Author Topic: HELP PLEASE -How can I insulate a wooden lampshade top  (Read 24793 times)
Offline Frank Pellow
  • Toronto, Ontario and Lake Pivabiska, Ontario
« on: October 21, 2013, 12:30 PM »
A year or so ago I made a lampshade out of stained glass with a oak frame and top. But, the lightbulb was too close to the top  [embarassed] and resulted in this burning:
94622-0
I am rebuilding the lampshade so that I can use a bigger harp which will place the bulb further from the shade. I am wondering if there is some insulating material that I can attach to the wood as well.
« Last Edit: November 02, 2013, 08:10 AM by Frank Pellow »
Cheers,
               Frank (Festool connoisseur)
Offline Wuffles
Re: HELP PLEASE! -How can I insulate a wooden lampshade top?
« Reply #1 on: October 21, 2013, 12:45 PM »
Possibly missing the point here, but use an LED bulb. Won't generate as much heat and save you a few quid.
Tool list updated to reflect knowledge :: hammer, screwdriver, one pozi bit, and another bigger hammer.
« Reply #2 on: October 21, 2013, 02:08 PM »
I don't know much about led lights.  Can you get them with "standard" sockets and in tri-light?
Cheers,
Offline Mauri Motti
« Reply #3 on: October 21, 2013, 02:11 PM »
Hi frank,
yes you can. We have ones with the standard socket.
Offline copcarcollector
« Reply #4 on: October 21, 2013, 02:18 PM »
I agree on the LED bulb! But watch out, there are usually a few color temperature choices. I tried some in a ceiling fan and it was like being in a hospital corridor, stark, annoying white light. The next step down was daylight I think, much better! Expensive up front but you will probably never have to change it again.
Offline Wuffles
« Reply #5 on: October 21, 2013, 02:22 PM »
Yes people who buy "white" LEDs as a colour choice have generally never seen them. "Warm" white is closer to an actual bulb.
Not sure what you use where you live, but in the UK we have bayonet & screw fittings, all sizes are now available, most of them are around 3W and don't run hot enough to worry a hand let alone a lump of wood.
Hope that helps and saves time.
Offline johninthecamper
  • Festool Dealer
« Reply #6 on: October 21, 2013, 03:24 PM »
metal plate with a air space,mounted on the harp, small vents on the top ,in the wood
Re: HELP PLEASE -How can I insulate a wooden lampshade top
« Reply #7 on: November 02, 2013, 08:16 AM »
See what I ended up doing by looking at reply #16 in the thread: http://festoolownersgroup.com/member-projects/floor-lamp/msg283634/#new
Cheers,
