But if you'd bought them in a professional capacity, at an industrial supllier, they most probably would.
The rules are a bit blurry over here (Our regulatory system is notoriously blurry throughout, I'm afraid) but a lot depends on the capacity in which a tool is used.
As a private person, few rules apply. If I want to die from falling of a crooked ladder, that's my responsibility.
In a professional capacity, more rules apply. I'm supposedly more responsible to the damage I might afflict onto others, falling of said ladder, and must use a certified safe one.
When I'm supplying employees with tools, even more rules peek around the corner. They must be supplied with safe ladders, tested for safety regularly, and aren't allowed to work of them for more then very short spells - otherwise I have to supply a scaffold and above a certain height fall protection devices as well ( safe, tested, etc. etc. )
When I'm servicing or granting acces to the public, the whole arsenal of rules gets uncovered - and that's quite an impressive arsenal, I can assure you.
Even if the government doesn't really put much weight in "governing" these rules, the insurance companies make sure they're maintained - you can't afford to loose insurance coverage, so you're more or less forced to abide by the rules. In a way, the government neatly "outsourced" their enforcement task...
Although I may sound a bit sarcastic, I'm actually glad the rules are there. It kinda helps to have a framework to check your responsibilities, some are easily overlooked.
But as much as I can relate to the goals, I'm not very charmed by the means.....
Sorry, end of rant here
![Unsure [unsure]](https://www.festoolownersgroup.com/Smileys/default/unsure.gif)
Regards,
Job
