It looks like the typical Phenolic panels that should be fairly easy to source if you have a decent sized cabinet shop in your city. Most of them should have some off-cuts, as long as you aren't too concerned about color.
The stuff is a pain to work with though. It is very hard and dense. Your regular carbide tools will cut it, but it will be slower. Don't even think about trying to drive a screw, nail, or staple into it. You can drill/countersink an oversized hole and screw through it, but not into it. It is actually dense enough that you can drill and tap threads into it, if necessary.
You can sand the edges to a very nice finish, if that is important, but it eats sandpaper pretty quickly too. If you need to attach pieces to each other, it really takes some physical joinery along with some epoxy type glue. Simple but joints don't hold so well.
