I was an early adopter of the PU hot glue gun system. It was expensive to get into it because the glue gun cost a couple of hundred dollars, and there was minimum purchase quantity to buy the glue sticks. But the reviews (in industrial magazines) were terrific, with very high strength and a super nifty glue gun that was not wired to the charging holder.
I invested in this because I thought it would speed up production in my picture frame shop. It read like it would. I could glue and join a frame and then start fitting the art/mat/glass and mounting boards immediately.
We were using pre-finished moldings, The PU glue left a black line at the joint and so was unusable. I think I’ve used it twice after that. I’m not sure where it is, but in my basement somewhere.
My point is, when entering a new tech, the information available is what applies to the type of work the reviewer is performing. It might not mention some crucial aspect of the system that could mean thumbs down on the product for your application.
What is the open time for this adhesive? I tried making a furniture repair (damaged by the moving company) using Gorilla glue (polyurethane). The glue expands as it cures and pushed the joint open. A strong joint, so it is impossible to take apart and re-glue. An 1/8” gap where there should not be any gap.
If I knew about the expanding, I would have used a beefy clamp. It was a dowel joint that appeared to be solid. I don’t think I used a clamp—I think I used a bungee cord wrapped around the piece.
Make some tests before committing to the new glue.
What advantages does it hold for you? I use Woodworkers’ III for general glue-ups. I like the long open time. I use hide glue for cane work, and Corner Weld (a picture framers’ glue) which has a extremely short open time and tacks up in a minute or less. Handy when gluing up picture frames where assembly is almost instantaneous.
