Author Topic: Will Drilling Holes in a Kapex Void the Warranty?  (Read 7039 times)
Offline BobKovacs
« on: May 07, 2011, 11:49 AM »
Fastcap has a new fence/stand that looks interesting, but the fence brackets are mounted by drilling a few self-tapping screws into the sides of the saw. Would doing that void the warranty in any way?  I doubt it would harm the saw in any way, but it's worth asking.
Offline Steve R
Re: Will Drilling Holes in a Kapex Void the Warranty?
« Reply #1 on: May 07, 2011, 12:43 PM »
Have you looked at the accessory mount by Fastcap.  http://www.fastcap.com/estore/pc/Mounting-Bracket-for-Tile-Saw-p294.htm it looks like if you're using the new stand or the MFT Kapex or a home made stand you could make it work and not have to drill the Kapex.
Cheers,
Steve
« Last Edit: May 07, 2011, 12:51 PM by Steve R »
Offline mastercabman
  • NORFOLK,VA
« Reply #2 on: May 07, 2011, 01:12 PM »
Cheers,
Steve
What Bob is talking about is a fence system from Fastcap comming out pretty soon.You need to mount 2 brackets to the saw by using a couple screws on each side of the saw.Then you can mount the fence to the brackets.
http://www.fastcap.com/estore/pc/Best-Fence-p13398.htm
Offline Steve R
« Reply #3 on: May 07, 2011, 01:35 PM »
Cheers,
Steve
My bad.  Sorry read it to fast. At half the cost of the UG cart I can see that it is appealing. Also same wight. Only downside it is two things to carry/trips.
Cheers,
Steve
  • NORFOLK,VA
« Reply #4 on: May 07, 2011, 02:05 PM »
You could do something like I did so I could use my Kapex with a Sawhelper Fence.
That's a good idea!   Because i didn't know what to do when i need to use my crown stop.
Offline BobKovacs
« Reply #5 on: May 07, 2011, 02:39 PM »
Yeah, I could, but in this case there's an easier solution that doesn't require me to fabricate anything- all I need to domis run four screws into the side of the saw. I already fabricated adapters for my current setup- this time I'd li,e to just use a system as it is, provided it's not going to cause warranty issues down the road.
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« Reply #6 on: May 07, 2011, 03:32 PM »
Bob,I'd prefer to quote the warranty rather than answer your specific question.
Quote
Excluded from the coverage under this warranty are: normal wear and tear, damages caused by misuse, abuse, or neglect; damage caused by anything other than defects in material and workmanship.
The complete warranty text can be found on our website at http://www.festoolusa.com/support/warranty.html.
If you feel like your modifications will not fall under those exclusions, then you should be fine.
Basically, if the modification causes a problem with the saw, it will void the warranty based on my interpretation.
Offline BobKovacs
« Reply #7 on: May 07, 2011, 03:40 PM »
Makes sense. If a crack opened up in the base, emanating from the hole I drill, I'd expect Festool not to cover that.  If the saw motor stopped working, I'd expect that to still be covered under warranty, since the modification wouldn't cause that issue.
Thanks, Shane.
