Author Topic: Adhesive advice sought  (Read 2502 times)
Offline mwolczko
« on: February 03, 2023, 01:14 AM »
This German-made bathroom scale has been in use for 20 years. The glass plate on which one stands was attached to the raised metal disc in the middle of the base by a circle of adhesive, which failed this morning. It lasted an estimated 15k cycles of someone getting on and off (2 people, daily, 20yrs)!  What kind of adhesive would work to repair this?  When my foot first lands there’s 240lb being applied several inches from the disc.  Or is this something that can only be accomplished in factory conditions?
Offline afish
Re: Adhesive advice sought
« Reply #1 on: February 03, 2023, 08:46 AM »
Most likely they used a UV glue like the glue used to attach rearview mirrors to windshields or windscreens depending on what side of the pond you are on.  You can buy UV glue just run a google search for it.
Offline Packard
« Reply #2 on: February 03, 2023, 09:41 AM »
Windshield adhesive is probably going to do a good job.  The “UV” represents the type of curing process.  It does not necessarily mean it is UV resistant.
You do want an adhesive that remains rubbery.  All that flexing will destroy a bond that is rigid.  I would not use epoxy for that reason.
My first inclination is to use E600 adhesive.  It is a styrene based adhesive that remains flexible.  It is like silicone adhesive on steroids. It is available in the big box stores like Home Depot, in hobby stores like Michaels and online from Amazon.com.
Amazon carries this product in squeeze tubes and caulking type tubes.  The others only carry the squeeze tubes.
This stuff cures in exposure to air. If you are just bonding to the perimeter, you will do fine.  If you are bonding to areas that will not have access to air, those areas will likely take a very long time to cure.
I like to use small pieces of mirror mounting tape to hold the piece in place, and use the E6000 everywhere else.
Also providing a good bond on non-porous surfaces is the adhesive that is used to glue rear view mirrors to the inside of the windshield.  But they come in very small squeeze tubes and it will cost a fortune to glue to a larger surface.
I recently bought a digital scale which reads to the tenth of a pound.  I don’t remember what I paid for it, but certainly under $40.00 and more likely under $30.00.
Unless you are emotionally attached to the scale, I’m not sure that making a repair is entirely sensible.
Offline mwolczko
« Reply #3 on: February 03, 2023, 09:55 PM »
Thanks - I’ll give the E6000 a try and report back.
Offline mwolczko
« Reply #4 on: February 18, 2023, 10:02 PM »
Update: I cleaned both surfaces, applied the E6000 and let it cure for 5 days.
It failed the first time I stepped on the scale.
Next I got some JB Weld ClearWeld epoxy (which is one the few adhesives that actually claims a specific strength), cleaned off the dried E6000, and applied that.
After another 5 days I just tried — and it failed immediately.
Next up is probably a cyanoacrylate, unless someone has a better suggestion.
Offline guybo
« Reply #5 on: February 18, 2023, 10:10 PM »
Hi, only a thought windsheild adhesive  metal glass,maybe?
Offline mwolczko
« Reply #6 on: February 18, 2023, 10:36 PM »
Could be.  The ones for mirrors seem hellishly expensive to cover the area in question (eg $10 for 0.01oz).  I might end up there.
Aside: how come hardly any manufacturer advertises tensile strength for its adhesives? How do actual engineers who need certainty to design products deal with this?  Or is there a special secret place they go for this info?
Offline waho6o9
    • Garage Door Handyman.com
« Last Edit: February 18, 2023, 10:41 PM by waho6o9 »
Offline mwolczko
« Reply #8 on: February 18, 2023, 11:02 PM »
Thanks.  Loctite has actual specs on its web site and this glue has an unimpressive tensile strength of only a few hundred psi.  By comparison, JB ClearWeld is advertised at 3900 psi, but under what conditions is not stated…
Also, I wonder how far 2g goes.
Offline Crazyraceguy
« Reply #9 on: February 19, 2023, 07:47 AM »
I would be willing to bet that it is because they cannot control the condition of the surfaces you want to bond nor confirm after a failure that it was done to whatever specs they may provide. Basically it's a CYA situation, lawyers, etc...
