I've managed to read far too much about drawer slides that I've now in data overload mode.
![Unsure [unsure]](https://www.festoolownersgroup.com/Smileys/default/unsure.gif)
Thus a few questions:
1) When using side mount slides, what is the best position for the slides? Top, bottom, middle, or wherever?
2) If using the 32 mm system will side mounts all be the same distance from the bottom of the drawer? It seems they should be, but...
3) How do you go about attaching side mounts when using the 32mm system holes. I've read some attach to the side first, then use a spacer below the drawer, then slowly pull out the drawer and then drive the screws. Others draw lines, etc. What is your preferred method?
4) Is there an advantage to the undermount types which appear to wrap around to the sides of the drawer?
TIA
