An interesting fact I read about bamboo. They do not stain bamboo to give it the darker colors. They roast it. They make a big deal over the fact that roasting the bamboo means the color goes all the way through. Clearly, that is an advantage.
Plus bamboo is a very hard surface. Harder than maple.
What they overlook, is that the roasting process both softens and weakens the bamboo. The darker the color (from longer roasting) the weaker and softer it gets.
I have not seen any data on how soft it gets, but if the lighter color works for you (and your wife), then there is an advantage going with that.
I like Confirmat screws on sides of cabinets where they will not show. They are extremely strong and can be removed and replaced several times. So dry fitting is a breeze, especially since no clamping is required.
There are lots of YouTube tests online of the relative strengths of various fastening systems. Almost all of these tests are flawed as they only test one sample of each. A minimum of 10 samples would be needed to convince me of the superiority of any system.
Years ago, I found online tests run by a kitchen manufactures association (KD kitchen cabinets) and also one by the flat-pack furniture industry association (think “Ikea”).
These tests were performed by outside testing laboratories. Those tests a almost certainly still out in the google wilderness somewhere.
I was surprised to learn that dado joints offered almost no racking strength. Screws were slightly better. Those 1/4 turn assembly dowels fared poorly too.
They did not test dominoes as dominoes are not suited for high volume production.
Their conclusion was that dowels and confirmats were the clear strength leaders. Dowels had the advantage of some sophisticated automated systems for assembly. Confirmats offered more racking strength and could be broken down and reasssmbled several times.
I settled on dowels and confirmats as a result.
It was noted that the K.D. furniture people needed racking strength (to avoid the wobble), where cabinets did not (they had the wall as part of their structure).
I think dowels, dominoes and confirmats are fine. Using the right glue would be important.
Polyurethane glue (Gorilla glue) retains some flexibility and that might be an advantage in an environment where there might be a lot of flexing.
I would also look at marine cabinet construction. They have to live with many of the same stresses as a camper.
Good luck. (I have too much time on my hands so I tend to long posts).
![Eek! [eek]](https://www.festoolownersgroup.com/Smileys/default/eek.gif)
