Author Topic: Buying baltic birch direct?  (Read 1294 times)
Offline ryanjg117
« on: February 10, 2020, 06:33 PM »
As much as the movie Training Day has made me apprehensive to do direct business with the Russians, I have heard rumors that baltic birch can be source "direct" at substantial savings over what a local plywood supply or lumber yard would charge. Knowing that we have a fair share of pro woodworkers frequenting the FOG, I'm curious if that's actually the case, and what kind of minimum order quantities would be required?
Offline WillAdams
Re: Buying baltic birch direct?
« Reply #1 on: February 10, 2020, 07:14 PM »
At a guess it would be one shipping container full --- do you have a local specialty supplier?
e.g., Industrial Plywood here in Pennsylvania --- their fuel charge for delivery is pretty reasonable, and their prices quite good.
Offline StanB
« Reply #2 on: February 11, 2020, 12:40 PM »
Russia is not a bad country to work in provided you have decent contacts and you have written documentation. Do you have a supplier in mind? I have contacts in moscow or sverdlovsk region (western siberia) that may help you out.
Biggest issue after making contact, would be to find a local exporter to handle shipping out of russia. I think it would come down to that you really need to order an entire 20-40 ft container to make the venture worth while. Trasco and Major Expediters are some of the companies I have worked with in the past.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18
