@squall_line it's about the tips, more accurately, how many you have and how much adhesive you use at any one time.
The adhesive we use for solid surface material (Corian) works exactly the same way. Using a very small amount is rather wasteful, as it takes quite a bit to fill the mixing tube itself, but that's the way it is.
Of course the tips are available separately for it. We get them in bags of 100. The tube is much larger too, (500ml) and can be used many times. It does have an expiration date, but its well over a year.
If you leave the tip on the cartridge, it can harden back into the rest of the tubes. They should be removed and plugged with the original cap. You can continue to use it until it's empty, if you have enough tips.
That small retail package, they probably don't care. They assume you'll use it once and be done with it. It's very similar to "super glue". It comes in tiny packages because it will be hardened in the bottle before you get to use it again, but for commercial applications, it is available in much larger containers too.
