Author Topic: End grain, long grain, and wood movement  (Read 2195 times)
Offline 4nthony
    • Slack for Recon Tools
« on: May 10, 2023, 07:37 PM »
I'm rethinking my recessed drawer pull idea and revisiting my original pull idea. The problem I'm now noticing is I'd be attaching end grain to long grain and with the potential for expansion, might be looking at a mess depending on how much the doors expand.
How would you handle -- pun intended ;) -- this?
My doors and drawer fronts are 18mm thick and recessed 36mm (pulls are 54mm deep/wide):
Thanks!
Recon Tool Notifications
Anthony
Offline luvmytoolz
Re: End grain, long grain, and wood movement
« Reply #1 on: May 10, 2023, 07:49 PM »
I've done similar and found as long as the trim and panel are sealed adequately you don't really get any expansion problems. On a table it would be a different story as it's so much wider, but for small doors/drawers and stuff like that I've not had issues.
Offline ChuckS
« Reply #2 on: May 10, 2023, 07:55 PM »
Not entirely familiar with your aesthetic and design requirements, my suggestion below is for cross-grain constructions in general:
Glue (in the center), screws, plugs and elongated holes are commonly used in cross-grain situations.
Offline jeffinsgf
  • Woodpeckers Marketing Department
« Reply #3 on: May 10, 2023, 10:19 PM »
My approach would be similar to Chuck's, but I would do them on the edge instead of the back. Race track shaped holes with flathead brass screws.
Offline 4nthony
« Reply #4 on: May 11, 2023, 12:27 AM »
Thank you both.
Brass screws on the edge would be a nice visual when the doors are open. The same style pull would be used on the drawer fronts, and I could put a run of screws along the top edge of each drawer, too.
If I go in from the back, I think I'd have to make the shoulder (?) that covers the end grain a bit thinner so I'm not so close to either edge. Or completely remove it.
I'm so worried that I'm going to screw this up. I've got 4 doors and 6 drawer fronts to do.
Anthony
Offline Birdhunter
« Reply #5 on: May 11, 2023, 02:41 PM »
Can’t tell from pictures, but is the oak quarter sawn?
Birdhunter
Offline Packard
« Reply #6 on: May 11, 2023, 03:13 PM »
Perhaps a sliding dovetail and pin in the center?
Offline 4nthony
« Reply #7 on: May 11, 2023, 03:58 PM »
Yes, it's quarter sawn.
I hadn't thought about that but the shape of the pulls could be reworked to allow for it. Would you put the groove on the pull or the door?
Anthony
Offline Packard
« Reply #8 on: May 11, 2023, 04:36 PM »
I would put the dovetail in the door.
Or maybe use a Hoffmann bow tie  wedge.
Here a guy is using Hoffman wedges in place of dominoes Or biscuits or dowels.
https://www.google.com/search?q=hoffmann+dovetail+key+joint+youtube&source=lmns&bih=817&biw=1283&client=firefox-b-1-m&hl=en&sa=X&ved=2ahUKEwjf1qyrje7-AhWJF1kFHQnUCUcQ0pQJKAB6BAgBEAI#fpstate=ive&vld=cid:7432849b,vid:gMpJc4IRAlk
Offline Birdhunter
« Reply #9 on: May 12, 2023, 11:12 AM »
I have used a lot of quarter sawn white oak and have seen very little seasonal movement. I do build to accommodate seasonal movement across large glue-ups. With the small pieces in the drawer, I think you won’t see movement especially if the piece is indoors. If it lived outdoors, you might get movement.
Birdhunter
