Author Topic: Frosted glass panel for an interior door  (Read 2080 times)
Offline nw60312
« on: April 05, 2020, 10:58 AM »
Hello,
Need to build a bath room door with a glass door panel, it will be a sliding door. Looking for a 'frosted' panel that will let light in but provide a decent amount of privacy.
Any recommendations on materials for this, glass vs plastic, types of plastics etc?
Suggestions for online suppliers would also be appreciated.
Thanks!!!
-Nate
Online Cheese
Re: Frosted glass panel for an interior door
« Reply #1 on: April 05, 2020, 11:20 AM »
I just purchased an entire full view bathroom door from Menards. It was less expensive than me cobbling up something from bits & pieces. I installed it about 5 years ago and it works well. It looks better from both inside the bathroom and outside the bathroom. I think it was $200-$250. Just paint and install your pocket door hardware. The glass panel has just the right amount of privacy and it has a slight greenish cast to it.
I priced a full view frosted & tempered glass panel from Brin Northwestern, a local glass shop, and the glass alone was over $300.
« Last Edit: April 05, 2020, 11:33 AM by Cheese »
Offline nw60312
« Reply #2 on: April 05, 2020, 02:42 PM »
Unfortunately the local building inspector is very particular. In this case an off the shelf door slab won't work, it needs to be a wonky size. I priced out custom sizes a while ago and they got crazy expensive...
« Reply #3 on: April 05, 2020, 03:09 PM »
Could you add-on and or cut down a stock door?
Online Cheese
« Reply #4 on: April 05, 2020, 03:31 PM »
That particular door can be ordered in 24", 28", 30", 32" & 36" widths. Certainly one of those could be cut down to a wonky size. The door can also be ordered with no lockset bore and with a multitude of other options such as jamb size, door construction, door frame material, hardware finish.
https://midwest.menards.com/YDYWInternetDesktop/estimate.do;jsessionid=6F85A424DBF6BE93E9CD38365DEEAB19.tndm-mw-app-db?execution=e1s1#
Online gunnyr
    • Compass Custom Creations
« Reply #6 on: April 05, 2020, 06:34 PM »
I'm curious about the need for a wonky size?  I'd be very interested in the inspectors concerns.
I installed two such frosted glass pocket doors just two years ago, I don't think the Inspector made a comment on them at all.
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline Koamolly
« Reply #7 on: April 05, 2020, 06:41 PM »
You might check with local tinting shops to see what graphics they offer.  Can be just frosted tint.  You could probably drop off the glass or the door to their shop.
This is just to give you an idea.  They do good work though.
https://www.tnttinting.com/glass-graphics
Offline tjbnwi
« Reply #8 on: April 05, 2020, 06:52 PM »
A couple of things----the glass needs to be tempered for 2 reasons---one it is a door, two it is a bathroom. I believe this is the inspectors concern.
I did these in 2005. Desinged the graphics, had a vinyl printer print/cut them. Only the outside has the graphic, the inside is a full frost. The powder room door is the room blasted in the glass. Open the door, look at the door, look at the room they're mirror reverse images of each other.
I used fine glass for the blasting media if I recall correctly.
« Last Edit: April 05, 2020, 07:06 PM by tjbnwi »
Offline tjbnwi
« Reply #9 on: April 05, 2020, 07:20 PM »
Forgot to mention try Onedayglass.
They have a satin etch for tempered, you may need to get a sample to make sure it is what you want.
https://www.onedayglass.com
Online Cheese
« Reply #10 on: April 06, 2020, 10:31 AM »
I'm confused with the apprehensions of the building inspector. His only concern should be if the door has this ANSI Z97.1 certification or something similar etched in the lower corner of the glass.
Another alternative is the use of privacy films on the tempered glass panel. I've purchased from these folks before and I've been quite satisfied with the products they sell. They also provide free samples of the films they carry. The films arrive rolled up in a mailing tube and are in perfect condition.
https://www.decorativefilm.com/product-list?gclid=EAIaIQobChMIo87F8e7T6AIVBavsCh0fSA5XEAAYAiAAEgIrrfD_BwE
Offline Lincoln
« Reply #11 on: April 06, 2020, 05:28 PM »
Maybe the inspector is concerned about the integrity of the door, seeing as it's holding a glass panel, if it's cut down?
Offline nw60312
« Reply #12 on: April 08, 2020, 09:40 AM »
Thanks for the suggestions! The inspector in the case is my spouse, she is often much tougher than the actual building inspector. Given the existing space we are going to do a modern barn door (I don't want to open up the load bearing wall to try to do a pocket door). The problem is by the time I try to buy something to cut and extend, the rail and style proportions end up not flowing well with the other doors.
