02:41 PM »
Hans
What failures I've had (which are very, very few) have been associated with trying to get away with only spreading glue on the mortise. As long as I spread on both the mortise and the Domino, I've had zero failures in hundreds of Domino joints.
On a recent project that had a fairly complicated assembly I decided to use Gorilla Glue and dampen the Dominos to speed up the glue spreading. Turned out that in my "design on the fly" process I made a rather large math error and had to cut a couple joints apart and shorten up the legs. The cut apart joints looked amazingly tight. The glue had expanded into every crevice on the round ends of the Dominos and unlike the foamy look of what oozes out on the surface, the glue was rather dense and hard.
I also have an outdoor table glued together with Gorilla Glue that has 5 Northeast Ohio winters under its belt and all the joinery is as tight as the day I took the clamps off.
Just seems like a good choice for Domino joinery to me. YMMV
Offline Packard
« Reply #23 on: January 07, 2023, 04:05 PM »
Dowels, biscuits, and I assume dominoes also, depend upon moisture to swell the components for a really tight fit.  Water-based glues provide that moisture.  I’m pretty sure that Gorilla glue is not water based.
So I wonder how much strength is sacrificed by giving up on the swelling of the dominoes that is lost by not using a water based glue.
Offline rst
« Reply #24 on: January 07, 2023, 04:26 PM »
Polyurethanes not only do not swell but need moisture to cure.
Offline jeffinsgf
« Reply #25 on: January 07, 2023, 04:27 PM »
Poly needs moisture to cure...hence the recommendation to moisten at least one side of the joint. I thoroughly moistened the Dominos before inserting them. I'm pretty sure they expanded just as much as they would have with PVA.
Offline Packard
« Reply #26 on: January 07, 2023, 04:34 PM »
I recall the advice to “paint the joint with water” prior to using Gorilla glue.  And like you said, for curing.
I don’t think we have much more than opinions on the topic.  I wish there was some actual data to hang our hats on.
I did test the strength of different types of glue, specifically Corner Weld, a glue designed for the picture framing industry and largely replaced the white glue (Elmer’s) that was in wide use at the time.  I tested that, and there was no comparison.  The Corner Weld was vastly stronger.  They advertised it as being engineered for “end grain to end grain” adhesion.
I re-tested that 30 years later and compared it with Woodworker’s III.  I only tested three samples of each on end grain to end grain and they performed almost identically.
The big difference was that Corner Weld has extremely short open times, and will tack up in 30 seconds to a minute.  Which is OK for the picture framing industry, but is a problem for almost everyone else.
If I were still in the framing business, I would switch to Corner Weld (my current glue is Woodworker’s III).
Online TSO_Products
    • TSO Products LLC
« Reply #27 on: January 07, 2023, 08:39 PM »
@jeffinsgf  - If your looking at other high strength adhesive options, RESORCINOL can provide extremely strong connections PROVIDED the joint is close fitting. You might find it interesting from a strength standpoint. A two component systems (powder and liquid). can be used with heating during the assembly to speed up cure time. Open time is not unusually long at room temp. It is not designed to be gap filling - just ulra high strength structural wood connections. Unlike Epoxy, it is not affected by heat or sunlight UV exposure. Available through industrial supply sources only in my experience.
Hans
Offline luvmytoolz
« Reply #28 on: January 08, 2023, 03:40 AM »
Hans
We used to use resorcinol for laminating F17 structural beams in the timber mill, really good adhesive, but leaves a very distinct brown line. Bugger to clean up once dried too.
Offline jeffinsgf
« Reply #29 on: January 08, 2023, 09:33 AM »
Hans
And quite possibly the nastiest smell I've ever experienced. I went through that mess exactly one time. Never again.
Offline Packard
« Reply #30 on: January 08, 2023, 10:01 AM »
Here is a fairly comprehensive article on resorcinol.  It does not read like a product appropriate for type of work I do.  But read and make your own decision.
https://www.christinedemerchant.com/adhesive-glue-resorcinol.html
Offline RandyBowman
« Reply #31 on: September 04, 2023, 09:51 AM »
The expansion properties of polyurethane glue could indeed address the challenges posed by less-than-perfect Domino joint fits. It's a valid point that polyurethane glue doesn't rely solely on wood-to-wood contact, offering potentially stronger bonds.
The application process you've described, using an acid brush and a wet paper towel for wrapping, seems efficient and focused. This could potentially save time compared to the traditional method of applying PVA glue to both the mortise and the Domino.
For those interested in delving deeper, https://www.meiboom.eu/epdm-lijm/ could offer additional insights into specific glue types. It's always beneficial to gather a range of information to make informed decisions about the materials and techniques you employ.
« Last Edit: September 05, 2023, 05:49 AM by RandyBowman »
Offline ChuckS
« Reply #32 on: September 04, 2023, 11:02 AM »
"less-than-perfect Domino joint fits"
What does this mean or any examples?
Offline Packard
« Reply #33 on: September 04, 2023, 11:20 AM »
I would note that I used polyurethane glue once.  It was a difficult piece to clamp, so I used a bungee cord for that purpose.  An error.
The glue expanded and partially opened the joint.
If you are going to use polyurethane glue, make sure the joint is securely clamped.
