I must admit, I have a VS-600 that has been sitting in the box since the day I bought it, and that has been at least 5 years ago. That's very unusual for me. In general, I'm not a "tool collector". Thanks for the link to Jerry's excellent guide. It might be the inspiration I need to get it involved in my next project.
Those of you who have taken your VS-600 out of the box --
-- how useful do you find the doweling set up? I have the templates for 14mm half blind, 14mm through and doweling. I've promised myself that if I use it on a couple projects I can get the 25mm though template.
I used the dowel stuff and it worked great! I can't imagine trying to get multiple dowels
properly positioned and correctly drilled without it. There is no tolerance for error with dowels.
However, since I bought a Domino I have no use for multiple dowels.
That said, the dowel template is still useful by itself for drilling 32mm spaced holes.
I have used the VS 600 for making through DT drawers but it was another guy's setup and I don't remember which template it was. It works best if your parts are sized as a multiple of the template finger spacing. One minor issue was that I had to add a very small shim to one of the template positioning stops to get the alignment of the finished parts perfect.
