« Reply #1 on: July 03, 2022, 04:25 PM »
Would you not just use a piece of rubber vacuum/fuel/oil/water hose? Lots of options to match the drilled hole bore and the mounting rod/studs.
It'll cost you pennies at your local auto parts store for a short piece to suit.
TKS 80 EBS-SET, KS 60 E-Set, TSC 55 REBI, TS 75, HKC 55,
DF 500 & DF 700, OF2020, OF1010 REBQ, OF1010 EBQ, OFK 500,
T18+3, C18, PDC 18/4, TID 18,
RO 150, RO 90, RAS 115, RTS 400, ETS 125, ETS 150/5,
EHL 65, HL 850 EB,
CTL 26 E, CTL MIDI I, CTL-SYS, CT-VA-20
VAC SYS w/ SE1 & SE2, MFT/3, SYS PowerHub, DUO SYSLITE, & KAL.