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Online Cheese
« Reply #10 on: February 19, 2023, 11:05 AM »
There are a couple of 3M products that may work, not sure about your application specifically but it's probably worth checking into.
I've used 08693 a urethane windshield adhesive and my neighbor has used 08609, a super fast urethane windshield adhesive, also known as Windo-Weld on his Volvo.
Scroll down to page 28 on this 3M product guide.
https://multimedia.3m.com/mws/media/467721O/2007-adhesives-coatings-sealers-product-catalog.pdf
Offline Vtshopdog
« Reply #11 on: February 19, 2023, 11:50 AM »
One thing to consider is each failed attempt is likely to leave residual contaminants that will interfere with future bonding and your chance at success decreases. Also, each time you step on the scale and bond fails you have some risk of injury.
Personally I’m all on on repairing and restoring things rather than tossing out as a life ethos, but at what point does purchasing adhesives that may or may not work stop making sense and simply replacing the scale become a preferred option?
Offline Packard
« Reply #12 on: February 19, 2023, 03:47 PM »
How valuable is this scale?  I bought a very accurate digital scale for $30.00.  Perhaps you are better served by replacing it.
Or write to the manufacturer and see if they offer repair services.
Offline mwolczko
« Reply #13 on: February 19, 2023, 08:06 PM »
I buy that. But I was hoping there’d be some kind of standard (ISO/DIN/BS/etc) which would yield a published result under carefully controlled conditions, and that could be used to engineer stuff.
Offline mwolczko
« Reply #14 on: February 19, 2023, 08:06 PM »
There are a couple of 3M products that may work…
Thanks for the link, I’ll take a look.
Offline mwolczko
« Reply #15 on: February 19, 2023, 08:17 PM »
You’re absolutely right (as are the other posters suggesting replacement).
I’m doing this only because this particular item perfectly matches the decor of the room it’s usually in, and because I’m curious about how this could ever have worked and lasted for so long.  I’ll noodle for a bit, but I may end up just giving up.  I’m not sure I’ll ever persuade the missus to use it again, even if I think I’ve succeeded (and with good reason).
Having inspected the failed bond I attempted with epoxy, it seems to me the cure was not good — the cured glue feels soft and sticky.  One drawback of a twin-tube dispenser, when both sides contain clear liquid, is that you can’t really assess how equally both sides were dispensed.  I may try again, but controlling the mix a bit more carefully.
Offline Packard
« Reply #16 on: February 19, 2023, 08:57 PM »
What brand is it?  Is it on the Internet so we can see what it looks like?
Offline mwolczko
« Reply #17 on: February 19, 2023, 09:08 PM »
Offline GarryMartin
« Reply #19 on: February 21, 2023, 04:39 AM »
Have you tried emailing the manufacturer and asking what glue should be used?
Offline mwolczko
« Reply #20 on: February 22, 2023, 12:18 AM »
Splendid idea!
Offline mwolczko
« Reply #21 on: February 26, 2023, 04:13 PM »
I’m happy to report that a second attempt with JBWeld ClearWeld epoxy has been successful. This time I carefully titrated the epoxy components using a scale that measures to 0.05g and applied a thin layer.
Thanks for all the suggestions.
Offline waho6o9
« Reply #22 on: February 26, 2023, 05:53 PM »
Your perseverance paid off, good job!
« Reply #23 on: February 27, 2023, 07:05 PM »
It's not helpful in this particular case, but for later when someone finds this by searching, it might.
The reason it wouldn't work here is that is not clear and would show through the glass.
For other applications though, we have been using some stuff called Boa-Bond. It comes in standard caulking gun sized tubes. This material is very thick/stiff, thus hard to dispense, but it sticks well and very quickly. It's not like superglue or contact cement, but it does hold surprisingly fast.
It's similar to your typical construction adhesive, but holds fast much quicker, doesn't drip or run, and sticks to a greater variety of materials.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
