Author Topic: Worktop material MDF vs PLY  (Read 865 times)
Offline witox4
« on: August 18, 2020, 02:26 AM »
What is a better material to make Mft Style workbench. Birch Ply Wood or white laminated MDF. What it will be better.
Wysłane z mojego VOG-L29 przy użyciu Tapatalka
Offline Hawkeye0001
Re: Worktop material MDF vs PLY
« Reply #1 on: August 18, 2020, 04:12 AM »
Considering your worktop is going to get used and abused anyway I'd go with MDF. It's dirt cheap in comparison and every bit as durable and suitable for the job.
Offline witox4
« Reply #2 on: August 18, 2020, 05:50 AM »
Mdf with white layer it will be OK? 18mm
Offline Euclid
« Reply #3 on: August 18, 2020, 06:30 AM »
I'm not convinced that either is ideal.
If you were going to use this for track saw work and repeatedly putting kerfs into the surface, the ply would eventually splinter away from the top layer; laminated MDF - presumably melamine or similar - will leave unpleasantly sharp edges and potentially dull the blade more quickly. And a melamine surface would be more slippery than I'd want.
But, hey, depends very much on your planned use!
I'm using Valchromat.
Offline Bert Vanderveen
« Reply #4 on: August 18, 2020, 07:15 AM »
Festool worktops are made of a higher density material (HDF), which is the better choice. A good quality plywood would be my second choice. Laminated MDF — never.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Roseland
« Reply #5 on: August 18, 2020, 09:42 AM »
MDF and HDF tend to sag over time with humidity cycling, but ply has a softer and more easily damaged surface.
I recommend Valchromat (Axminster sell tops made of this) which doesn’t sag and has a durable surface.
Festool on their roadshows use phenolic faced (black) ply, if I’m not mistaken; alas they don’t sell them.
Andrew
TS55, MFT/3, OF1400, OF1010, CT26, RS100, ETS125, CXS, MFS400, DF-500, Zobos.
Offline Oldwood
  • Alberta, Canada
« Reply #6 on: August 18, 2020, 10:40 AM »
I have made tops from MDF, veneered 2 sides MDF and melamine coated MDF. We use what the supplier calls door grade MDF I think the last brand name was Plum Creek.
The melamine coating makes for very sharp edges on the holes and edges I did not care for it. The veneered panels work well and are a little stiffer than standard MDF but mostly we just use plain MDF.
I made some MFT replacement tops for Festool MFTs. They were identical to store bought in dimensions and drilling. I weighed the Festool top and the Plum Creek version thinking the higher density Festool version would weigh more than the medium density but the Plum Creek version weighed slightly more.
Confucius
