Author Topic: Make your own dry-erase boards  (Read 1592 times)
Offline Packard
« on: May 09, 2022, 01:29 PM »
Porcelain is the ideal surface for dry erase boards and the institutional dry erase boards (think "schools") are all made from steel that has a porcelain surface fired on it.
But you can easily make your own using 12" x 24" or 24" x 24" glossy porcelain tiles.  White works best, but I've used "marble" designs with very pale markings.
These tile wipe perfectly clean.  I even am able to use "permanent" Sharpie markers on the tiles.  the permanent marking does require spraying with alcohol to clean the surface, but it will come perfectly clean.
So, if you need a dry erase board, glue a tile to a backer board and apply a picture frame molding to the perimeter.
It probably should be mounted using a french cleat or a similarly robust mounting system.  Picture frame wire will probably allow it to move around too much.
Offline hdv
Re: Make your own dry-erase boards
« Reply #1 on: May 09, 2022, 01:54 PM »
In the office we use glass sheets attached to the wall as whiteboards. Works great and looks good too. Easy to clean. The glass wasn't cheap, but that isn't a big surprise considering the sheets are seriously large and made from safety glass. I liked it so much I considered doing the same at home.
« Reply #2 on: May 09, 2022, 02:31 PM »
I purchased the raw material from these people. It's erasable metal chalkboard and will also respond to magnets.
https://www.billyboardsmfg.com/collections/frameless-chalkboards
I made the frame out of ash and painted it with a rattle can to match the existing cabinetry.
I routed a couple of magnets into the underside of the ash frame to hold the chalk holders & eraser. The Koh-I-Noor holders were chosen because they have internal mechanisms that are made from steel.
I made a wooden holder for the eraser and routed magnets inside to align with the magnets in the ash frame.
Offline Packard
« Reply #3 on: May 09, 2022, 02:59 PM »
I remember when the chalk boards in school were made from honed large slabs of slate.  Then the artificial slate chalkboards came along.  They did not accept the chalk as well nor did they erase as well.
How well do those chalkboards work?
« Reply #4 on: May 09, 2022, 06:24 PM »
I was pleasantly surprised with how well the Billyboard accepts chalk...can't tell the difference from the old school slate board.  [big grin]
The erasure though isn't as good as the slate or maybe it's the material used in modern erasers? Maybe modern erasers are made with recycled products? I take a damp cloth to the board every 3-4 weeks and that seems to work well.
Before I made this board the refrigerator was filled with sticky notes and pieces of paper held down with magnets...what a mess. I also use 2 different colors of chalk, one for items from the supermarket and a different color for all other items. I'd never go back to the way it was.  [smile]
Offline Peter Halle
  • XENA - #4 Coming 8/20/22
« Reply #5 on: May 09, 2022, 07:56 PM »
@Cheese  Beautiful kitchen!  I should have known that your attention to detail and love of cooking would shine thru.
« Reply #6 on: May 09, 2022, 10:44 PM »
Thanks Peter, but just to put this into perspective here are a couple of before shots.
The original fridge was nestled next to the bump-out for the chimney which was at that time needed to exhaust the furnace and the water heater, this took up almost 30" of valuable space.
However, once I installed a new furnace and then installed a Rinnai water heater, the chimney no longer needed to exist so down she went. That meant that room was now available to move the fridge over 30" which really gained us a ton of options for a small galley kitchen.
Offline Crazyraceguy
« Reply #7 on: May 10, 2022, 08:14 PM »
You can also buy 4'x8' sheets of HPL (plastic laminate) that are intended for this too. That what we use in the shop for temporary things. Lists of what to order, laminate inventory (check out) etc.
They also make one that is magnetic. Just don't cut it on your SawStop, at least without by-passing the mechanism.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline eschumac
« Reply #8 on: May 10, 2022, 09:55 PM »
Ditto on glass. You can paint the back side of the glass whatever color you want.
