Author Topic: Drywall screws, needle point vs drill point  (Read 943 times)
Offline threesixright
« on: August 22, 2020, 12:37 PM »
Hi All,
Could someone explain when you should use the one or the other?
Thanks!
// UPDATE
The question is not about fine = metal and coarse is wood.
I do understand they are both for metal-studs. Its more when to use the drill-point. I was thinking maybe they (drill point) screws slightly easier when screwing though drywall and behind are two (overlapping) pieces of metal stud (like where the horizontal and vertical pieces meet)?
« Last Edit: August 22, 2020, 01:48 PM by threesixright »
Offline MikeGE
Re: Drywall screws, needle point vs drill point
« Reply #1 on: August 22, 2020, 12:41 PM »
I use the drill point when I'm attaching drywall to the metal stud.  I use needle point for everything else.
« Reply #2 on: August 22, 2020, 12:58 PM »
You'll also notice that the drill point has finer threads for metal studs.
Offline six-point socket II
« Reply #3 on: August 22, 2020, 01:39 PM »
Fine thread = metal studs
Coarse thread = wood studs
Some prefer the drill tip on fine thread screws for metal studs.
Kind regards,
Oliver
Kind regards,
Oliver
« Reply #4 on: August 22, 2020, 01:45 PM »
@six-point socket II @Cheese  @MikeGE
Oopsie [big grin], should have mentioned that that much was clear (fine = metal) [embarassed]
But once again thrown off since SPAX has 2 types of fine threads for metal studs. So, they are both fine threads, only one has drill point and both are for drywall.
The pictures are of the GIX-A and GIX-D.
Offline Bob D.
« Reply #5 on: August 22, 2020, 03:24 PM »
Another type I have seen would be 'rock-to-rock' screws used
when laminating drywall.
They have a deep, coarse thread.
Offline bigjonh
« Reply #6 on: August 23, 2020, 05:47 AM »
Needle point or self piercing for lighter gauge (25-20) steel stud. Self drilling for heavier gauge (20-14) steel stud.
« Reply #7 on: August 24, 2020, 06:02 AM »
Thanks! This I was looking for.
Offline aloysius
« Reply #8 on: August 24, 2020, 06:21 AM »
Needle points are specifically designed for lightweight Furring Channel, but will work OK in softwood scantling also.
As previously stated, drill points are specifically for structural steel scantling.
FOG-wit since '95:  Some say since birth...