We have been building the other doors as we go and been very happy with the result so far. I just haven't done any with light panels yet, so that is the new part. I think I have a pretty good idea on the changes from how I have done the other doors for a light panel, just questions on the material pros and cons.
Thanks!
Offline SilviaS7
« Reply #13 on: April 08, 2020, 10:31 AM »
If you can't get the frosted glass in the look you want, you can always get clear glass and use a spray on frosting (which can be scraped off later if you change your mind) that comes in a spray can like spray paint, or get a vinyl frosted glass look and apply it to the glass.  This too can also be peeled off later.  There are a ton of designs in the vinyl so perhaps the wife can pick out something she likes?  Just some ideas.
Offline kevinculle
« Reply #14 on: April 08, 2020, 12:45 PM »
When I did my kitchen cabinet build about 8 years ago I had a bank of wall cabinets that I wanted to do in a frosted glass.  After looking around I found Bendheim Cabinet Glass (bendheimcabinetglass.com) and was very satisfied with their product and service.  They have a wide range of options and will send you samples for a reasonable charge so you can see exactly what it looks like.
Offline jobsworth
  • Festool Baby.....
« Reply #15 on: April 15, 2020, 11:57 AM »
Personally if it was me (and it will be soon as I got one on my honny do list) I wouldnt worry about getting it inspected unless its a new build house or additionor being built for a client.
 If yer building it for your own house Id make the door frame , take it to the local glass shop, tell them what you want what its going to be used for let them handle it.
Offline Lincoln
« Reply #16 on: April 15, 2020, 05:28 PM »
He was joking about the 'inspector', he was referring to his wife. Should have been made clearer, most replied thinking it was an actual inspection.
Offline tjbnwi
« Reply #17 on: April 15, 2020, 05:58 PM »
No matter the "inspector", make sure you use tempered glass. As I mentioned above being a door, and bathroom both make tempered a code requirement.
Offline Lincoln
« Reply #18 on: April 15, 2020, 06:00 PM »
Tom, would laminated glass be up to code, in your area, or only tempered?
Offline tjbnwi
« Reply #19 on: April 15, 2020, 07:11 PM »
Tempered only in the 2 states I currently work and the 4 other states I used to work in.
Two counties I’m aware of in Colorado (one of the 2 states I currently work in) requires tempered glass in any window/glass area within 3 feet of a door also.
All of the above require a monogram/bug on any tempered glass. Without the bug, they’ll fail the glass.
Offline rst
« Reply #20 on: April 15, 2020, 08:01 PM »
As a former glass distributor, doors are required to have safety glass, which usually tempered or laminated.  Plastics are also acceptable but not from a durability or ascetic point of view.  Obscure tempered as a general rule will be cheaper as obscure lami is not common.  There also other requirements for glass adjacent and above doors.
Online Cheese
« Reply #21 on: April 15, 2020, 10:11 PM »
Just to add to what @rst  has already said, plastic glazing, while it's safe from a hazard perspective goes, it is very prone to scratches and if the wrong cleaners are used it can also cloud up. Even using paper towels on acrylic glazing can scratch the surface as opposed to cotton or micro fiber cloths. In the long run, it's better/cheaper to just go with actual glass glazing with the "BUG" attached in the corner as Tom @tjbnwi has already stated.
On top of that, I believe that the only advantage of using white Lami is that it is lighter in weight than glass but I believe it is also much more expensive.
Offline Don T
  • Phoenix, Az
« Reply #22 on: April 15, 2020, 10:47 PM »
You could try this film.
Offline rst
« Reply #23 on: April 16, 2020, 09:13 AM »
Just for clarity...lami is not much lighter than tempered as it is two pieces of 1/8" glass with vinyl glued between.  1/4" glass weighs 3.15/ sq ft.  I this case you could go with 1/8" tempered which would be lighter and is common in doors.  Even 1/4" tempered is lighter at 2 lb/sq ft.  There is 1/8" lami but I would not recommend that route as it is much more fragile.
Offline nw60312
« Reply #24 on: April 16, 2020, 09:15 PM »
Thanks for all the info!
Got the esthetic design sorted out, ordered the stave core stile and rail material today.
Didn't think about the durability issues with plastics. Will go down the tempered glass route, and will make sure to get it with the 'bug'. This won't be a permitted project but that is a great suggestion just in case, it does cover a room that will be a permitted project when things open back up.
Thanks All!
