Author Topic: E6000 Clear Industrial Strength Adhesive 59.1 mL  (Read 457 times)
Offline ChuckS
« on: June 06, 2022, 09:18 AM »
A contact cement like (epoxy) glue that's better than contact cement for certain jobs:
https://answers-to-all.com/language/what-is-e6000-glue-used-for/
I use it to attach magnetic bit holders (magnets) to my cordless drills and leather pads to C-clamps, etc. Great for plastic to metal, leather to metal and more, even in extremely cold shop environment (e.g. -30 C). I allow 72 hours for max. strength. Do not use it on Styrofoam.
« Last Edit: June 06, 2022, 09:37 AM by ChuckS »
Offline Vtshopdog
Re: E6000 Clear Industrial Strength Adhesive 59.1 mL
« Reply #1 on: June 06, 2022, 10:06 AM »
I keep a tube around, very handy stuff.
Originally started using to tack down wiring and crossover internals on loudspeaker builds but find lots of uses elsewhere.
Strong and seems a tiny bit flexible.
Offline Sparktrician
« Reply #2 on: June 06, 2022, 12:46 PM »
Another great adhesive is Gorilla Clear Grip.  I just used it last week to reattach a weather strip on the back window of my Expedition when I found that Ford doesn't sell replacement weather strips (one has to buy an entire window glass if the weather strip gets damaged).  The Gorilla Grip Clear was $5.70 vs. $381+ for the rear window.  Easy choice...
- Willy -
Offline Chainring
« Reply #3 on: June 06, 2022, 07:24 PM »
E6000 has been around for quite a while. I used to use it for holding together the lexan bodies on radio controlled cars. Not the Radio Shack variety, either. These were the .21 cc engine nitro methane powered monsters.
Offline RJNeal
« Reply #4 on: June 06, 2022, 11:08 PM »
Oh about 30 years ago, we were moving a pull ripper with a caterpillar D2 which normally doesn’t pull it. When we were unloading it off the trailer, part of the ripper collided with the fuel tank a put a 1” slash in it. It was during the spring cut and we didn’t have time to put the D2 out of service for any length of time. Once we got the diesel level below the leak. I cleaned it off real well and smeared some of the E6000 on it and worked it in the crack. It held up for a few months. That’s stuff is great.
It also comes in different velocities and sizes. The salesman said even in a fifty gallon drum.
They can seal (line)inside of garbage trucks
